Hi All, I'm A New Member, Need Help!
Hi everybody
I'm having a power loss problem with my 51 plate fabia favorit 1.9TDI.:(
Its only when going uphill or overtaking, is fine on the flat.:confused:
I've done the obvious things, changed fuel filter, checked timing belt, redex, diesel magic,ect, clutch is fine. Oil is clean, I service regular. :thumbup:
Has been suggested that it could be pump but i'm doubtful as I said it's ok on the flat.:confused:
Anybody any ideas what to look for next?:o
I'm no novice and have a few ideas like MAF and brake servo pipe but would appreciate any feedback from you.:thumbup: Thanks.
Hello and welcome. Sorry I can't help you on your problem, but hope you get it sorted soon. If someone doesn't come up with a solution try a search or start a new thread in the Fabia section.
Welcome to Briskoda :thumbup:
As Captain Scarlet said, you will get a better response if you post your question in the relevant section. Hope you get it sorted :)
welcome to briskoda
Hiya. I'd check the MAF, by disconnecting it. Not like that costs anything.
However, I suspect the problem is a weak spring in the turbocharger boost bipass valve, causing it to open too early when you're on full throttle.
