EnterName
Everything posted by EnterName
  1. Oh yeah, it's completely pointless and no doubt however carefully I do my calculations, like a school experiment, reality will intrude and the actual result will be different to the calculated result.
  2. Agreed. (Just re-read the second line in your post, and that is a factor I had tried to account for my using all DSG vehicles in my calculations, but it's a good point. Might explain the difference between the 150PS TDI & TSI numbers, though the weight is also likely a factor.) 👍 Also, even around these very close numbers, either side of 150MPH, replacing the 220PS with the 230PS figures changes the calculated top speed result for a 210PS car. Though there may be changes between the 220PS and 230PS vehicles which change the aerodynamics or weight of the vehicle slightly, changing the final top speed. Different tyres between the vehicles would also be a factor in the top speed. (If they were different.) And as @Roottoot just posted in his linked video, even different runs will yield different results. I'm just trying to extrapolate from the manufacturers figures for fun.
  3. I doubt your speedo was spot on at 150MPH, but you never know. The MK1 Octavia will have different aerodynamics again, not to mention the different weight of the car (which is also a significant factor between the MK2 and MK3, I believe.)
  4. Claimed top speed of my 190 is 147MPH, which I reckon is rounded one way or another. Here are the MKIII pre facelift numbers I have. (The additional accuracy is presumably because the original source was in KMH. So these may be more accurate than the MPH numbers quoted in the UK, and I may need to revisit my MPH figures for the FL *assuming* the original data was in KMH and there are rounding errors in the conversion to MPH for the UK. But I digress) So this is ideal. And the numbers look like this. On the pre-FL MKIII, 210PS should be enough to crack 150MPH. The formula I'm using is (Note that cell Q2 is Power 1 and cell Q6 is speed 2.)
  5. The pre FL model isn't a problem as the old 220PS MKIII was rated at an unlimited 154MPH, so could be used to accurately linearly interpolate. (Which I might do in a bit. How did you measure your 150MPH?) However the FL MkIII has different front end (as well as other things I expect), which I can't rely on not to have affected the aerodynamics, which will in turn affect the top speed, especially at those speeds.
  6. There *was* method in my madness. 😛 I was trying to determine what power is required for a FL MKIII Octavia to reach 150MPH. To do this, I was planning to use linear interpolation between an Octavia which does a little under 150, and one which does over 150. However the 155 speed is limited, which would make any calculation inaccurate. Hence the original question. I do not have any kind of reasonable explanation for why I wanted to know what power a FL MkIII needs to hit 150MPH, other than I didn't don't know.
  7. Thanks for the insider info. I suppose the supercars that are *not* restricted to 155 are so few in number, that restricting their speeds would not dramatically reduce accidents. Why 155 and not 150 though? Is it as simple as 250km/h is a nice round number?
  8. £280 including vat is a bargain, and the option I'd choose if and when Chris can get a kit from my 2019 Octavia.
  9. Looking at some other vRS top speeds, I'm not sure it's much of a discrepancy. The 220vRS max speed is quoted as 154MPH (pre FL model) with the 230vRS at 155MPH. I'm guessing the 245PS vRS true top speed is probably in the range 156-158. (It seems a bit pointless to limit it, unless there is legislation or a technical requirement to limit it it. After a quick online search it seems there are a few theories about the 155 limit. 1) The "It's my understanding that there was a gentleman's agreement..." theory, which sounds to me like an urban myth that gained traction. 2) The "It was to pacify the greens" theory, which doesn't ring quite true to me. 3) The "Things get really crazy after 155MPH and you need beefed-up car components" theory. This one sounds the most plausible to me.
  10. I like to fool around with data and produce graphs to see if anything interesting catches my eye, and I was doing this with some recent DSG Octavias. As you can see, there's a discrepancy for the 245PS vRS's top speed because of the 155MPH speed limiter. Does anyone know what the top speed of a 245PS vRS is *without* the speed limiter? Any guesses?
