Wiring up a booster...
I've just got myself one of these to try and do something with the reception before trying a new aeriel,
has anyone got a picture of what to wire the blue wire too? or an explanation would be just as good.
cheers for the help,
Shaun.
Assuming this is a device for supplying power to the aerial base mounted amplifier (booster) then the blue wire needs to go to a 12 volt point that is on with the ignition, or on when the radio is on.
If it is an amplifier itself then the same applies for the power but it may not do much good as it is trying to amplify a very poor signal in the first place ,the roof aerial without the amplifier working is a very poor aerial as the roof amplifier does impedance matching and amplifies
it comes with a special clip on the end of the blue wire so i assume they had a specific pin to attach it to when they made it:confused:
