in dash cd player
Does anyone know if your able to add a in dash cd player to replace the cuby hole so you have a double din setup. I had a mk4 golf which had the double din stereo/cd player which i also had a multichanger connected which is what im after in my octy.
From the look of the rear of the standard stereo it has the same connections to add the cd player.
cheers
Russ
I think with it removed its a double din
it's a very tight double din!
So it could work then? Cool ill give it a bash
Took me about 20 minutes yesterday just to fit the double-din cage it was that tight!
What sort of cage was it?? i was going for a mk4 golf/bora cage
