Cruise Control
Hi, can anyone tell me why the cruise control accessory BEA600002A cannot be fitted on post 2010 built Yeti.
As the control stalk on before 2010 where separate unit, while the current one is a combined unit also the connectors and the controller are now buil in the slip ring itself, the current stalk and slip ring are not compatible with old cruise control module.
-Pramod
Hi, Pramod thanks for the info will have to make do without it.
I have had cruise control fitted to a facelift Octavia II. There are 3 different steering column electronic control modules (ECM) and 6 different combi switch options so it isn't as straightforward as pre-FL models. The combined stalk costs a fair bit more than the single stalk option and, if you need to replace the ECM as well, I would guess that the overall cost would be way over £300. I was lucky in that my car's steering ECM supported cruise.
