2008 superb speed pulse
Speed pulse location for connection to aftermarket Navigation or is it all on the 'CAN'
Thanks.
Mick
:confused:
what navigation are you fitting to your car? As some sat navs ie blaupunkt freestyler or rome doesnt need a speed pulse as its gps based only and the built in gyro will let the nav unit know when the car goes round corners......other than that a good ICE specialist shud be able to wire up a couple of iso plugs so that you can plug straight in........hope this helps regards andy
Thanks.
Mick
Mick
I see this is your first post. It is customary to post a hello in the intro section. Your post seems to be a question isn't very well worded.
The pulse wire is on the back of the radio unit's wiring loom
Thanks all,
Sorry for previous brief post, pulse required for taximeter intall for a new customer with fleet of new superbs, before I got on site I wanted to check if pulse was the same as previous installs id done on 57 plate cars.... It was ( behind the OE tuner )
All my tech info was at work and I was working from home. Grrr.
I'll post an entry as a 'newbie' introducing my self and hope I may also be able to help some of you guys in due course.
All the best,
Mick.
