haris
Everything posted by haris
  1. My car now has more hp and maybe I will increase more. Also if I can stop earlier, I feel safer. Last, for the look I didn't imagine that the extra weight will cause such big difference in ride quality Vrs models I suppose are OK. Is it because of stronger suspension? Something else?
  2. Hi, I think front brakes are 288mm. Can I install bigger brakes for example 340mm from vrs? Will this this be a straight swap? Also can I use brakes from different cars/models? Audi? Seat? Something else for 4pistons? I don't want strange modifications. I prefer something plug and play
  3. I don't think it will be 11mm. It will be 30mm !! Isnt there anyone who has 225/40/18 with et35 to see how it looks??
  4. Hi, I need real photos of your cars and a comment with the dimensions. I want to see how much out will be the wheel. Sorry for my english
  5. Hi everyone. I have a 1.4 140hp mk3 with stock suspension and height. I want to buy 18" wheels and I had in mind that 18x8 et 45 is good both for the car and look. Now I have 16" with et46 I found some wheels 18x8 ,et 35 and I think they will be ugly . I don't want the wheels going out too much . Are there any photos to see how it will look?? Please write down your wheel width and et
  6. Hi everyone. I have a 1.4 140hp with stock suspension and height. I want to buy 18" wheels and I had in mind that 18x8 et 45 is good both for the car and look. I found some wheels 18x8 ,et 35 and I think it will be ugly . I don't want the wheels going out too much . Are there any photos to see how it will look??
  7. Thanks guys.. According to this site, The outer rim will poke out 7-8mm more than before. compared to my 16" . https://www.willtheyfit.com/index.php?width=205&aspect=55&diameter=16&wheelwidth=6.5&offset=46&width2=225&aspect2=40&wheel_size=18&wheel_width=8&offset2=45 Is there any photo to see ?? One friend of mine , has 225/40/18 rs replica rims , 8" , 45 offset and seems nice. According to site the outer rim will poke 20mm more than the 16's"
  8. Hi, does anyone know how.many kilos is the alaris 18" without tyres? And approximately with tyres
  9. Thanks Is it a straight swap? Or needs coding ?
  10. Hi. I bought this Ls8012 model It's perfect € 18,69 25%OFF | 720P 170 Degree Fisheye Lens Car Rear View Trunk Handle Reverse Backup Camera For Skoda Fabia Octavia Yeti Roomster Audi A1 A3 https://a.aliexpress.com/_m07OUU1
  11. Can I replace this part myself? Is it easy or needs a technician? Does it need coding or something? Have we got any part number to check it on Ebay ..?
  12. My problem is that it doesnt lock when I lock with the remote the car. It always stays unlocked . Not always locked .
  13. Hi, I noticed that fuel door doesnt lock with the doors But I can open the door and close it as usual without any problem Can I do something to check/ fix it? Must I replace any part?
  14. Hi, can so.eone told us where to connect the wires inside the door panel ,of the red warning lights? Is there any way to connect them somewhere and work without coding? I suppose somewhere which is relevant with door lock
  15. I also just took a look at the wires between door and car. A strange hard plastic like obd Inside. I hope i didn't make any damage or cut any wire and it needs only the reset you told me
  16. Hi, I removed the driver's door panel and after putting everything in place , airbag error appeared on dashboard screen. I just pulled out and put in place the 2 big set of wires. For mirror and for windows
  17. πŸ˜„πŸ˜„πŸ˜„πŸ˜„yes and there is no option to correct it from mobile phone
  18. I didn't find anywhere a clipped one. Only this style with bolts for 92mm But if you see there are 2 small plastic latches left and right. Won't be enough you think?
  19. I took some photos of my button. It seems that camera from octavia a5, polo, audi A1 etc should be ok. My button has one big latch from one side to keep it steady € 19,79 19%OFF | 720P 170 Degree Fisheye Lens Car Rear View Trunk Handle Reverse Backup Camera For Skoda Fabia Octavia Yeti Roomster Audi A1 A3 https://a.aliexpress.com/_mMeydsj This camera from aliexpress also has 2 small latches and not only the two big screws like other cameras I think ls8012 model is the correct one. Sashagray please help me if you can...
  20. I saw some models 92mm but there also 2 styles of connector. Also they have 2 big screws I suppose i must check my button first from inside
  21. Well...I bought a reverse camera from aliexpress that was saying suitable for mk3 a7 and I did not measure before order. I tried to start the procedure today and I saw that my car's length of the trunk button is about 9 cm and 11cm the camera I bought. What is going on? Are there different trunk buttons between mk3 octavia models?
  22. Hi,did you have any problems so far? Have you got any link ? I suppose it's from aliexpress
  23. Hi, I have a 2014 model 1.4 140hp It has a varta silver dynamic 60ah battery and start stop stopped working. I think I need a new battery. My question is : if I buy the same exactly battery , can I replace it myself or it needs coding or any other tricks? I asked everywhere and the want 150-160 euros I found the same battery 115 euros.
