Maxi dot help
Hi all,
Newbie here! Got an 06 vRS with optional maxidot fitted. when I access the menu, it has one option that I can't access. IIRC its called vehicle settings?
Is there a special way of accessing this?
I want to set auto-locking up but I guess it'll be a trip to the dealers!
Thanks in advance:)
have you tried someone with a vag com?
IIRC that is the one which shows when you have low fuel or washer fluid or some other warning.
Mine's an 06 and Maxidot has limited functionality - i.e. you can't set anti-hijack etc.
Ah well!
Thanks for the replies.
Looks like I'll be taking a visit to the dealers to get the locking done. I want to add cruise anyway and probably the split level boot floor. More expense!!
the locking is a 30 second job with vag com, have a look on the vag com list for someone close to you!!
This might assist you in your quest :thumbup:
