Warkman
Everything posted by Warkman
  1. I went a different route, as I find the tv tuners fitted on most xars are not very good. instead I download the programmes I want to watch onto an SSD drive and play that instead.
  2. I’ve got the 2021 SEL and that does have the animation
  3. Have you tried holding the mem button down and whilst pressing down, press the number button?
  4. Nah, I too have the 70 SEL estate but 150ps DSG. ITs no longer than our Discovery 😃
  5. Why would you want to turn them off? They are a safety feature that allows you to be seen more clearly. by turning them off, you are not being safe. Next yiu won’t want the seatbelt!
  6. Download the manual here https://manual.skoda-auto.com/210/en-gb/Detail?model=Superb_3V&edition=11-2020&market=&manualLang=en then go to the bolero section, it tells you all the parameters for music and video
  7. I’ve gone with an USB ssd external drive and it plays both mp3 and video files to the Amudsen, it’s plugged into the centre cubby box https://www.amazon.co.uk/gp/product/B087DF38J9/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
  8. I have the 2021 MY SEL. 1) there is no CD player, nor SD card slots in the glovebox it’s been replaced with a hard drive nav system, updated over the air 2) the removable torch in the boot has also gone and 3) the washer bottle cap is now a standard type of cap, not the fancy funnel. added are a micro usb c in the front of the gear lever, this is like the cigarette lighter socket with it, permanently on, and a standard usb in the centre cubby box there is also a cigarette lighter socket in the rear passenger centre box and in the boot
  9. I have the same car, in estate version. Love it. can’t say I’ve noticed loud road noise just turn the radio up
  10. Yes, seperate keys can have seperate Seat profiles. Make sure you don’t have the two keys together in the car. There is also a change on 2021 MY cars tgat to set the seat, instead of pressing the set and 1, 2 or 3 at the same time, now it’s pres the set button, let go and press eitger 1 2 or 3 within 10 seconds, yiu will then get a chine to tell you it’s set
  11. I might be missing something, hope someone knows. when I get in and start the car, (Superb estate 2021 my) the phone connects. however, if the phone connects and emails/text messages come in, the radio mutes and I can’t seem to be able to get the radio sound vack on apart from swiping the unit off and on again. when I check the sounds menu, it says this will be available once the call has ended? very strange, tried everything to get the music back on, only turning the unit off sorts it. Am I missing something? thanks in advance
  12. Jyst be glad you don’t have a BMW, the doors stick fart in low temps, you can’t get in lol
  13. I have a 2021 Superb with Amudsen IFE, and a S20 Uktra. connects fine to both wireless android auto and plugged in. im assuming it’s the same software?
  14. As you might know, I had a problem coding the DRL with stripes on obd11. It caused an error with the rear fog lamps, so I reverted it to original. well, had a phone call from my Skoda dealership today, it seems that the car had contacted the dealership to notify them of an amber error code.Lol tokd them it was all five (which it us now) so, 2021MY and I’m sure previous models call home if you abuse them lol 😂
  15. I have the exact same car. Using obd11. I have enable the pukding start button, the throttle pedal response You can enable or change Scandinavian always on rear DRLs, Comfort turn signal Central lock with pressing ignition Lock/unlock audio sound What you can’t do, us enable traffic sign recognition in the binnacle, as tgat needs a SWaP file and DRL stripes as this throws up error signals for rear fog lights
  16. I have a 21MY SEL, you can enable traffic sign recognition in the Nav, done from centre screen, but, has been said by others, to get it in the binnacle, you need a SWaP file change, which only Skoda dealers can do as far as I can see.
  17. Yes, it’s not a plate. If you listen, you can hear the unit whirring when using the sat nav etc. plug yiur SD card through a reader and use the socket in the glovebox
  18. Funnily enough, mine was fine until yesterday, now mine is also saying “not activated” could it be a Skoda server error? Or an update that has screwed it up?
  19. I use a set of Thule aero bars and different feet for different. Are, all use the same length of aero bar. The way they are designed they slide on the feet to centre on the car
  20. My Samsung s20 ultra in its case fits fine
  21. It does say used SD or usb. Perhaps a usb can be used?
  22. You should be able to. go to Thule website and you can see which is required for each midel
  23. Right. looks like I was blaming the Scandinavian DRL one touch application wrongly. still had the rear fog light error even after uninstalling the scandinaviannDRl app. so, I then removed 1) DRL with sripes 2) coming home lights via fog 3)DRL settings in head unit And surprise, the error has gone away. so now to find out which of the three is causing the rear fog light errors
  24. I will have another look, I didn’t see tgat view in eitger iOS or android.. I will link to the car and see if that changes it thanks
