Air con
Recommended Posts
My air con works and chills the air. I don't know wheteher it works as well as it should though.
I have service history with the car, but there is no mention of any re-gassing or any other work being carried out on the air con.
So two things really, is there a temperature that the system should drop the temperature to? Or, is there a margin from ambient that it should reduce by?
Thanks fellas.
Link to comment
Share on other sites
It could just be low on gas. I had mine regassed last year and it has had no problem keeping me cool in the recent hot weather. I haven't measured any temperaures but then I've not had the need to. I set it at about 18-19ºc which is fine, any lower and it just gets too cold. In warmer weather it helps to use the AC with re-circ mode on to cool the car down quicker and reduce the load on the evaporator.
Edited by Dazza95
Link to comment
^ Agree with the above.  Both Fabias I have had need a regas every two years.  Neither have ever been flagged for leaks either despite paying for tests so I would say if it gets cold, but not cold enough, re-gas it.
Other common problem is the evap sensor goes but you wouldn't get cold air and a fault code would be logged.
Link to comment
Thanks fellas.
Like I said, it gets cold but I don't know if it's as cold as it should be. I'm in Spain, so it might struggle a bit and having knowledge of what temperature drop (in specific terms) I could expect would be better than my - it feels like - test.
I will have a look at the local "Halfrauds" and see what they can offer
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
