Advise suspension (rubber) parts :-)
Hi again!
I am about to order Bilstein B6 Sport shocks, Lesjöfors "OEM" springs and some SuperPro poly-bushes for my Octy Estate (1,6i - 2000-model).
On a prewiev my garage found that I should also change a bush (bearing?) at the top of the front shocks. The OEM is cheap and probably OK, but do you know of others that might be GREAT? :)
I also want advise for other rubber parts in the chassis that will highten the driving-experience changing.
Please then also mention the effect on NVH (Noise, Vibration and Harshness).
Olit
Do you mean the top mount? Quite a large rubber bush.
It's advisable to change them if your replacing the shocks.
As far as i'm aware noone makes an aftermarket version so an OEM bush is your only choice.
I've got the SuperPro poly wishbone and dog mount bushes and can recommend them.
