3 plugs at rear of headunit
Just bought a new sony head unit. Have removed the standard one and found 3 plugs which connect to the rear of the unit in the configuration shown below.
What does the plug for section C do? The adaptor that came with the sony has plugs that will connect to the A and B plugs only. Is the C plug left disconected?
Thanx guys.
Yes, the C plug is the connection to the autochanger at the back, You only need A and B. You will also need to cut the K wire, and possibly reverse the 12V feeds because they are reversed on the octy.
Thankyou.
which wire is the K wire?
The K wire is on Pin 3, of the power block.
  • 2 months later...
Been looking for this post!! LOL
Is the K-Wire on block A (Power Block?) connector 3? The one with all pins? Sounds a silly question but i want to make sure that is a top down picture of the car ISO and not the Headunit ISO, otherwise I have no K-Wire on the ISO.....LOL
If so, on my Kenwood that is a grey/black wire and i just unplug it with a paperclip, is that correct?
I looked on the Octavia ISO and the K Wire is there, Grey with a white strip. But there is nothing there on the Kenwood ISO in the same spot, so obviously it doesn't use it... :thumbup:
So, now the HU is in, USB in the glovebox, and RCA in the glovebox to! I need more time to fit the rest in LOL
