ABS Light
Could the ABS light come on if the discs and pads needed replacing. It has recently had a new sensor and my brake wear light is on as well. Car is a 03 Octy Vrs
i dont think that the abs light is related with the brake pads wear light replace the brake pads and if the abs light is stil on check it with a vag com
Neither do I. I suspect the recently fitted sensor in this case.
