Alarm Horn
Hi, as my indicator lights no longer flash when i operate the central locking, i decided to have the beep from the alarm horn come on, i set this up with vag-com, but no beeps, vag-com tells me there is no communication with the alarm horn and intermittent fault with ind. lights, .
Does this mean i have a problem with the dreaded convenience unit :mecry:
Mind posting a complete diagnostic protocol (Auto-Scan), so we can see exactly what's going on and which stuff is actually in your car?
Hi, sorry for not getting back to you sooner,
These are the faults found on scan of Central Convenience.
My car is the Elegance model, has just about everything in the line of extras,
3 Faults Found:
01131 - Control Circuit for Turn Signals
25-10 - Unknown Switch Condition - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
49-10 - No Communications - Intermittent
01134 - Alarm Horn (H12)
49-00 - No Communications.
See, the reason why I wrote "complete" was also to see your control module part number. This would make us able to tell you which measuring blocks to look for since it's unknown yet which control module (generation) your car has.
Additionally there seem to be some more issues with your car than just the horn - another reason why I suggest you post a complete Auto-Scan.
Hi again, I did an autoscan and these are the modules which returned a fault,
hope this information is better
regards,
Control Module Part Number: 1C0 959 799 B
Component and/or Version: 5F Komfortgerát HLO 0004
Software Coding: 00259
Work Shop Code: WSC 28059
Additional Info: 1C0959802 5F Tõrsteuer.FS KLO 0009
Additional Info: 1C0959801A 5F Tõrsteuer.BF KLO 0009
Additional Info: 3U0959811 5F Tõrsteuer.HL KLO 0009
Additional Info: 3U0959812 5F Tõrsteuer.HR KLO 0009
2 Faults Found:
Control Module Part Number: 3U0 907 044 A
Component and/or Version: CLIMATRONIC S B5 C 2004
Software Coding: 17000
Work Shop Code: WSC 00028
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
Control Module Part Number: 1U0 035 161 D
Component and/or Version: Radio GRO 0001
Software Coding: 00407
Work Shop Code: WSC 00000
3 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
00853 - Loudspeaker(s): Rear
36-10 - Open Circuit - Intermittent
01044 - Control Module Incorrectly Coded
35-00 - -
