FrankLK
Everything posted by FrankLK
  1. I would add: Memory of heated seats and steering wheel, air recirculation after restart of the car, start-stop deactivation.
  2. For you guys with RH drive, is your driving side wiper blade longer? I don't see a reason for a difference in blades itself, only where you will fit longer and where shorter blade.
  3. If you want other options:
  4. And which brand was it? OEM is not a brand, vw and skoda are not producing wipers, mine SWF first fitment lasted 2 years with no remark. In skoda dealerships they are selling rebagged wipers so maybe they are good, maybe rubbish. I didn't say buy OEM, I said buy SWF in car part shop if you want decent wipers, avoid being ripped off in dealerships.
  5. Does it also happens with kessy? I actually didn't try because normally the car doesn't lock if the key is in the car, something to test😁
  6. I buy SWF brand which was OEM on my 2018 octy, friends which tried say they are superior to Bosch. If anybody needs more info I think I have pics somewhere.
  7. Is it enough to upgrade only rear and leave front stock?
  8. Thanks, if it gets worse I will have to take it off and play with it.
  9. What is the price difference between OEM and aftermarket? What if you want to install a normal battery if SS system is not used? I really didn't know that battery needs coding.
  10. I think I have somethimes a buzz from that part, any idea what could it be and how to solve it?
  11. I have the fl version with rear multilink, so it has wider rear wheel track so the rear looks ok but the front looks too much in arches.But I wonder why skoda engineers made it like this?
  12. Conclusion yes or no? Because how much I get info, plus is only looks, handling can be only worse.
  13. FrankLK replied to vrskeith's topic in Skoda Enyaq
    I don't like the roundness of exterior.
  14. I have kessy and the battery was dead without warning from car, the car was daily driven, now I change battery every year to be safe.
  15. Why I have a feeling that TC doesn't do its job in first gear(plenty slip from zero) but kicks in a lot in second and third which is annoying sometimes. Does sport mode in a non-vrs does anything to TC or SC?
  16. FrankLK replied to vrskeith's topic in Skoda Enyaq
    Correct!
  17. FrankLK replied to vrskeith's topic in Skoda Enyaq
    This makes it clear, thanks. I'm waiting to see the VRS edition, I hope it will not be reserved for GT coupe version.
  18. FrankLK replied to vrskeith's topic in Skoda Enyaq
    But that's not true, city go was the first. Founders edition to me doesn't sound classy as it should be as the flag trim.
  19. FrankLK replied to vrskeith's topic in Skoda Enyaq
    What's with the founders edition logo? Does that mean Skoda is ditching L&K logo? Because they are the founders.
  20. Did you try to reset dsg yourself? Start ignition without pressing brake, so the engine doesn't start. Press fully throttle pedal for 20 sec Release pedal and start the engine.
  21. Plenty BS on this link, if your mirrors are noisy and not moving smoothly they are worn out, replaced my both motors under warranty after 2nd year and after one year already getting noisy.
  22. To compare, does your trunk stays locked after any door opens except driver door? Is there any setting in menu or possibility with coding to change this?
