![](https://www.briskoda.net/forums/uploads/set_resources_23/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
Gerard2071
Finding my way-
Posts
45 -
Joined
Last visited
Content Type
Profiles
Forums
Gallery
Shop
Events
Downloads
Everything posted by Gerard2071
Fabia Mk2 vRS - General Rattles and Knocks !
Gerard2071 replied to Gerard2071's topic in Skoda Fabia Mk II (2007-2014)
Hi, thanks for your reply. My A/C doesn't work (compressor gubbed). Strangely enough with the recent cold snap, the noise hasn't been happening. This makes me think its a pipe underneath the car rattling when the car is hot. I haven't taken the covers off underneath to check fuel lines, etc for looseness...... maybe a good starting point. It does sound metallic, like I said, something like a heat shield. -
Hi, it rattles only in the 1800-2500 RPM range. Does it when driving mostly. Can get it to do it when stationary, but doesn't do it all the time. -
Happy New Year to you all !!! I own a Mk2 Fabia vRS, CAVE engine. For a few months now it has had a metallic rattle between 1800-2500 RPM. It sounds like a loose heat shield would if it vibrated against the body. I've had it up on a ramp. There are no loose heat shields or thin metal items anywhere. I mentioned it to my mechanic and he had a poke around and was unable to find anything loose either. I remember somewhere on the forum someone mentioned rattling from fuel pipes or similar. I can see that there are covers on the underside of the body which run the length. Would there be anything under them like pipes or heat shields? Any idea or similar solved issues? (if it helps any, I had the Mechatronics rebuilt in Dec, but the sound existed before and after that so I don't think they're connected). Also, I mentioned to my mechanic that there is a knocking at low speeds on ROS corner (as if a drop link had failed). He had a look and said that there are no rear drop links ! He suggested a "noisy shocker". Any ideas ??? Thanks in anticipation. Stay Safe
Fabia VRS Mk2 - CAVE issues and TSB's
Sittingbull, Sounds like you've been through the mill on your Fabia. I don't know what to suggest other than keep on keeping on......good luck ! -
Sittingbull, looks like I'm one of the lucky ones. I really hope you get sorted without too much more pain. Fingers crossed for you 🤞 -
Also, if anyone wants a VRS personalised plate, mines in the classified for £150 all in 👍 -
UPDATE To all the forum users, firstly a Happy New Year (Chinese) and Happy Burns Night (Scottish). Just a quick update on this thread.... After my initial panic and with the help of you all I can now confirm that the CAVE isn't an oil burner like I feared !!! I've done a few low-tech oil consumption tests and they all seem to indicate minimal oil consumption. I can live with the occasional small top up every 2k or so. So just to say thanks to all those who took the trouble to answer my posts. You're all very appreciated 😁 -
Fabia vRS MK2 compression test
Hi Kobayashi, Although I eventually intend a remap, at the moment I just need to sort the oil consumption issue and how good/bad the engine is. The compression test was one angle to try. As always, your reply and help is appreciated. -
Found this link to previous topic Only issue seems to be there's a fair amount of differing views in the responses. The consensus seems to be : test with plugs out. There a mention of throttle being open, removing fuse 30, etc ??? I'm guessing from reading this that there is no "exact" figure, but as long as the cylinders are more or less the same then that's fine...... -
Hi all, Looking to carry out a compression test on my mk2 Fabia as part of a range of tests to prove/disprove excessive oil consumption. Does anyone know what the average and optimum readings per cylinder are likely to be? Just need a benchmark for comparison. Many thanks as always......
