tail light
on my octavia reah lh tail and front position ligt do not work
i check fuse, bulbs and they are ok
what could be wrong
please help tnx
Are you sure the fuse is ok (it's one of the 5amps on the top left of the fuse board). The front side light and the rear tail light are common to each side (ie. RH front and RH tail are on the same wiring & fuse). If the fuse is ok then you probably have a break in the wiring which you'll have to trace.
yes the fuse is ok
Just a thought, have you checked the brake light sensor switch on the pedal?
I know that on my previous car that stopped the lights working, can also cause them to stay on.
Not sure where it is on the Octy but try searching for a post on here someone must know about it.
brake light sensor is ok and works ok
i yjuts don t have position light on left side front and rear
