Everything posted by RCC49
Delivery/lead times
Thanks for replying. Helps with my thought processes.
Delivery/lead times
Does anyone have any idea what the lead time might currently be on a Sportline Edition 1.5tsi DSG?
Karoq front wipers rest positions
That's a tweak which is available in OBD Eleven.
- Blackvue dashcam GPS query
I have a Blackvue DR590X dashcam and I'd like to add a GPS receiver, which would fix to the top corner of the windscreen. The cable is 1 metre in length so would need to be tucked behind the trim above the windscreen. Has anyone done this and am I likely to have any difficulty? Thanks in anticipation.
Coding on s 2023 Sportline 1.5dsg
I made a few tweaks to mine using OBD 11, but I think the most useful one was permanently ebanling Headlamp Assist, rather than having to enable every time I started the car.
Air Bag warning light
Funnily enough, I've just had the same problem. It turned out to be a "false positive", so just needed a reset by the dealer, though would have been covered by warranty otherwise. They still had the car in all day though!
USB C, wireless charging, Android Auto
Pairing an iPhone with the phone via Bluetooth offers the option to use CarPlay if wireless CarPlay is available. Might be worth trying that to see what follows.
- New Karoq ordered
Carplay in Karoq
And if you're trying to connect to the car's wifi hotspot as well as CarPlay, you'd better hope you're not on iOS 16.x, because the chances are that CarPlay will connect but not wifi.
Light Assist Package
Headlight Assist is activated by pushing the headlight/indicator stalk forward until you feel a resistance (a dipped headlight symbol appears in the instrument display to show that it is activated). When the ignition is turned off, the the system is reset to off by default. It has to be activated every time the ignition is turned on. The OBD11 change means that the car will remember the last setting when the ignition is turned off, so I leave mine on permanently.
I would echo the positive views on here with regard to the Light Assist Package. They're just amazing and never had a problem. i also changed the setting with OBD11 so that it remembers the last setting rather than having to activate them every time the ignition is turned on.
Infotainment system 😱
Regarding the telephone volume, have you tried turning the volume knob on the infotainment system?
Amundsen Hotspot, CarPlay and iOS 16
I'm somewhat amazed that there have been no responses to this post, even if just to say that the same problem was being experienced. I became convinced that iOS 16 was responsible and that Apple had "broken" this facility when introducing that version. This belief only increased when reading on a variety of forums, including Apple's Community Forum, that other people with cars from other manufacturers were experiencing this same problem. In case it might be of use to anyone else, I've finally managed to get round this problem. I felt the only way would be to revert to a version of iOS 15, but that's not possible through official Apple channels. However, after much trawling, I found a guide to do this very thing. It took around 40 minutes in total to complete, and I'm now back on iOS 15.6. The result is exactly what I wanted, in that when I get into my car and start up, my phone automatically connects to CarPlay and the car's wifi hotspot, and all my cursing and swearing have disappeared. For anyone interested, this is the link to the guide:- https://www.iphonetricks.org/downgrade-ios-16-1-to-15-7-1-how-to-guide/ I was unable to get to iOS 15.7.1 because that version isn't available over air, but 15.6 is fine. It would be really nice if Apple would fix this problem in iOS 16 at some point, but I'm not holding my breath.
Daytime Running Lights with rear lights
Yes, I do.
I used OBDEleven to activate Scandinavian DRLs, and I can report that the headlights are not permanently on. They only come on when the ambient light level drops sufficiently.
