Help! anyone got vag-com in Devon?
Really would like to check my car for fault codes, as i have the surging problem :rolleyes: and what seems like a boost problem loads of boost low down but not much further up the revs. Hopefully this way i can find out what it is without having to change eveything related to these problems. Thanks. (Im in Honiton about 15mins from exeter)
I may be going to Jason's on sunday IF things go that way, will know as soon as he knows.
I've got an official lead & can bring the laptop along :)
:wavey: I'm in Dawlish.
Thats sounds good! but not sure if i will be able to make it over on sunday :( I could kill 2 birds with 1 stone though!
Jason i take it you have vagcom for the octy?
If so can i pm you to arrange a time to pop over some time mate?
I have it for any OBD2 equipped motor. As long as you know where your OBD2 port is, I can scan for fault codes. Around most of Sunday I think, OR if you want to pop over to Exmouth when I'm at work, I'll try to remember my laptop.
Thanks bud!
Yeah afaik i have obd2 with 16 pin bit i know where it is too mate. Sunday may be a problem for me but i'll see what i can do, i'll pm you and let you know cheers. :thumbup:
Mine's the full CAN-enabled one but yeah Mk1 is not CAN so should be fine ;)
No go for sunday! Father-in law's brithday cant get out off it! :(
So ww vrs you still coming down?
Cheers Jason for the scan :thumbup: and the cupra splitter!! Just need to sort out the two fault codes now.
No worries. Glad I could be of help. :thumbup:
Hope you get the DV and fuel trim codes sorted out asap. :)
