Everything posted by Stewartasb
Roof trims.
Me again lol ok just a couple of quickies firstly how do I remove the roof trims the ones where you put the roof rack into the black plastic strips and secondly im still going to do the front wheel bearings but making sure I order the correct ones and the guy is asking if my car has servotronic steering is this a posh name for power steering or something else ???
Rear wheel bearing.
Got you found the correct kit now in case anyone does need to do one of these. https://www.ebay.co.uk/itm/Front-wheel-bearing-wheel-hub-removal-tool-kit-for-VAG-VW-Polo-Audi-A1-A2-72mm/203223418386?hash=item2f510f4612:g:zMwAAOSwhrRfydka
Rear wheel bearing.
Would this kit do the trick ??? https://www.ebay.co.uk/itm/23Pc-Front-Wheel-Drive-Bearing-Puller-Press-Removal-Installation-Tool-Kit-Set-PA/402588143765
Rear wheel bearing.
I know what you guys are saying but I just believe prevention is better than cure and also I have to do a 200 mile motorway journey 3 times a week for work so in my case its prudent to replace before a big issue arises and looking at videos the job in itself looks pretty straight forward the only issue I can see there being is obviously if the old bearings do not want to come off which is why I need to get the correct kit.
Rear wheel bearing.
Also bearing in mind that ive done all the rear suspension now and the front suspension the works why not just finish off with the new bearings I dont see how you can say its a bad thing to consider replacing bearing at 80k they do wear you know.
Rear wheel bearing.
Well thats your opinion wino but in my opinion why wait till it breaks on a major component ive done 80k and in my books its not for the sake of it its called preventative maintenance and forward thinking rather than the old let it go pop before I can be arsed to fix it.
Rear wheel bearing.
Ive done the backs now whats a gen 2 bearing tool kit there are different sizes need one to pull it off and the other to push it back in i dont know the correct size there are a few 72mm,76mm,82mm,88mm
Rear wheel bearing.
Just about to do my 2 rear bearings today then was thinking of doing my 2 fronts as they never been done does anyone remember the size puller kit I need to order to get these off please ???
Rear wheel bearing.
Yep I had same issue one was stuck solid had to borrow some tooling to get it off.
Condensation and mould!
Ahhhh cheers mate thats great to know i can get these thanks 👍
Is that part number correct TMB as im after a set of these as someone nicked mine lol but its not finding that part number.
Rear wheel bearing.
Lol I know he did thus why I said cheers at the beginning was just explaining 😀
Rear wheel bearing.
Cheers mate the nuts come with the kit I've ordered but I don't know what size spanner socket to buy to undo them lol even Hayes manual does not state the size 🙄
Rear wheel bearing.
I can see how to do them now thanks just one quick question whats the nut size please ???
Rear wheel bearing.
Hi all anyone ever changed one of these just had my mot and it passed but the rear bearing is getting a bit of noise and as ive changed all the rear suspension just thought I might as well, tackle this and do the other side as well any tips or advice please thankyou
Cooling fan sensor
Hi all I think my cooling fan sensor is faulty the Haynes manual stated it was top left of rad but mine is actually located near bottom of road in a pig of a place to get at. Any know how on best way to get at and change the offending item please my fans were working until a couple of days ago and it's been suggested this sensor is the likely suspect for them not working now any way to test please. As always thankyou in advance.
