KU57 MLZ - Injector issues I think, No fault codes. Misfire/hesitation and Intermittent smoke. (Pic Heavy)
Recommended Posts
Ill add all of the images again here to keep the thread in line...
Link to comment
Share on other sites
Also, just a quick thought. What boost pressure should the car be requesting if it has been remapped?
Mine is asking for 2500mBar, so minus atmospheric pressure actually 1.5bar. That's 21.7psi which is an awful lot! My old Audi S4 only used to pull about 18psi!!
Can anyone have a look themselves and compare to my log on the previous page?
In VCDS I see my boost hit 2606 IIRC....
Different engine slightly of course.
Link to comment
Thank you! So map is requesting the correct boost then. :)
What next to try... I'm sort of stumped here.
Link to comment
Yea, and as you can see injector 3 is almost getting out of spec (values of way over 2.00)...so wonder if you have a knackered injector?
You could swap injectors and see if the fault moves with it....or borrow another known working injector to test with....
"Usually when the correction factor gets over =/- 1.0 mg/stroke you start to notice operational issues."
Edited by Plantman
Link to comment
https://sites.google.com/site/1810martin/vcds-and-pd-tdi-engine-health-check
All 4 injectors should have similar figures as close to zero as possible.
E.g.
13, 1, Injection Quantity, Deviation Cyl. 1.  -0.28 mg/str
13, 2, Injection Quantity, Deviation Cyl. 2.  -0.49 mg/str
13, 3, Injection Quantity, Deviation Cyl. 3.  0.56 mg/str
13, 4, Injection Quantity, Deviation Cyl. 4.  0.21 mg/str
If one injector is well out of specification compared to the others it could be faulty or it could be a faulty cam lobe.
If all figures are all over the place it suggests worn camshafts.
It is hard to tell if an injector oddity is due to an injector fault or a camshaft fault.
Apparent multiple injector faults are usually worn camshafts.
Edited by Plantman
Link to comment
Thanks Plantman! I've read that page. Quite a lot of information there, even if it is for passats its still relevant. Read the ECU remap stuff too, it taught me a bit.
Cam problem then it looks like on that diagnosis. Only thing that goes against that is the fact it comes and goes. Surely a worn cam would be a constant?
Link to comment
And it does come and go. You can watch the measuring blocks, and cylinder three go out to +2 - +3 itll start rocking and missing for maybe 5-10 seconds, and then it'll come right back inline with all values +/- 0.3 for 5-10 seconds...
Link to comment
Sorry I didn't see this post. I have 3 spare injectors that came with the car. I have swapped one already, and it got slightly better, but overall no difference.
Link to comment
So the values were the same on that injector when replaced? Least that eliminates an injector fault I guess. Odd you had them come with the car. Guess the previous owner was trying to sort this issue too?
Injector seals shot?
Injector loom ok? Think this was mentioned already. Being bathed in oil they can soon produce faults, 'miss fires' and the like.  <---- Edit, just re-read you have already had that replaced!
Edited by Plantman
Link to comment
Does anyone know - Isn't cylinder 3 used in line with the Crank sensor? I've read it somewhere but can't find the page now.
http://www.volkspage.net/technik/ssp/ssp/SSP_316.pdf
that the one on page 20?
http://www.fixya.com/cars/t6734476-crank_sensor
http://wiki.ross-tech.com/wiki/index.php/16706/P0322/000802
Edited by Plantman
Link to comment
A few possibilities could be, injector loom, injector, crank sensor.
I had one the other day, intermitant non start, until complete failure. Broken crank sensor wire and faulty injector loom.
Crank sensor pain to fit, so check wiring first.
Link to comment
Injector loom ok? This this was mentioned already. Being bathed in oil they can soon produce faults, 'miss fires' and the like.
Yes the values where the same or very similar. Only difference being that it seemed a bit better. Look at the pics above, the injector I removed had a couple of nicks in the injector seal. The one I replaced it with had perfect seals, but I had to reuse the clamp bolts which are stretch (use once) bolts.
One of the bolts on cylinder 4 is rounded off which tells me the bolts have been used and reused a few times.
I have a full set of injector seals and bolts that will be fitted this weekend. I will adjust Torsion to +0.5, and re adjust rocker clearance with new plungers too, as well as making sure injectors are seated correctly without damaging seals.
I have a receipt for injector loom from September that came with the car, and has done barely 1000 miles since, however, the wires look hard and brittle, which makes  me think it wasn't fitted and was possibly returned. I will be checking resistance of wires back to ECU as I now have a pin out.
Link to comment
Hi, thanks for the reply.
Did it flag a code on VCDS/Vagcom?
And did you remove the box to change the sensor ring too, or just the external sensor in the bell housing?
Link to comment
No fault logged for crank initially, only after disturbing the wires to test did it log on diagnstics as signal fault.
Sensor was not faulty, sensor ring was not faulty
Link to comment
Sorry so what part of it was? What was replaced?
Thanks again.
Link to comment
Been through VCDS and the measuring blocks to make sure all sensors are reading correctly (e.g. at ambient when car is cold)?
Tried unplugging say coolant sensor and the fuel temp sensors to see if behaviour improves?
Link to comment
I know, if it wasn't for it being a different vehicle I would have thought I bought that car! My Flywheel and clutch have just been changed too! haha.
I've read that, and it was never updated to show the result :(
I've spent days scouring the net and nothing is conclusive. Only thing I keep coming back to is Crank sensor.
Do you know if the 2.0 TDI can be compression tested as glow plugs are inside head?
Link to comment
Don't know the answer to that one sorry. Poss not it seems when you check the web internet....
http://www.volkswagenforum.co.uk/f33/2005-golf-gt-tdi-misfire-problem-11501.html  <- post #6
http://www.myturbodiesel.com/threads/vw-audi-2-0l-tdi-bmn-bkd-engine-misfire-judder-fix.4728/  <- post 10
Link to comment
http://forums.tdiclub.com/showthread.php?t=331796 - BKD engine wont start after injectors swap >I know yours isn't a BKD <
PS: I would try posting on this forum above. The chaps across the pond are very good at the derv tech.
And......also try a post here too, if you have not already:
http://www.audi-sport.net/vb/forum.php
Edited by Plantman
Link to comment
Wow, nice links thanks again for your help.
Here's the pic of the injector hole with a damaged seat from the first link you supplied -
And here is the best PIC I've got of the suspect cylinder on mine -
Edited by amk2vr6
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
