Doors Remote and door lamp fault
Hi there!
Today i was changing that light the doors have down there when we open it, when suddenly, the bulb didn't turned on...I tryed reversing sides, and nothing...
Then i was trying to close the car using the key remote, and NOTHING!! And all the light the other doors has don't work!
Probably, I think is the fuse! But I don't have the Skoda RS Manual to see wich fuse is to change! Can anyone help me please!!
I have a Octavia I RS
I went th to car again to confirm:
-The eletrical windows and the interior door light DONT WORK
-The eletrical mirrors WORK
-Using the key, it LOCK AND UNLOCK ALL DOORS
So, i guess it's a fuse problem...isn't it? But i don't know wich fuse is cause i don0t have the skoda manual!!
The most likely fault that has happened is that the wiring connectors to the drivers side window regulator motor have corroded due to water ingress and broken the pins off on the motor.
Problem solved
Discovered the fuse by confirming one by one. It was the fuse had the resistance broken...Just erease the some info on the car with this...
