Gt4thomas
Everything posted by Gt4thomas
  1. Check the glow plug fuse on top on the battery, they break. Check the timing if you have access to VCDS program. Engine won't run if the timing isn't spot on. Found that out when i did my cambelt.
  2. Replaced drivers side motor unit, window worked for about 1 minute then stopped. Im pretty sure water getting into to drivers side door sill. Both rubber door seals on the drivers side are wet. I think water is getting into the channel where the wires really run inside the sill.
  3. Battery is new. Ill check fuse 11 tomorrow morning
  4. Both front left and front electric windows stopped working the other day. Both fuses are good. Theres 9v at the fuses with acc on. Driver's side and passenger side switches do nothing, no relay clicking sound. Voltage at the fuse does not change when a switch is pressed. Is there another control module to test?. Seems a odd both window motors would go at the same time. Any advice is appreciated.
