Petrol gague
The problem that i have now is that the petrol
gague every time the steering wheel is turned the gauge goes up and down and the
reserve alarm also sounds very annoying just had a new clutch fitted
the garage said that this is a new problem
it just seems strange that this has all happened as soon as i get the car back
it has never happened before could it be connected to the clutch change?
Sounds to me like a connector is being knocked when the wheel is turned causing contacts to break,but im no expert :rolleyes:
Cheers i will check it out:)
I'd agree with Mart, and would say that this seems to have happened during the clutch change, so it's the garage's responsibility.
They said no but have taken it back
because it is so annoying so i will see what happens later on when
i go to collect it
Got the car back today good as gold they said it was a wire under the battery housing it cost £30.00 which was ok so that suggests it was a loose
terminal
but there you go
i was not going to argue over £ 30.00
