Andrei1496
Finding my way
Everything posted by Andrei1496
  1. Imagine the LED like a different module. Until you code the new RGB module, you won't be able to adjust the brightness. It must be assigned to a group. But most important is what OEM module or part it represents. Keep in mind that the module is from China, not OEM, so we are not sure if it's the correct group from LIN slaves. You must play with these, maybe you'll find the address. Ask someone who has the door handles with RGB lights to give you the AD Map: ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_x ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_x ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_x Is there any part number on the RGB module? Do you have a link from the seller or any instructions?
  2. @Honza179 sure. Keep in mind that the dashboard trims is different for cars newer than 2017. Mine is 2016 so here is the list of trims with ambient lighting that I've used: Dashboard: 3V1 858 415A NF8 3V1 858 418A NF8 Doors: 3V0 867 061 D RJ9 (Front Left) 3V0 867 062 D RJ9 (Front Right) 3V0 867 067 D RJ9 (Rear Left) 3V0 867 068 D RJ9 (Rear Right) NF8 (for dash trims) and RJ9 (for door trims) represents the color code. Even if the color is the same, the code is different. So make sure you order the correct color code. Use ETKA to get the correct one.
  3. As a solution for the problem on top, all I had to do was to change IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren from 0% to 100% Loosely translates to "door brightness when unlocked".
  4. As a solution for the problem on top, all I had to do was to change IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren from 0% to 100% Loosely translates to "door brightness when unlocked".
  5. Hello again, I got things done, all the ambient light strips are in place on the dash and on all 4 doors but I have a weird behavior. Everything works normal but when I go to the car and unlock it, without opening any door, only the dashboard ambient lights are turning on and the ones from the doors are turning on after opening one of the doors. I checked and there is constant 12V in them so what could be the problem? There might be a coding issue? I'll leave the AD MAPs here from 5F and 09. Please help, I have no other clue on what to do here, thanks in advance!😁 adpmap-5F.CSV adpmap-09.CSV
  6. Hello again, I got things done, all the ambient light strips are in place on the dash and on all 4 doors but I have a weird behavior. Everything works normal but when I go to the car and unlock it, without opening any door, only the dashboard ambient lights are turning on and the ones from the doors are turning on after opening one of the doors. I checked and there is constant 12V in them so what could be the problem? There might be a coding issue? I'll leave the AD MAPs here from 5F and 09. Please help, I have no other clue on what to do here, thanks in advance!😁 adpmap-5F.CSV adpmap-09.CSV
  7. @Dronzillla 1) You should check the logs with VCDS and see what's the problem or remove the door panel to check the wiring. 2) Yes, you can buy them individually. 3) Here are all the ambient light strips for all doors (these are for the brushed aluminum ones): - 3V0 867 061 D RJ9 - Front Left - 3V0 867 062 D RJ9 - Front Right - 3V0 867 067 D RJ9 - Rear Left - 3V0 867 068 D RJ9 - Rear Right As far as I know the "RJ9" part from the OEM code represents the color. You should check with ETKA what is yours, maybe you have the piano black version and so on.
  8. Hello, What's the correct selection for Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus from a factory fitted camera? Is it Databus Infotainment? I saw on some threads that they use Terminal 15. I have an OEM camera retrofitted and I want to know what to select in there. Thanks in advance!
  9. Hello, Does anyone know what are the pins in the Front Door modules for 12V+ and GND for the ambient lightning? Thanks in advance!
  10. Hello, Does anyone know what are the pins in the Front Door modules for 12V+ and GND for the ambient lightning? Thanks in advance!
