Skoda Octavia vRS mk1 speakers-results so far of my research!...
Hi.....
I have been trying to determine which speakers i can fit to the octavia mk1-here are the ones which i think will fit and i have put into a shortlist...what do you guys reckon?.....i will post links here so if you need to fit some new speakers,this is the latest tackle i can find online...which will fit into the prohibitive mounting depth of the octavia without any modification i hope lol...........
:cool:
Lanzar VX60S-Slim Mounting Neodymium Magnet
6.5" 2-way Speaker
Poly-Mica Coated Woofer Cone
1" High Tempreture Voice Coil
Neodymium Tweeter
80 Watts RMS Power
160 Watts Max Power
Impedance: 4 Ohms £74.99
Lanzar VX60S 160 Watts slim mounting speakers (2-way) - VX60S from Lanzar
Lanzar NEO6.1-240W max power
6.5" 2-way speaker
Neodymium magnets
Shallower speakers with fast bass response £129.99
Lanzar NEO6.1 240 Watts slim fit 2-way speakers - NEO6.1 from Lanzar
Lanzar VX610-Super Slim 6.5" 2-way Speaker
1" High Tempreture Voice Coil, Neodymium Tweeter
80 Watts RMS
160 Watts Max Power
Impedance:4 Ohms
Rubber Boot Magnet Cover £57.99
Lanzar VX610 160 Watts 2-way Super Slim speakers - VX610 from Lanzar
Kenwood KFC-1761C-3-way 3-speaker System
170mm Injection P.P.Cone Woofer
35mm Midrange & 12mm Tweeter
Easy Fit Connector for European Cars
200W Peak Input Power
Kenwood KFC-1761C 17cm 3-way Flush mount speakers - KFC-1761C from Kenwood
Kenwood KFC-1751C-Dual Cone Speaker System
180W Peak Input Power
Kenwood KFC-1751C 17cm Dual Cone Flush Mount Speaker - KFC-1751C from Kenwood
JBL's-http://caraudiosecurity.com/shop/product/products_id/4958.html
Infinity's-http://caraudiosecurity.com/shop/product/products_id/4305.html
Alpine's-
Features
6.5" (17cm) Woofers
Extreme shallow mounting depth
Separate high pass crossover network
Basket-integrated low pass filter
Soft dome tweeter (18mm) with level adjustment
Specifications
210 Watt Peak Power
25 Watt RMS
Frequency response: 35Hz – 25kHz
Insatallation Diameter: 139 mm
Depth: 38 mm
http://caraudiosecurity.com/shop/product/products_id/8019.html
Car Audio Direct - Alpine SPE-17SF Shallow Mount - Speakers
MB-http://caraudiosecurity.com/shop/product/products_id/5441.html
Blaupunkt-THx 652 *THx652 £39.99. * 2-way coaxial speaker system * Diameter (mm) 158 - 16cm * RMS Power 50 Watts * Max. Power 200 Watts * Sensitivity 2.83 V/m 92 dB * Frequency range Hz 60 – 22,000 Hz * Impedance 4 ohms * Cone material Injected PP/PEI * Installation depth (mm) 46 mm * Power to Install, With the TH speakers you avoid time consuming, costly and complicated installations. The series offers good quality sound and stylish design and thanks to the extremely shallow basket design the speakers will fit into almost every car.
Low Cost Car Audio | Blaupunkt THx 652 *THx652 - 2-way coaxial speaker system
Blaupunkt THx 662 £49.99.
System,
16.5cm 2-way coaxial speaker
RMS Power 50 Watts
can anyone add to these?...
hope this is of help sorry its a long post!! cheers all
Bradley x
Problem with some of those is that they are coaxial so the tweeter and woofer are mounte together which isnt ideal as all the high pitched sound will be by your feet, not up by the A pillars as designed. You really need a component set with seperate speakers.
Best to stick with component speakers.
The Infinity Reference 6010cs speakers are excellent value for money and sound great. Easy to fit because the tweeter fits in the stock tweeter location.
....thanks for this reply...ok heres another option im looking at,what do you think?...i dont want to mess around with the door cards,im told this is what you have to do to replace the standard tweeters...so,providing they are up to some sort of competence i will leave those in and fit just the 6.5's in the doors to handle the bass...
in the parcel shelf there are some nice co axial 5.25's lanzar again..
they seem dead good value for the spec,,
links below..
:)Lanzar Max 6.5" 300 Watts Components Speakers on eBay, also Component Speakers Sets, Speakers, In-Car Entertainment GPS, Cars, Parts Vehicles (end time 20-Mar-08 17:36:54 GMT)
Lanzar Max 5.25" Coaxial Two Way 160 Watts Speakers on eBay, also 5 5 1 4 Inch, Speakers, In-Car Entertainment GPS, Cars, Parts Vehicles (end time 18-Mar-08 14:11:19 GMT)
You will need to remove the door card for this anyway as you need to run cable to and from the crossovers. The standard speakers have a resister arangement that ensures the correct signal is supplied to the tweeter, as the componet speakers your planning dont, the crossover box will need to be wired up.
The standard tweeters arn't going to match the new setup and wont handle much power before they go pop.
