Everything posted by Andacami
Skoda Superb Elegance boot accessories, boot rail hooks, divider, flexible strap and pollen filter
I have some boot accessories and a filter from my old Superb Elegance as follows. All prices are for collection from EN5 3EA and are cash or PayPal (buyer pays any associated fees such as G&S). The smaller items I can, of course, post at cost.Boot rail expandable aluminium divider (4F9860204) has some paint on it but perfectly serviceable x 1 - £25.00 Boot rail expandable securing strap (4F9860378H) in good used order x 1 - £40.00 SOLD Boot rail tie-down hooks (4F9863539) in good used order x 4 - £25.00 Internal pollen filter for Elegance, new sealed x 1 - £5.00 Happy to do a deal on all of them, say £80.00 £60.00 OVNO
Superb Estate Aluminium boot divider
Skoda Superb Estate boot divider. Fits into the sliding rails and is extendable in length. It has some white paint on it, so a bit untidy. However, it functions perfectly well. Collection from EN5 3EA or I can deliver locally. Cash on collection or PayPal (buyer pays fees).
New owner, personalisation questions....
1) once you have the car set-up for "your" key, don't you have to hold down the unlock button whilst out of the ignition barrel until a couple of blips/flashes to set things to the key? Repeat with the other users key... 2) not all of them do, I "think" this needs a specific type of mirror and maybe the folding type 3) interesting that stuff still remains that have been "deleted", perhaps these are key specific (kinda makes sense). I would think the answer may lie in 1) i.e. locking the individual drivers profiles to their key... This of course is based on my experience of me setting up my 2nd hand MK3 where I did the same, others with way more knowledge will no doubt be along to correct/advise as necessary...
Hunter alignment code needed please
Hi, A little help please, 2018 vRS TDI DSG with sports suspension. Local place want to know what suspension setup code to use for tracking/alignment as there are a few apparently. I've asked my dealer twice, nothing yet. Is there an easy way to find out? There is no sticker in the boot and no physical book. I do have reg and VIN... Thank you.
- Space saver spare wheel 125/90 R15
Beeping sound
Winter tyres speed setting? As others have said, it's an unusual Skoda sound and no visible warnings either is odd.
- Hi!
Mudflaps for FL vRS Estate
Chrome be gone!!
@mattft86 are these replacement bits or painted/PlastDip'd?
Where has my front VRS Emblem gone?!
For the best quality replacement, try Superskoda: http://www.kopacek.com/OCTAVIA-III/ I believe they are a bit of a faff to fit but doable with patience.
Throttle Response Change Using VCDS
Which box please and can it be easily removed? Thx
DSG auto gearbox, no creeping forward, is there something wrong with it?
Thanks, I will mention it to the dealer at the next opportunity. They have already put a few things right for me and have been good as gold so far. It's a new to me 2018 car, I got it in December 2022. Dealer is Citygate, Bushy, Watford.
I have noticed with my 2018 vRS TDI Auto, that there is no fwd creep too; more lurch! It's very annoying when other autos and torquey manuals you could creep on the brake. I do feel it is worse with a cold car/engine, less of a problem, less of a lurch forward when warmed up. I will get used to it I'm sure but the car WILL LURCH forward with the slightest touch of the accelerator or release of the footbrake when auto-hold/hill-hold disengages - not so much in reverse as others have said; it makes parking very nerve wracking! Judicious use of the handbrake might be the answer...
Boot open warning randomly comes on
Seems to be a common problem with the boot lights either in a failure of the holder or diode in the holder or by replacing with not so good quality LEDs. I'm not sure there is a setting to tell the car its LED and not Filament, I "think" the LED bulbs need to have the additional loading to act as filament so as not to confuse the system. I do not believe these lights are on CANBUS...? I have the same problem with a failed normal bulb and holder in the boot, disconnecting the holder cures my issue of alarm going off, hazards flashing and boot open warning.
HELP! Alarm is doing my head in....
👆This is the answer. The housing and the diode are at fault, even the bulb seems to be working fine.
Hazard lights blink when car is parked and closed
Dealer has now commented that it is a known problem for the light housing, not the bulb, to go faulty and cause these types of issues. A new one is on the way but for now I've just left it disconnected.
SOLVED: Flapping / rattling noise at high speed...!
Car up on ramps and three loose/sheared bolts holding the undertray in. Only obvious on ramps and needs force of air to move them. Problem now sorted 👍
I can't see or feel anything obvious. Have mentioned it to dealer and they will take a look tomorrow along with a few other small things under warranty.
No but problem is related as disconnecting the nearside boot light fixes the problem. Either the bulb, housing or diode is no good and therefore messing up the electrics. I'm hoping dealer will replace under warranty this week. I will report back to the couple of threads on here...
[HELP] MIB 2.5 Retrofit Attemp
- Hazard lights blink when car is parked and closed
Mine did this, it was the nearside boot light. Everything works fine when disconnected but when connected (it all works fine when unlocked) upon locking the car, the alarm will go off and the hazards flash, torch fin boot will flash and the Maxidot flashes the tailgate.- HELP! Alarm is doing my head in....
A bit of a resurrection I know, but useful to understand if a replacement unit fixed it or it was just left disconnected? I have exactly the same issue with the nearside boot light.- Help please! Tailgate warnings, torch flashing and alarm going off SOLVED
Solved! The chap from PF Jones is a clever bloke, he discovered that the nearside boot light was causing the issue. He disconnected it and everything now works just fine. During my own search just now, I found this which seems to be the same/related thing: So all is now well 😁- Help please! Tailgate warnings, torch flashing and alarm going off SOLVED
Just had a tow bar fitted by a professional (not dealer), all OEM wiring etc. Now when locking the car, the alarm goes off and/or the indicators flash rapidly. The Maxidot shows a rapidly flashing image of the tailgate, but not red as it does when the tailgate is open and the inbuilt torch flashes too. If we press the tailgate unlock button the alarm state goes off. If we rearm, it repeats above. Is there a sensor that is not working/disconnected? Is there an adjustment on the tailgate latch we could look at? Thanks- Bluetooth Issues
2018 MKIII Octy vRS. My S22 Ultra works just fine on BT and Android Auto, no difference in making connections to my old Note8 or my Sons iPhone. S22 Ultra SM-S908B/DS Android 13 patched 1st Dec 2022 Amundsen 5Q0035874C H41 MST2_EU_SK_ZR_P0471T 0471 Random thought... is it something to do with the "user" i.e. the key you have used is for person A so it's looking for person A's phone? - Hazard lights blink when car is parked and closed