  11. Hello there, I recently had a problem with the speakers on my Superb 3, Canton system. I took off the covers from all 4 doors and I've discovered that on the front doors the bass speakers were stuck and the mid-bass speakers on the rear doors were stuck as well and you could only hear them on a very low volume level. It looks like the first revision of the speakers had an issue with the glue from the magnets that makes the magnet off centered. Even if I tried to push the membrane of the speaker with my hand, they wouldn't move. So I've replaced all 4 speakers with the new revisions: Front door bass speakers: - OLD VERSION: 3V0 035 411 D - NEW VERSION: 3V0 035 411 K Rear mid-bass speakers: - OLD VERSION: 3V0 035 411 G - NEW VERSION: 3V0 035 411 L I'll leave this here, maybe it helps😁
  12. @Rsrob how does the material of the steering wheel behave over time?
  13. It's working now!!🥳 The problem was that someone told me that LIN is purple, 12v is yellow and GND is black and actually LIN is yellow, 12V is purple and GND is black.
  14. @ApertureS actually LIN is yellow, 12V is purple and GND is black
  15. @Eki1002 you can see the adaptations list in the last post😁
  16. Sorry for the late reply, I didn't had the time and also due to the lack of the ambient light panels, I paused the DIY. But now that I got the dashboard trims with the ambient light, I resumed the project. After some more coding, I couldn't manage to light up the led but I get an error: 527884 - Local Databus 5 U1500 00 [009] - Electrical malfunction Confirmed - Tested Since Memory Clear Freeze Frame Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 149 Mileage: 146486 km Date: 2024.04.17 Time: 22:20:05 I get this error when the led is connected to the LIN and GND. It doesn't change if it's connected or not to 12V. But if I disconnect either the LIN or GND, I get the No Communication errors related to more Contour Lamps for Doors, and Dashboard and the Local Databus 5 disappears. Tried a lot of coding combinations but I couldn't light up the RGB LED. Any ideas? I will post my AD map if it helps. Thanks in advance and sorry again for such a long late reply. I've tried to compare it with the AD map from @MartiniB and I think got covered everything that needs to be done. I think I'm missing something.. It's pretty clear that the BCM knows now when the RGB led is connected or not. SW:5Q0-937-084-AS HW:5Q0-937-084-AN --- Cent. Elect. Component:BCM MQBAB H H24 0173, Coding:0C010A76C2C722FB57E44004011817080800000000000000000000000000 EV_BCMMQB,015001,EV_BCMBOSCH_015.rod Wednesday,17,April,2024,22:24:56:16365 VCDS Version: Release 21.3.0 (x64) Data version: 20210226 DS325.0 VCID: 094F9D3909BABC93D8D-805C IDE00001-ENG99061-Production mode-Access control,not active ,3 IDE00001-ENG115730-Production mode-Exterior lighting,not active ,3 IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3 IDE00001-ENG112304-Production mode-Heckwischer,not active ,3 IDE00001-ENG98647-Production mode-Interior lights,not active ,3 IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not active ,3 IDE00001-ENG115731-Production mode-Virtuel_pedal,not active ,3 IDE00002-Transport mode,active ,1 IDE00820-Activating and deactivating all development messages,not active ,1 IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active ,12 IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,12 IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,12 IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,12 IDE01268-ENG133394-Windshield wiper-Frontwischer_Abtauposition,not active ,12 IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,12 IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,12 IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,12 IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,12 IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,1000 ms,12 IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,1000 ms,12 IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,12 IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,2500 ms,12 IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,800 ms,12 IDE01268-ENG133393-Windshield wiper-Tippendes_Frontwaschen,not active ,12 IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,12 IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,12 IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,active ,12 IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0 ,12 IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,12 IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,active ,12 IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,12 IDE01550-Service position,157.49 °,2 IDE02152-Characteristics in production mode,2000 ms,4 IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,4 IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,4 IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,4 IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,4 IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active ,4 IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,4 IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,4 IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,4 IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active ,4 IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl,not active ,4 IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active ,4 IDE02332-Deactivate production mode,0 ,3 IDE02711-ENG116690-Rear wiper-Automatisches Heckwischen,not active ,8 IDE02711-ENG133397-Rear wiper-Einzelansteuerung Heckintervallwischen,not active ,8 IDE02711-ENG133395-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,0 s,8 IDE02711-ENG133396-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,0.0 s,8 IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlauf,not active ,8 IDE02711-ENG116692-Rear wiper-Kein automatisches Abparken,not active ,8 IDE02711-ENG114946-Rear wiper-Komfortwischen Heck,not active ,8 IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8 IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8 IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8 IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8 IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW,not active ,8 IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,not active ,8 IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,20 %,8 IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,0 %,8 IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,0 %,8 IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,Enabled ,8 IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,8 IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,8 IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset,-0.25 °,14 IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit,50.00 %/s,14 IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt,both sides ,14 IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold,0.00 km/h,14 IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur,100.00 °C,14 IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur,95.00 °C,14 IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel,90 °,14 IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur,80.00 °C,14 IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel,30 °,14 IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold,40.00 km/h,14 IDE03638-ENG116674-Stationary cornering lamp-Vorschrift,ECE R119 ,14 IDE04923-ENG133379-Turn signal control-Abbruch Komfortblinken,active ,8 IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte ,8 IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,8 IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3 ,8 IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,SMLS ,8 IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,8 IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,8 IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,8 IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10 ,8 IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,20.00 %,8 IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,50 km/h,14 IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,50 km/h,14 IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,14 IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14 IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14 IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14 IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h,14 IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14 IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14 IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active ,14 IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active ,14 IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14 IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,14 IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14 IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,8 IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic ,8 IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,ignition ,8 IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx,8 IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx,8 IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,8 IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 seconds ,8 IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,8 IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,8 IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,8 IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,8 IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C,8 IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C,8 IDE04927-ENG126845-Window heater-FSH Automatik,active ,8 IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8 IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active ,8 IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active ,8 IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn,active ,4 IDE04928-ENG115864-Anti-theft protection-Alarmsignal,frequency modulated ,4 IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung,not active ,4 IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus,not active ,4 IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl,10 Alarme ,4 IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel,not active ,4 IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm,keine verzoegerung ,4 IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,8 IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,8 IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active ,8 IDE05142-ENG116706-Access control-Autounlock NAR,not active ,8 IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,8 IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active ,8 IDE05142-ENG133387-Access control-Deaktivierung_Laderaumschliessung_extern,not active ,8 IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,8 IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,8 IDE05142-ENG115722-Access control-Electrical rear lid,not active ,8 IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,8 IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active ,8 IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,8 IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,8 IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,8 IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,8 IDE05142-ENG133386-Access control-Heckfreigabe_Ohne_Verzoegerung,not active ,8 IDE05142-ENG133388-Access control-LS_Taster_Togglefunktion,not active ,8 IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,8 IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,8 IDE05142-ENG137162-Access control-Mindestbetaetigung_HDF_Innentaster,0.00 s,8 IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,8 IDE05142-ENG115755-Access control-Notschließfunktion,active ,8 IDE05142-ENG133389-Access control-Nutzfahrzeug_Schliessung,not active ,8 IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,active ,8 IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,8 IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu ,8 IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always ,8 IDE05142-ENG115758-Access control-Valet Parking,not active ,8 IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active ,8 IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,8 IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,8 IDE05142-ENG133390-Access control-Wiederverriegelung_Laderaum,Freigabe_Softtouch ,8 IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,8 IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,8 IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung ,8 IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,8 IDE05144-Read parameter address,00 00 00 ,3 IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560 IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560 IDE05145-ENG116063-Light configuration-BAP Bitposition 10,37 ,560 IDE05145-ENG116082-Light configuration-BAP Bitposition 11,41 ,560 IDE05145-ENG116101-Light configuration-BAP Bitposition 12,38 ,560 IDE05145-ENG116120-Light configuration-BAP Bitposition 13,42 ,560 IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560 IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560 IDE05145-ENG116177-Light configuration-BAP Bitposition 16,00 ,560 IDE05145-ENG116196-Light configuration-BAP Bitposition 17,00 ,560 IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08 ,560 IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18 ,560 IDE05145-ENG115911-Light configuration-BAP Bitposition 2,48 ,560 IDE05145-ENG116253-Light configuration-BAP Bitposition 20,09 ,560 IDE05145-ENG116272-Light configuration-BAP Bitposition 21,19 ,560 IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560 IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A ,560 IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A ,560 IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560 IDE05145-ENG116367-Light configuration-BAP Bitposition 26,0C ,560 IDE05145-ENG116386-Light configuration-BAP Bitposition 27,00 ,560 IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560 IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560 IDE05145-ENG115930-Light configuration-BAP Bitposition 3,4C ,560 IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560 IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560 IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560 IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560 IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560 IDE05145-ENG115949-Light configuration-BAP Bitposition 4,48 ,560 IDE05145-ENG115968-Light configuration-BAP Bitposition 5,4C ,560 IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36 ,560 IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40 ,560 IDE05145-ENG116025-Light configuration-BAP Bitposition 8,00 ,560 IDE05145-ENG116044-Light configuration-BAP Bitposition 9,00 ,560 IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560 IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560 IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560 IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560 IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560 IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560 IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560 IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560 IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560 IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560 IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560 IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560 IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560 IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560 IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560 IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560 IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560 IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560 IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560 IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560 IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize ,560 IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560 IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560 IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560 IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560 IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560 IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560 IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560 IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560 IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize ,560 IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize ,560 IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560 IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560 IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560 IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560 IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,560 IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,560 IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560 IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560 IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560 IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560 IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560 IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560 IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560 IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560 IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560 IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560 IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,minimize ,560 IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560 IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560 IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560 IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize ,560 IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize ,560 IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560 IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560 IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560 IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560 IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560 IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,minimize ,560 IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560 IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560 IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560 IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560 IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560 IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560 IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560 IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560 IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560 IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560 IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560 IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560 IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560 IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560 IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560 IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560 IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560 IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560 IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560 IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560 IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560 IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560 IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560 IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize ,560 IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560 IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560 IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560 IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560 IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560 IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560 IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560 IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560 IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560 IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560 IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize ,560 IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560 IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560 IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560 IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560 IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560 IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560 IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560 IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560 IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560 IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560 IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560 IDE05145-ENG115878-Light configuration-Dimmwert AB 0,127 ,560 IDE05145-ENG115897-Light configuration-Dimmwert AB 1,127 ,560 IDE05145-ENG116067-Light configuration-Dimmwert AB 10,127 ,560 IDE05145-ENG116086-Light configuration-Dimmwert AB 11,127 ,560 IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100 ,560 IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100 ,560 IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560 IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560 IDE05145-ENG116181-Light configuration-Dimmwert AB 16,0 ,560 IDE05145-ENG116200-Light configuration-Dimmwert AB 17,0 ,560 IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100 ,560 IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100 ,560 IDE05145-ENG115915-Light configuration-Dimmwert AB 2,27 ,560 IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560 IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560 IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560 IDE05145-ENG116314-Light configuration-Dimmwert AB 23,100 ,560 IDE05145-ENG116333-Light configuration-Dimmwert AB 24,100 ,560 IDE05145-ENG116352-Light configuration-Dimmwert AB 25,127 ,560 IDE05145-ENG116371-Light configuration-Dimmwert AB 26,100 ,560 IDE05145-ENG116390-Light configuration-Dimmwert AB 27,0 ,560 IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100 ,560 IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100 ,560 IDE05145-ENG115934-Light configuration-Dimmwert AB 3,27 ,560 IDE05145-ENG116447-Light configuration-Dimmwert AB 30,100 ,560 IDE05145-ENG116466-Light configuration-Dimmwert AB 31,0 ,560 IDE05145-ENG116485-Light configuration-Dimmwert AB 32,0 ,560 IDE05145-ENG116504-Light configuration-Dimmwert AB 33,0 ,560 IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0 ,560 IDE05145-ENG115953-Light configuration-Dimmwert AB 4,127 ,560 IDE05145-ENG115972-Light configuration-Dimmwert AB 5,127 ,560 IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127 ,560 IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127 ,560 IDE05145-ENG116029-Light configuration-Dimmwert AB 8,0 ,560 IDE05145-ENG116048-Light configuration-Dimmwert AB 9,0 ,560 IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0 ,560 IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0 ,560 IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560 IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560 IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0 ,560 IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0 ,560 IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560 IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560 IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560 IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560 IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560 IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560 IDE05145-ENG115919-Light configuration-Dimmwert CD 2,100 ,560 IDE05145-ENG116261-Light configuration-Dimmwert CD 20,0 ,560 IDE05145-ENG116280-Light configuration-Dimmwert CD 21,0 ,560 IDE05145-ENG116299-Light configuration-Dimmwert CD 22,32 ,560 IDE05145-ENG116318-Light configuration-Dimmwert CD 23,0 ,560 IDE05145-ENG116337-Light configuration-Dimmwert CD 24,0 ,560 IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560 IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560 IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560 IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560 IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560 IDE05145-ENG115938-Light configuration-Dimmwert CD 3,100 ,560 IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560 IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560 IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560 IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560 IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560 IDE05145-ENG115957-Light configuration-Dimmwert CD 4,127 ,560 IDE05145-ENG115976-Light configuration-Dimmwert CD 5,127 ,560 IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0 ,560 IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0 ,560 IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560 IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560 IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560 IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560 IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560 IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560 IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560 IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560 IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560 IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560 IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560 IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560 IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560 IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560 IDE05145-ENG115923-Light configuration-Dimmwert EF 2,10 ,560 IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560 IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560 IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560 IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560 IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560 IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560 IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560 IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0 ,560 IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560 IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560 IDE05145-ENG115942-Light configuration-Dimmwert EF 3,10 ,560 IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560 IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560 IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560 IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560 IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560 IDE05145-ENG115961-Light configuration-Dimmwert EF 4,0 ,560 IDE05145-ENG115980-Light configuration-Dimmwert EF 5,0 ,560 IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560 IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560 IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560 IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560 IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560 IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560 IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560 IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560 IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560 IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560 IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560 IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560 IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560 IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560 IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560 IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560 IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0 ,560 IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560 IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560 IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560 IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560 IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560 IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560 IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560 IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560 IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560 IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560 IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0 ,560 IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560 IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560 IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560 IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560 IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560 IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0 ,560 IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0 ,560 IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560 IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560 IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560 IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560 IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560 IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560 IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,1E ,560 IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,1F ,560 IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,22 ,560 IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,23 ,560 IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560 IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560 IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,00 ,560 IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,00 ,560 IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16 ,560 IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18 ,560 IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A ,560 IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,2B ,560 IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,2D ,560 IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560 IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29 ,560 IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A ,560 IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560 IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2E ,560 IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,00 ,560 IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560 IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560 IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,4C ,560 IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,02 ,560 IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,03 ,560 IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,04 ,560 IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,05 ,560 IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,06 ,560 IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49 ,560 IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B ,560 IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560 IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560 IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,00 ,560 IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,00 ,560 IDE05145-ENG115873-Light configuration-Lasttyp 0,33 - LED-Modul Blinkleuchten ,560 IDE05145-ENG115892-Light configuration-Lasttyp 1,33 - LED-Modul Blinkleuchten ,560 IDE05145-ENG116062-Light configuration-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low' ,560 IDE05145-ENG116081-Light configuration-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low' ,560 IDE05145-ENG116100-Light configuration-Lasttyp 12,10 - allgemeine Scheinwerfer ,560 IDE05145-ENG116119-Light configuration-Lasttyp 13,10 - allgemeine Scheinwerfer ,560 IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560 IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560 IDE05145-ENG116176-Light configuration-Lasttyp 16,not active ,560 IDE05145-ENG116195-Light configuration-Lasttyp 17,not active ,560 IDE05145-ENG116214-Light configuration-Lasttyp 18,12 - Blinkleuchten ,560 IDE05145-ENG116233-Light configuration-Lasttyp 19,12 - Blinkleuchten ,560 IDE05145-ENG115910-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,560 IDE05145-ENG116252-Light configuration-Lasttyp 20,34 - LED Bremsleuchten ,560 IDE05145-ENG116271-Light configuration-Lasttyp 21,34 - LED Bremsleuchten ,560 IDE05145-ENG116290-Light configuration-Lasttyp 22,34 - LED Bremsleuchten ,560 IDE05145-ENG116309-Light configuration-Lasttyp 23,32 - allgemeine LED bis 12W ,560 IDE05145-ENG116328-Light configuration-Lasttyp 24,32 - allgemeine LED bis 12W ,560 IDE05145-ENG116347-Light configuration-Lasttyp 25,36 - LED Kleinleistung ,560 IDE05145-ENG116366-Light configuration-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15 ,560 IDE05145-ENG116385-Light configuration-Lasttyp 27,not active ,560 IDE05145-ENG116404-Light configuration-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,560 IDE05145-ENG116423-Light configuration-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,560 IDE05145-ENG115929-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,560 IDE05145-ENG116442-Light configuration-Lasttyp 30,46 - LED Kleinleistung ,560 IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560 IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560 IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560 IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560 IDE05145-ENG115948-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,560 IDE05145-ENG115967-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,560 IDE05145-ENG115986-Light configuration-Lasttyp 6,3 - Xenon Abblendlicht ,560 IDE05145-ENG116005-Light configuration-Lasttyp 7,3 - Xenon Abblendlicht ,560 IDE05145-ENG116024-Light configuration-Lasttyp 8,not active ,560 IDE05145-ENG116043-Light configuration-Lasttyp 9,not active ,560 IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560 IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560 IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560 IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560 IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560 IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560 IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560 IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560 IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always ,560 IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always ,560 IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560 IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560 IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560 IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560 IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560 IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560 IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,560 IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,560 IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560 IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,only_if_closed ,560 IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always ,560 IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,Always ,560 IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,Always ,560 IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560 IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560 IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560 IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560 IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560 IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560 IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560 IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560 IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560 IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560 IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560 IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560 IDE05145-ENG116199-Light configuration-Lichtfunktion B 17,0 ,560 IDE05145-ENG116126-Light configuration-Lichtfunktion C 13,0 ,560 IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560 IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560 IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,13 ,560 IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,14 ,560 IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,18 ,560 IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,19 ,560 IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560 IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560 IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,0 ,560 IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,0 ,560 IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560 IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560 IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,8 ,560 IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24 ,560 IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24 ,560 IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560 IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8 ,560 IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8 ,560 IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560 IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,26 ,560 IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,0 ,560 IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25 ,560 IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560 IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,8 ,560 IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,43 ,560 IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,45 ,560 IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,46 ,560 IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,47 ,560 IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,48 ,560 IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560 IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560 IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560 IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560 IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,0 ,560 IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,0 ,560 IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560 IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560 IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,15 ,560 IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,15 ,560 IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,22 ,560 IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,23 ,560 IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560 IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560 IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560 IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560 IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560 IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,9 ,560 IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560 IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560 IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560 IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,9 ,560 IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,10 ,560 IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0 ,560 IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560 IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560 IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560 IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560 IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,10 ,560 IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560 IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560 IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560 IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560 IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560 IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0 ,560 IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0 ,560 IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,15 ,560 IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,15 ,560 IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,0 ,560 IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,0 ,560 IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0 ,560 IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0 ,560 IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560 IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560 IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0 ,560 IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560 IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560 IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0 ,560 IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0 ,560 IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0 ,560 IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0 ,560 IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,20 ,560 IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,0 ,560 IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,0 ,560 IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,36 ,560 IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,0 ,560 IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,0 ,560 IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560 IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560 IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560 IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560 IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560 IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,20 ,560 IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560 IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560 IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560 IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560 IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560 IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,8 ,560 IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,8 ,560 IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0 ,560 IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0 ,560 IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560 IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560 IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0 ,560 IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0 ,560 IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560 IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560 IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560 IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560 IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560 IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560 IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560 IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560 IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560 IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560 IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0 ,560 IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,0 ,560 IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,0 ,560 IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560 IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,0 ,560 IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,0 ,560 IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560 IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560 IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560 IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560 IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560 IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0 ,560 IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560 IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560 IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560 IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560 IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560 IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,9 ,560 IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,10 ,560 IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560 IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560 IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560 IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560 IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0 ,560 IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0 ,560 IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560 IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560 IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560 IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560 IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560 IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560 IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560 IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560 IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560 IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560 IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,6 ,560 IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560 IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,0 ,560 IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560 IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0 ,560 IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0 ,560 IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560 IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560 IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0 ,560 IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560 IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560 IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,7 ,560 IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560 IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560 IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560 IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560 IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560 IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,0 ,560 IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,0 ,560 IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560 IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560 IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560 IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560 IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560 IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560 IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560 IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560 IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560 IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560 IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560 IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560 IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560 IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560 IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560 IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560 IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560 IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560 IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560 IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560 IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560 IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560 IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560 IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560 IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560 IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560 IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560 IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560 IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560 IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560 IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560 IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560 IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,0 ,560 IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560 IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560 IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560 IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560 IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560 IDE05145-ENG115979-Light configuration-Lichtfunktion F5,0 ,560 IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560 IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560 IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560 IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560 IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560 IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560 IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560 IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560 IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560 IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560 IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560 IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560 IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0 ,560 IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560 IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560 IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560 IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560 IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560 IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560 IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560 IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560 IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560 IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560 IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0 ,560 IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560 IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560 IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560 IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560 IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560 IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0 ,560 IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0 ,560 IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560 IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560 IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560 IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560 IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560 IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560 IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560 IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560 IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560 IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560 IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560 IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560 IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560 IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560 IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560 IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560 IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560 IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560 IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560 IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560 IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560 IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560 IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560 IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560 IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560 IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560 IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560 IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560 IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560 IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560 IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560 IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560 IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560 IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560 IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560 IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560 IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560 IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560 IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560 IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560 IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560 IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560 IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560 IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560 IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560 IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560 IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560 IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560 IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560 IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560 IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560 IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560 IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560 IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560 IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560 IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560 IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560 IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560 IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560 IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560 IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560 IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560 IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560 IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560 IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560 IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560 IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560 IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560 IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560 IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560 IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560 IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560 IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560 IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560 IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,24 IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,24 IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,23.00 °C,24 IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,22.00 °C,24 IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,23.00 °C,24 IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,22.00 °C,24 IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,24 IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.50 °C,24 IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,24 IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.50 °C,24 IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,41.00 °C,24 IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,40.00 °C,24 IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,41.00 °C,24 IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,40.00 °C,24 IDE06096-ENG116596-Interior lights-Innenlicht bei offenem Heckdeckel einschalten,not active ,8 IDE06096-ENG116597-Interior lights-KL30G ohne PWM,not active ,8 IDE06096-ENG116598-Interior lights-KL58 Einschalten mit Rampe,not active ,8 IDE06096-ENG116599-Interior lights-KL58 Verriegelungsausschalten,not active ,8 IDE06096-ENG116600-Interior lights-Lichtsensor wirkt auf Suchbeleuchtung,active ,8 IDE06096-ENG115631-Interior lights-Suchbeleuchtung Festwert,60 %,8 IDE06425-Dynamometer mode: functional,not active ,1 IDE06507-MAS13125-Button in center console-Function of button 1,Start-stop ,8 IDE06507-MAS13129-Button in center console-Function of button 2,Luggage hold closure ,8 IDE06507-MAS13132-Button in center console-Function of button 3,Driving program ,8 IDE06507-MAS13135-Button in center console-Function of button 4,Steering wheel heating ,8 