Everything posted by vRSG60
- Amundsen update
Amundsen update
For CarPlay! The patch is free for the clock fix. Please read the posts correctly ! To add CarPlay it costs around £80 unless you know better, then enlighten me please.
Amundsen update
The patch is for CarPlay If I do the clock update it wipes out the CarPlay patch so I’d need to reinstall the patch for CarPlay. Another £80 Not worth it just for a clock error when the clock on the dash works perfectly.
- Amundsen update
Amundsen update
OK I’ve had my Amundsen update to CarPlay If I update the unit to rectify the clock problem will I lose CarPlay? CarPlay wasn’t added by Skoda
- Adblue filling
- Adblue filling
Adblue filling
There's obviously a problem somewhere. Either fill level sensor or something else. Thae car doesn't know the fill level. And yes I do go through the sequence after a fill. If I put much more in it'll overflow. I've tried with the level just below the fill tube and half way up the fill tube. Light stays on, goes off around 4 days later only to come on again 4 weeks after that with barely any AdBlue used.
- Adblue filling
- Adblue filling
- Adblue filling
Adblue filling
Adblue light comes on every month now. Reading reports about overfilling I'm cautious when adding more. What level constitutes too much? I can see the adblue level when shining a torch down the filler neck. It looks about 1" below the bottom of the filler neck. I've seen comments saying "I just added it until it was just below the filler" Is that the full height including the neck? That surely is to much! It looks to me as though my tank is nearly full. The sequence to turn off the AdBlue warning never works, I add AdBlue then it goes off about 3-4 days later, for a month! I'm beginning to think the problem is a NOX sensor. I don't have the AdBlue fill level on my MFD
No Cruise Control
AGM https://www.gsfcarparts.com/products/096-9000-series-agm-start-stop-plus-battery-4-year-warranty-ybx9000-agm-start-stop-plus-batteries-4-year-warranty-za042696
No Cruise Control
New battery, a Yuasa, from GSF, should have been £188, not bad I thought. Got it for £133 when I went to pick it up 🤗 Offset the £50 the local guy charged me for coding it 🤬
No Cruise Control
Thanks, yes battery is on the way out. I’ll invest in a new one. is all the new batteries need coding strictly necessary?
No Cruise Control
Strange one this morning. Cruise Control not working. Now I know my battery isn't the best & it's -5° c, the car does take a bit to start on such a morning. I've not had chance to turn off and leave it for a while then check if it's working but I assume the 2 are linked? I think this is also why my rado clock always say 12:00 Lack of crank power may have broken something. And no, the switch isn't set to off.
Dash and radio clock are different times
I don't think the dash clock is linked to the radio. The radio gets the time from the radio signal.
Insurance cost
Insurance is a legal requirement yet the Government still taxes it. Rip Off Britain!
Leaking Panoramic Roof - The Cause and the Cure
The ingress in mine is minimal & sporadic, annoying non the less. I place super super absorbant towels (nappies I think) under the mats & dry them out every so often. They get more damp than wet.
My thoughts are that it's only opening panoramic sunroofs that fail, not static panoramic roofs. They don't have the same joints. Or are all the references above to other VAG car with "panoramic" roofs refering to opening sunroof type?
Wireless CarPlay adaptor
I have wired Carplay.
- Wireless CarPlay adaptor
Has anyone tried one of these (or similar) wireless CarPlay adaptors?
Upgrades for a 2017 4x4 TDi - what else have you done to yours ?
I've done the same. Yellow front fog bulbs, not for everyone, but I like them which is all that matters. 😇
Adding SmartLink on Bolero (late model Yeti)?
£80 for me , activated by a guy on FaceBook. Yorkshire VWAG Retrofits & Solutions. Amundsen unit though.
