Limp Mode
Right, got a bizzare problem.
If i turn my engine on, let it idle until the revs settle down after a few mins, then go to drive it, i cant get above 5psi, until the usual switch off/on again, then fine.
But if i jump in the car, drive it, and go above 5psi within the first few minutes, the car is fine, and never goes into limp mode.
VAG-Com showing nothing new, no CEL lights, and otherwise the car drives fine.
(apart from my faulty thermostat)
But it's been doing it since day one.
Any thoughts ?
Dodgy N75 possibly?
Could be..although i'd expect the problem to occur more often, not just when i dont take it above 5psi.
What about the other way round:
Drive it as soon as you turn it on, and after a while try pulling aside and let it warm a little.
What happens then?
Does exactly the same...goes into limp mode unless i drive it above 5psi.
Should've said, it does it warm or cold.
Hmm... :(
Have something alike (don't know about the PSI) - when left to heat it losses power - it may be while waiting on the driveway or while waiting for the lights to change (especially after a long jurney).
I'm sure it has someting to do with temperature - I live in a hot region (middle east) and it happens more often on daytime.
Mine involves also limp mode after harsh driving.
Tried several things - replaced N75 and all vacuum pipes, replaced the MAF, ruled out the A/C control unit and the intake air temp sensor (on the intercooler). To no avail.
VAG-COM couldn't find anything.
