light again
my engine light came on ,but my hubby good as he is checked the battery, and found some cells were low on wet stuff, so he topped them up, the battery put back in and the light dissappeared, until 5 days later and has stayed on since. also the interior door light fails to go out after the door is closed, causing annoyance, was told it could be a faulty censor or sensor on the door. any ideas somebody as all very much appreciated. thanks. :confused: :)
Hope he used the right wet stuff:eek:
The engine light coming on usually relates to some sort of combustion problem, often the egr assembly or lambda probe(s). A search will bring up loads, but you really need to get the car hooked up to vag com to find out.
The EPC light is another matter..................
