Front Skoda badge
I need to replace my front Skoda badge and want ot know how you remove the old one and replace with the new one?
They are held on by two pins which at the back had been kind of flattened- they are also held on by some sticky gue.
I would take the whole front grill off (some torx screws and very easy to take off) and cut the two pins at the back, then pry off from the front with a small flat headed screwdriver.
You can get new badges on ebay for £6 incase you didn't know...
My Badge was just held by the sticky foam at the front. It could of already been replaced before.
When someone decided to hit the front of my car damaging the grill i just got a replacement badge direct from skoda. It was only £6. I find that main dealer is quite good price for these type of parts. It is held ok just by the sticky foam.
hope the following helps.
When i removed the originals i used a thin piece of wire to "saw" through the glue holding the badge on, just be careful not to scratch the paint as you do it. once you get so far it will pull off. The ebay replacements are peel and stick.
When i put my new badge on i obviously used the sticky pad then heated up a screwdriver and melted the lugs flat like the original.
This way it ain't going no where.
