ABS Problems
Has any one had any problems with their ABS.
I have had the ABS warning light stay on and then go off after a while but when I brake the ABS is sometimes comming on even under slow braking.
I have cleaned all the sensors on each wheel but still the problem occurs then goes away?? The rings look ok but then again not 100% sure
If I disconnect one sensor from one wheel will this disable the whole ABS system as I would like to try and eliminate each sensor.
If not it will be a visit to a skoda dealer:(
It will disable the whole system indeed.
Fault code check should identify the problem.
Sounds like a job for the mighty vag-com!!
Yes I thought it might disable the whole system.
Suppose I will bite the bullet and book it in tomorro on the VAG-com
