Knocking noise 1st to 2nd
Hi guys,
Got a Octavia Mk1 vRS and today I have noticed a strange knocking sound when I change from 1st to 2nd only (Sounds like two loud 'clunking' sounds
Any ideas????
Mine does it as well, always has. I have no idea why though I'm afraid but if I change slower and more precise it seems to dissappear.
Sorry I can't be any more help
probably nothing to worry about. maybe just a noisy linkage or shift fork or something
think mine makes a little knock too
inspect it if you bet bored, but i wouldnt lose any sleep!
Thanks for your help guys :thumbup:
I stopped worrying about after about a year :)
I'm wondering about a slightly weak synchro (relative to the engine, I don't mean it's badly worn). I can't be sure, cos I don't know about peoples' gear change techniques.
You may well be right Ken, as i said if I do- clutch in -shift clutch out it doesn't seem to do it. Where as if I kinda toe poke slighty lazily and not use the full travel of the pedal, I get the noise
If you get what I mean
I what context do you mean "relative to the engine" (scuse my dullness)
I mean that you're beating the synchromesh because it doesn't have enough friction power to synchonise the second gear wheels as fast as you're asking it to.
Do you ease the throttle when changing gear, or just hold your right foot and expect the gearbox to do all the work of synchronising gear speeds?
I sort of see what you mean .....lol
as in blip it between changes ??? If so the answer is sometimes:D
You're changing up; it's not a blip. You're just easing back on the throttle so that the engine slows towards the revs it would want for second gear at the road speed you're changing at. Quite apart from being easier on the gearbox, done right it actually lets you speed your changes up, and is smoother than holding the throttle steady, or coming right off it to change gears.
yeah I never fully ease off I was thinking of the blip on the down shift, I'll try to think about my changing and see what I come up with.
As I said earlier this is all a bit foreign to me, but I do think I can be lazy with the shift sometimes (as with most other things)
It sounds like you're trying to do the right thing. The ideal gearchange is one that your passengers neither feel nor hear you make.
BTW, this is why I don't like conventional automatics; they always fail this test, usually by jerking me when they change and I'm not expecting the change.
Your more than likely right Ken
I'm goona try ypur suggestions out asap :thumbup::thumbup:
Agreed! When your passengers fall asleep easily you know your doing something right!
  • 1 year later...
Hi
Mine 2002 vrs seems to be making the same sound mine seems to do in 1st gear when you let your foot of clutch too quickley.
Re-reading the thread, I think the conclusion was that you should try changing gears more smoothly before looking for a cause that requires spending money.
