• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
1.4 TDI Fabia estate -timing belt
Sign in to follow this
Followers 0
6 posts in this topic
Hi All,
Hope you don't mind lending a thought or two. I'm considering this car:
http://www.autotrader.co.uk/classified/advert/201152376287296
Been to see it and looks tidy enough. Main concern is the timing belt - none of the service history suggests it's been done ever. It's got 80,000 miles on the clock. The service book suggest the timing belt (or "toothed belt" as it says) should be done at 100,000 miles - but that doesn't seem right. I know the 1.9TDI is 60K/4 years. Any one know for sure what it is on this engine?
Other points: clutch had a high biting point, brake pedal had fair bit of travel, uneven wear on the front brake pads (one looked close to needing replacement).
Cheers,
Matt Edited by mattiker
Share this post
Link to post
Share on other sites
My view on this topic is look around all the Skoda garages for the car you seek just as then I got given a 6month warranty so i have had plenty of work done on the car all for free so just consider this maybe?
Share this post
Link to post
Thanks, but on my budget there is nothing in the Skoda garages.
Does any one have the figures for timing belt renewal on this 1.4 TDI engine?
Cheers,
Matt
Share this post
Link to post
You certainly seem to have had a thorough look at the car, so the advice I'd give would depend a lot on how long you plan to keep the car for.
On the 1.9s, the interval is either 60k / 4 years, or 72k / 4 years depending when the car was built. Having said this, my service booklet says check at 80k and replace at 100k IIRC, so if the car hadn't been serviced at a dealer, the TSB that highlighted the change won't have been read or actioned.
But the fact the cambelt may be overdue isn't necessarily cause for concern in itself, in the same way as keeping the oil or coolant in for too long would be. Even if it HAS been done at 60k / 4 years, you'd need a new one in 18-24 months or 40k, so if the car's a keeper, you might want to consider putting the money aside to get it done as soon as you've bought it anyway, and then you can run the car for at least 60k / 4 years without worry.
Share this post
Link to post
Looks nice. Belt doesn't matter until it jumps a cog or breaks, so just get the belt done immediately and no problem (about £300)
Our hatchback - same age - has 135K and is a great machine. Many Fabia clutches seem high compared to other cars so this by itself isn't a worry. New pads (and maybe discs if it has been stood and they've corroded) easy and fairly cheap DIY. Change the brake fluid - you'll be amazed what horrible stuff comes out! Best of luck.
Share this post
Link to post
My 1.4TDi hatch is 4yrs/63k - I got mine done last year by the local Skoda dealer with an MOT and it came out around £400 for the lot, so likely not a dealbreaker and if you do buy and shell out to get it done you'll have peace of mind that it's really been done and will give you no trouble for the next few years.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
