Everything posted by staituk
Repeated daily Infotainment update issues
my shop has when missing since the new update
- Shop section in infotainment menu issue
Dashcam / rear wiper fuse keeps blowing
great, thanks for your help
so i could just put the piggyback in to 48 with just the 2 Amp?
Hi, thats great, thanks, yeah i think i had them the wrong way, had the 2 amp closest to the fuse box
Hi, i am needing some help, I hard wired my dashcam in to fuse 47, in my 23plate superb. But what i am finding it that when the rear wiper is on about 5 mins later it is blowing the 2amp fuse.. I read that on the piggyback that the original fuse goes at the bottom and the 2 amp one on the top. And there is a correct way to have the piggyback as and to make sure the the piggyback is the right way up. Positive and negative. Just wondering if anyone has had the issue of a fuse keep going, as it did not do this in my last superb. . Would be great if someone could post a photo of the orientation of how you have it. Thanks.
door exit lights
i have had a quick look in to this, and it seams that SE-L and up from the last half of 2024 have the Additional LED warning light (door area) in front and rear, but up to then you get reflectors unless you have an SE-L Exec, or a L&K
door exit lights
hi all doors have the light in, so i might just be a case of them not having a bulb? will check to see if the wiring is there
door exit lights
hi, i have just noticed the lights at the bottom of my doors are not working, i boiught the car from a dealship it is a 23 plate petrol auto, SE-L, so i am assuming they should work, so i am assming there is a fuse issue or a setting issue, or all four dont have bulbs, anyone any ideas why they are Not working, thanks
Wind deflector recommendations
Nice :-)
hi i am looking to get some Wind deflector, is there brands that people recommend, thanks
Map update help
yeah i only have USB Ports
Map update help
ah ok, thanks
Map update help
Hi, i am after some help, i am trying to update the maps on my car, the map version is 21.7, i when to the update portal, entered my VIn, i downloaded OI_P154_EU_202534_Offline_Update and extracted the zip file as per instructions formatted the USB C drive to Exfat , copied the folders across,. put the USB c Drive in to the front port where the lighter socket is and nothing. what am i doing wrong/ missing. thanks
Software update.
Software update.
Hi, my car says the the current soft Version is M013_EU_skmQB_P33000P, to can i find out if it is the latest. thanks
thinking of changing models, after views
yeah think i am just going to stick with my 2L Diesel
yeah i have had a look at this and the hatchback IV boot space is only 480, which is much smaller than my 660, so dont think i am going to get one
i am thinking of changing my 2019 Skoda Superb 2.0 TDI SE L Executive Estate 5dr Diesel DSG for a 2021 Skoda Superb 1.4 TSI iV 13kWh SE L Hatchback 5dr Petrol Plug-in Hybrid DSG as i am coming to the end of my PCP., i am just wondering what are people views/experences with the 1.4IV, would i see much difference in fuel economy, and all that. thanks
Tracking & alignment
i have had the same issue, thought my rear wheels needed balanced, as was getting vibration for a few weeks , then the was pressure loss so thought i had a puncture, when to get it sorted and ended up getting two new tyres, as the photo shows the result of why, was told i need to get rear wheels tracked. which i have to done, would the tracked cause the issue of the photo, also has the rear springs replace by skoda in Jan 2023 by a skoda dealership and one went bang, these are the same tyres that was on at the time, but nothing was said when the MOT was one in July Skoda Superb 2.0 TDI SE L Executive Estate 5dr Diesel DSG Euro 6 (s/s) (150 ps)
Timing belt
Thanks all sorted the dealership I got it from paid for it as only had the car 6 week's
Timing belt
hi, i called the parts dept, they said the kit is £201, so will just get it done makes sense 🙂
Timing belt
sorry it is a SKODA Superb 2.0 TDI SE L Executive DSG
Timing belt
HI i had to call skoda roadside assist the other day as my 19 plate superb was overheating, the guy said it needed a new water pump and took the car to the local dealership. i called today and asked if the timing belt will be changed, and they said that they are still wating for authorisation to change the pump under warranty and when that get it they will call me and ask if i want the belt changed and all i will have to pay for is the kit and not the labour as that will be cover by the warranty for changing the pump. i was under the impressing that if changing the pump you have to change the belt as they cant be retentioned, is this correct, should they replace it as part of the course? thank
