Where is the air con drain underneath the car ?
I have a problem, see here: http://briskoda.net/forums/octavia-i/water-drivers-side-rear-footwell/105108/
My question is where is the air con drain underneath the car ?
Reading on the forum, Ive heard that the aircon drain can get blocked causing internal puddles, which I have.
Ive had the air con on as always and I'm not loosing water underneath the car as I have in the past.
Hopefully this is what is causing my problem, I have put it into ECON mode now so hopefully no water in the short term.:thumbup:
Matt.:D
Think its in the middle of the car underneath the center just behind the engine bay.Thats where mine drips from i think.Have you tryed putting a hose pipe on the windscreen and seeing if you can see the leak.Mine was very obvious once you had someone with a hose and me on the inside.Your wet patch is on the drivers side by the doors i wouldnt think the drain is over that side.
I have tried pooring water over the window, but as its wet still in the back and not drying easily its hard to tell.
I will have to wait till the next rainy day to see if its rain causing the flooding.:thumbdwn:
  • 8 years later...
Hi Multon,
I'm currently having the exact same issue you had regarding the air con leak?
Did you find out what was causing it?
Thanks,
Dan
