brakes
hi guys. just after some advise if any1 can help. what size front brake disks do the vrs have, Its a 51 reg, 02 plate, and do the pads have sensors on, because there is no mention of them in the haynes manual. any advise is appreciated thanx.
"PRAISE THE TURBO GODS"
sorry only me again, i forgot to ask, is the front brake pad wear sensor situated on the left or right or both. thanx for being a pain.
"praise the turbo gods"
312mm disks on front 256mm disks on rear and the pads do have wear sensors HTH :D
wear sensor is on the nearside front only i believe..
thanx very much, id allready had the offside wheel off, i thought it had bin dissconected for some reason. thanx again, will check, nearside 2moz.
checked nearside brakes today, and true to bodges word its right. thanx buddy.
No problemo mate!
I'm changing my front pads this weekend aswell.
Tried to do them the other day but didn't have a single 7mm allen key or socket amongst my mountain of tools. God knows why they went 7mm, so odd!
Have fun disconnecting the wear sensor wiring aswell! Those connectors are a bugger to pull apart, and usually get broken by angry mechanics!
Other than that the fronts are easy.....
i must say bodge, i thought it looked tricky myself when i had a quick look, is there any easy way it comes off. im a chuffer for breaking things. oh ill make sure ive got a 7mm key to lol. ta matey.
to save you typing praise the turbo gods every post (whatever that means)... you could always put it in your signature?
You can add your signature into the control panel options, save you typing it out.
thanks for the advise pmsl
Done mine now.
Predictably broke the electrical connector on the old nearside pad wear sensor!
Off to bed them in.....
