Recommended Posts
Stumbled across this thread for people like me who are trying to code xenons without shutters on there early Octy buy have not got long code helper option byte 3 bit 4
http://forums.vwvortex.com/showthread.php?3986819-HELP-Xenon-without-shutters-option-not-available-in-VagCom/page2
basicly in simple terms what it is saying is disable cold lamp diagnostic then go to byte 3
Go to 3) which has all the boxes with 2 digit numbers init and the 4th box from the left will have a 2 digit number init (will differ from what options you have ticket atm)
And add 10 onto that number
So for example if the number there is 21' then +10 and write 31 and then check if the car accepts the coding
I will be trying this tommorow and keep you informed wish me luck
Edited by DanialA11
Link to comment
Share on other sites
Ok slight problem I fitted a non canbus dc 35w kit
defiantly was a non canbus kit as the ballast only had one black block where as I been told canbus have 2
So once fitted turned ignition on but there was no bulb error light started engine still no bulb error
So I still went along and installed the xenons and also turned cold lamp diagnostic off and on byte 3 I added 10 onto the hex
Think I'll be ok ?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