Dipstick levels on mk2 VRS
Hi Madvlad65, Roottootemoot has previously stated to me that the oil needs to conform to VW502 standards. I think I remember he said 5w30 also, but maybe you should check direct with him. Failing that, I'm sure a Google search will find the correct oil grade, or some suppliers offer suggested oils based on your car details/reg. I would check the correct grade yourself, although I bought mine following a reg check on Euro Car Parts so ended up 5w40. Good luck.... -
Hi Oz Fabia, Thanks for the info. Once I've finished my "test" I will see where the oil level ends up and measure how much I have to top up. With any luck that should also give me an idea of the max/min difference. Thanks for your reply and help.... -
Roottootemoot, While I think of it.....a while back you advised me on the correct oil type saying it had to conform to VW 502 standard. I checked the Shell Helix I bought and it does comply. Thanks for the heads up and advice ! -
Hi Wino, I know it's not "high tech" but it should work.......and all it cost me was the oil and a 35p plastic jug from Asda !!! Cheaper than an official dealer test. The reason I asked for the full/empty capacity on dipstick is a mate with a 1.4 Tsi Golf said he thinks it's only 500-600ml. When you have 4 litres in to start, you can afford to lose the odd 500ml without an engine disaster..... That's my thinking anyway. Could be proved very wrong.......🙄 -
Hi Roottootemoot, Yeah, this was what kicked the whole oil consumption panic off in the first place......I'd done about 2k miles and saw that if used 2/3 of the engine oil. This was when I first came across the forum and the issues with the CAVE engine. Admittedly, my car was parked in different places in the work car park do the levels varied depending on the spot I parked. That's why I'm trying to park in the same spot through the testing. The master plan once the 2k test is done will be to drain oil, refill to exact capacity and repeat 2k test. Cheers again for taking the time to reply. -
Further to last.. I tend to park the car at work in the same spot and allow it to cool right down so all the oil drops back into the sump. Hopefully this keeps the level consistent and accurate. -
Hi Roottootemoot, Rightly or wrongly, I waited til the car was cold and dipped it. Filled it to top hatched line. Checked when hot and it was approx 2-3mm above top hatch. Wasn't much change over the first 700 miles. Dropped to top hatch at 1000 miles. Now at 1500 miles it's approx 1/2 way up the hatched area. I'm slightly less concerned about the oil consumption than when we first spoke, but still want to see the test through for a definitive answer. I'm being careful and won't let the level drop dangerously low just to see out the 2000 miles. I'm carrying a 1 litre oil just in case of emergencies..... Thanks for all your help and advice. -
Hi all, I'm currently running my "low tech" oil consumption test on the vRS. This will be done over 2000 measured miles with regular checks of the dipstick. I'm 1500 miles in so far. It will eventually be topped up in 100ml stages to allow me to calculate the total used. Dipped it the other day and it's half way down the hatched area when cold. Question.... Does anyone actually know the total quantity between the top (max) line and the bottom (min) line ? Thanks to all who have helped and supported me so far on the forum !
Jetex exhaust and air filter
Roottootemoot, As always, your wisdom is appreciated 👨🎓 Cheers- 4 replies
- 5j
- jetex exhaust
(and 2 more)
Tagged with:
Hi all, I'm looking for any advice on Jetex exhausts and performance air filters. I'm looking to treat my Mk2 VRS to a stainless system and performance air filter. Has anyone got any views, good or bad, on the Jetex systems? Would fitting these mean I would have to remap or would they be fine without? The exhaust is https://jetex.co.uk/product/skoda-fabia-5j-vrs-2010-10-half-system/ The air filter I'm looking at is the cone filter as that seems to be the only available option for my model from Jetex. Any advice is appreciated. Bear in mind I have a £500-£550 budget for the parts so I'm not looking for major mods or Stage 3 performance 😁 Cheers 👍
- 4 replies
- 5j
- jetex exhaust
(and 2 more)
Tagged with:
Edit to last sentence as my mobile decided to autocorrect and confused everything?!!! -
Hi Fitzwilliam, Thanks for your post. I'm keeping an eye on the oil. I'm the only driver of the car and commute 50 miles a day on A roads and twisties. I also have the occasional Motorway blast at weekends. I will continue my Low-Tech experiment, but will bear in mind your experience. Cheers. -
Roottootemoot, Thanks as always for your advice. I know the oil is Shell, can't remember if it's semi or full as I'm working away at the moment. Pretty sure I bought it from Eurocarparts, so would have read the tech spec to make sure it complied with manufacturer standards. Will check when I'm back. -
Roottootemoot, Let's hope the CAVE has been cured by some miracle, but I won't hold my breath.....still early days in the oil test. I haven't serviced it as yet and have only topped oil with Shell Helix Semi Sythn. Was running it on Asda standard unleaded, but have switched to Sainsbury Super Unleaded. Not sure paying for premium brands would make any real difference to a standard mapped car with 67k on clock TBH..... If I get through the test and the car seems miraculously cured I may treat it to a Jetex stainless system and a performance air filter. Maybe it will get a mild remap after that......got to drip feed the mods to stay under the Wife's radar 😉 Thanks for your posts. It is appreciated. -
Roottootemoot, Mickmartin, Thanks for your posts. I'm still monitoring my oil consumption myself to make sure it is sufficiently high to justify paying Skoda to do the "Official" oil consumption test. So far I haven't seen the dramatic drop I was expecting. When I first dipped it after 2k it was down two thirds. This time after a few hundred miles it hasn't moved. I will keep an eye up to 1k miles.....maybe a miracle has happened !!! All the best. I will update in due course.
