winscreen wipers not working (intermittent)
graemes75
Recommended Posts
The wipers on my 2006 plate furby are only working on setting 2 and 3 . All the washers are working normally and once before ive had to open and shut bonnet to get them to work. Ive tried fuses 15, 21 , 41 to no avail. Is it the bonnet open sensor ? They worked once after I had another look tonight but nothing after the inital wipe. Ive also noticed the amber lights arent flashing when I lock the car with the remote central lockin. Could these be related ? Any ideas ?
Link to comment
Share on other sites
There's an integrated switch in the bonnet latch!
That's your issue!
So is it just a case of buying a new one ? does the whole lot come as one or does the sensor come seperately ? i can see the swicth but it looks like like it comes as a whole? any ideas where to buy another?? Greatly appreciated :)
Link to comment
If the intermittent wipe doesn't work that could point to a faulty stalk contact, But that wouldn't affect the alarm!
Had a quick look on VagCat it's a single unit P/N 6Y0 823 509 E (Needs confirmation) First port of call would be your dealer or TPS!
If you buy it from the dealer don't be afraid to ask for a discount, The worst they can say is no! Dependant on the part my dealer usually gives me between 10-20% discount!
Edited by Mike B
Link to comment
Thats brilliant mate thanks for the help. Just pretty sure that its the switch , because the alarm not setting would make sense with the car thinking that the bonnets still open. Ill have a look on there and let you know how I go . Thanks again.
Link to comment
I needed a replacement bonnet latch for similar reasons - sometimes the intermittent wipers didn't work and also the alarm would arm but then it would go off for no apparent reason (usually at 2 in the morning, which made both myself and my neighbour rather unhappy!). As a temporary measure I found that disconnecting the wiring (plug on driver's side of latch) seemed to stop the alarm going off - perhaps when it's armed it finds there's no signal to the bonnet sensor so disregards it - so you may want to try disconnecting the plug and seeing if it has any effect on setting your alarm.
Link to comment
  • 2 years later...
I had this happen tonight; alarm kept going off, intermittent wipers didn't work, indicators didn't flash when locking. I unplugged the bonnet sensor and the wipers started working and the indicators flashed when locked. The alarm hasn't gone off yet...
Any ideas about fixing the sensor?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
