Windows Mobile 6
Hey peeps,
I have just installed WM6 onto my Vodafone V1640 (o2 XDA exec etc etc) I not can't use MMS or internet. I can't find the settings to put in to make it work again. I've googled but I can't suss it out. Where do the details go and what details are correct?
Any help much appreciated!
Hiya, I've tried those settings but to no avail :(
xda-developers - Xda-developers
Vodafone UK - Help - Vodafone
I got an XDA exec and it had WM6 but I had to flash the ROM to WM5 as it wasn't connecting to my wireless properly for some reason.
I had to get the latest one from T-mobiles website. it flashed OK though.
When I turned it on/reset the device T-Mobile would autoimatically send the settings.
Try going on Vodafones website or emailing them.
In the past I have found Vodafone Tech support really helpful, worth a call.
There should be an autoconfiguration setting in control panel somewhere, I dont have a WM6 mobile to hand so cant tell you where. I can tell you that vodafone use different settings for both payg and contract, and the config program lists them both but doesnt distinguish which is which. Try each one until you find one that works.
Also found this on another forum
Click on “Start“ – “Settings“
Click on “Connections“ (TAB) and select “Connections“
Click on “Advanced” and click on “Select Networks
You should see “Network Management“.
Click on “New” under “My ISP”
Enter the name “Vodafone MMS“ for these settings
Click on “Modem“ and then click on “New“
Enter the name “Vodafone MMS“ for this connection and select “Celluar Line(GPRS, 3G) for the modem type.
Then click on “Next”
The access point name is ”wap.vodafone.co.uk” for Contract and
“pp.vodafone.co.uk” for Payt.
The user name is “wap“.
The password is “wap”.
Then click on “Advanced…”
Use these IP address: 212.183.137.012.
Then click on “ok”
Click on “Finish“
Now, you see the activated “Vodafone MMS“ connection
And you see under “Network Management“, the “Vodafone WAP“
profile
