Key???
SKODA FABIA, OCTAVIA, SUPERB FLIP KEY FOB REMOTE
3 BUTTON - HLO 1JO 959 753 G - 434 MHZ FREQUENCY
will this key work for a octavia 2001 vrs?
"should" do - the part number sequence and operating frequency is correct, the only anomally is the "G" suffix - normally would be AG(for 2button) or AH(for 3button), so not sure of the implication of that.
If it's not very expensive, worth a punt I'd say
It will work, but the extra button (boot popper) won't as the Octavia doesn't have this facility.
The 3rd button does work fine on my car and you can simply change top section with the key blade and transponder straight over avoiding the need for getting the new key blade cut and programmed :) Got mine from ebay for £28 all in. Seller id shaidk123 is who i bought mine from
yep, the boot button opens my boot too (2002 vRS) :)
Thats odd mine doesn't :confused:
odd.. seems like some do and some don't..
Presumably all have the locking motor in the tailgate to lock and unlock via the normal central locking? Maybe there's a (vagcom) module configuration that can enable or disable the remote boot unlock?
It won't pop the boot open, but it will unlock it.
Yeah I suppose you could be right I'll have to look into that one
Anyone know ?????
Depends on the version of the convience module you have. But my understanding is that all vRS have the right module because of their age.
Edit: Ah I was talking about estates due to them coming out on an 03 plate. Older hatches may actually use an older model module.
Do i need to cut the key or do they come cut universally from ebay???
Read the 4th post again dude, theres your answer
Depends if you want to use the whole key or just the remote part (which can be clipped into your current key). If you need a complete key, then you will have to get the key blade cut, if it's supplied as a blank, or buy a new keyblade and get it cut to suit if it's a pre-used keyblade.
I have an early 2002 VRS. As stated it doesnt pop the boot it just unlocks the boot without unlocking the doors. It also autolocks when the boot shuts or remains unopened for more than 20 seconds after unlocking.