I’ve been having a problem since updating my iPhone to iOS 16 and I wonder if anyone has had a similar experience, or even found a solution. To give some background, to provide WiFi in my car, I use a Huawei dongle with a Three data only Sim, which I replace when it’s expired, and which gives me 24gb for up to 24 months. I’ve used this in my previous cars, where I wasn’t using CarPlay because I couldn’t be doing with a wired connection, and this has worked perfectly. When I took delivery of my facelift Karoq, I decided to try the wireless CarPlay. In the WiFi settings of the Amundsen, I enabled the WiFi, which disables the built-in e-sim, and then selected my WiFi dongle from the list of external devices. To connect to CarPlay, I followed the correct route of first pairing the phone via Bluetooth and once it had connected, selecting “use CarPlay”. For the first 6 months or so, this worked perfectly. I would start the car and CarPlay would be activated in the car and my phone would connect to the hotspot (My Skoda nnnn) and I never had to give it a moment’s thought. Since updating to iOS 16 (and the subsequent minor updates), CarPlay starts up fine most of the time, although I get the occasional error message, but my phone stubbornly refuses to connect to WiFi. I can see the network Id of the Hotspot in the “My Networks” list on my phone, and I have to manually select it to connect to WiFi, although on the very odd occasion, it does connect automatically (I do have Auto-Join set on). Weirdly, if I select the “information” button next to the network name in “My Networks”, then select “Join this network”, the phone says it needs to disconnect from “My Skoda nnnn” (even though the phone is not yet connected to the Hotspot), then it reconnects but then says the password is incorrect. I type in the correct password, but it still says it is wrong. The only way of connecting is to go back and select the network from the “My Networks” list. I’ve also tried connecting my wife’s phone, also on iOS 16.1.1 and the same problem exists. Trying with an old iPhone 7, which is on iOS 14, there’s no problem. Apologies for this long-winded diatribe, but I’m intrigued to know if anyone has any wisdom to offer.
Advice requested re. symbol on infotainment system
Thank you. That makes sense, and ties in with my realisation after initially posting the question that it probably had nothing to do with Carplay/WLAN/Wifi.
Since I updated my iPhone to iOS 16, I have been having lots of problems with Carplay and WLAN/WiFi. I won't bother going into it all right now, but I wonder if anyone can explain the significance (or not) of the small "i" in the attached photo, between the globe and person.
Foot operated tailgate
I had difficulties when I first had mine. The key for me was when I realised that there's actually a time lag between kicking below the bumper and the boot opening, as opposed to an instantaneous response when pressing a button. Having cottoned on to this, I have 100% success.
Facelift model and Carista
Has anyone succeeded in carrying out any customisations to the facelift model using Carista? I was wondering if it's possible to set it to remember Auto Light Assist setting (to avoid having to push headlight stalk forward every time), set Scandinavian DRLs, and set lane change indicator to 4 repeats. Any info welcomed.
New Karoq USB C connection
Interesting. As I said, I use mine to power a wi-fi dongle and, on checking while driving, it's not at all warm to the touch.
You could try these:- https://www.amazon.co.uk/gp/product/B07M6413ZW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 plus these:- https://www.amazon.co.uk/gp/product/B00J4NMTMQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
There are these to:- https://www.amazon.co.uk/dp/B08HWKVHMK/ref=sspa_dk_detail_1?psc=1&pd_rd_i=B08HWKVHMK&pd_rd_w=9Xos8&content-id=amzn1.sym.1d17a7d9-68f2-46c6-a55b-f888c57f8c2e&pf_rd_p=1d17a7d9-68f2-46c6-a55b-f888c57f8c2e&pf_rd_r=GYX8KKGJV1JP7Z4WWX38&pd_rd_wg=aGflO&pd_rd_r=bfe31687-86ad-4317-b740-16774a4e701f&s=electronics&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFHVk9KQ0ZVOVE5QkcmZW5jcnlwdGVkSWQ9QTAxMTU0NzQxTzRUU0Y5TDFBRVhLJmVuY3J5cHRlZEFkSWQ9QTA3OTI0NTQzU1kyRDhNR1kyTzAxJndpZGdldE5hbWU9c3BfZGV0YWlsJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
You're right that it's only possible to use one at a time. I use the socket that's closer to the driver side for a permanent connecion to a wifi dongle, and I have cable stashed to plug into the vacant socket should I need to charge my phone, so it hasn't been a problem for me. I've never searched, but it would be interesting to see if there's a variation on the Amazon adapter with the USB-A socket rotated through 90 degrees which would then enable both USB-C sockets to be used.
