Orchid70
Everything posted by Orchid70
  1. The rear boot is shown closed...... This is making me MAD!
  2. Me neigther =) Ill try to contact him/her and ask. The caar owner is picking up her car soon, so I will have try tyo figure this out later, anyhow. Thanks for you ideas!! Always nicer when you are not alone in, trying to resolve things =)
  3. No - checked the coding too - its correct at 00034: I dont know if this looks correct - Long coding for Central Electric module:
  4. Question 1: In module 09 Shoud I test in Module 16 also? Question 2: I do not know. Battery is not a original. Thank you!!
  5. Checked out the measuring blocks.... This is really strange. There is still no fault codes - but I can see in the measuring blocks that the lever i operated.... but the rear wiper motor nor washer operates - only when I operate it with VCDS. Yes, I mean the unit under the steering wheel.
  6. Hi I have changed the motor because the arm had lost its attachment to the motor. I can activate the washer and motor with VCDS. Not with the lever/switch. No fault codes. Took out the switch but couldnt see anything wrong in the board on it. Opened the Onboard power supply control unit when I had it in my hand - nothing obviously wrong there either. My question is - other people out there who have had same problem and solved it? The switch is very simple, so wonder what could go wrong with it?
  7. Can you operate it with VCDS? If yes - then you have same issue as I do - dont know if its the lever itself or the Onboard Power Supply Control Unit (under the steering wheel).