IDE06864-ENG115833-Daytime running lamps-Fahrlicht bei Tag,Daytime running lamps ,4 IDE06864-ENG115832-Daytime running lamps-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,4 IDE06864-ENG116592-Daytime running lamps-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,4 IDE06864-ENG116594-Daytime running lamps-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,4 IDE06864-ENG122184-Daytime running lamps-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,4 IDE06864-ENG115734-Daytime running lamps-Tagfahrlicht nur in Schalterstellung AUTO,not active ,4 IDE06864-ENG116593-Daytime running lamps-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,4 IDE06864-ENG115733-Daytime running lamps-Tagfahrlichtkontrollleuchte,not active ,4 IDE06864-ENG116591-Daytime running lamps-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,4 IDE07356-Position during interval mode,30.00 °,2 IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,12 IDE07470-ENG133381-After-run for park light-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement ,12 IDE07470-ENG133380-After-run for park light-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement ,12 IDE07470-ENG133382-After-run for park light-Faktor fuer Verfügbarkeitstimer,Faktor fuer x5 Minuten ,12 IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,12 IDE07470-ENG133383-After-run for park light-Standlicht-Verfügbarkeit,24 s,12 IDE08542-IDE02021-Access control 2-Comfort closing,active ,8 IDE08542-IDE02022-Access control 2-Comfort opening,active ,8 IDE08542-ENG128459-Access control 2-easycloselight_aktiv,not active ,8 IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,8 IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,8 IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,8 IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,8 IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,8 IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,8 IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,8 IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active ,8 IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,8 IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active ,8 IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active ,8 IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,8 IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,8 IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,8 IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,8 IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,8 IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,active ,8 IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,active ,8 IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active ,8 IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active ,8 IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,not active ,8 IDE08542-ENG125656-Access control 2-Regenschliessen_art,Permanent ,8 IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,active ,8 IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,not_active ,8 IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,8 IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,8 IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,not active ,8 IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,8 IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active ,8 IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active ,8 IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,not active ,8 IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active ,8 IDE08542-ENG133411-Access control 2-Spiegelanklappen_bei_Wiederverriegelung,active ,8 IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active ,8 IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active ,8 IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active ,8 IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms,8 IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,8 IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active ,8 IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,8 IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active ,8 IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,8 IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,8 IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,8 IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,not installed ,8 IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,not installed ,8 IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,8 IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active ,8 IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,2 IDE08787-ENG101416-Auxiliary functions-Reserved_1,not active ,2 IDE08787-ENG99458-Auxiliary functions-Reserved_2,not active ,2 IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active ,2 IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,2 IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,2 IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4 IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4 IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4 IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4 IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active ,4 IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4 IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4 IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4 IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4 IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4 IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4 IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4 IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,4 IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4 IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4 IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4 IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4 IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4 IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s,20 IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,1 ,20 IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,4 ,20 IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,5 ,20 IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,10 ,20 IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,10 ,20 IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,255 ,20 IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,20 IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,20 IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,20 IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,20 IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,20 IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,20 IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,20 IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,not active ,20 IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,20 IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,20 IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,20 IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active ,20 IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,10 ,20 IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,255 ,20 IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,10 ,20 IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,20 IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,20 IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active ,20 IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,active ,20 IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,20 IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,20 IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active ,20 IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,active ,20 IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,20 IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,active ,20 IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,20 IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,20 IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,255 ,20 IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,10 ,20 IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,10 ,20 IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,20 IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,active ,20 IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,2 IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,installed ,2 IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed ,2 IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,2 IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,active ,2 IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,active ,2 IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,2 IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,2 IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,2 IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,installed ,2 IDE09732-ENG114629-Interior light: light configuration-Footwell lighting,installed ,2 IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI,not active ,2 IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,2 IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,installed ,2 IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,2 IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12 IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,12 IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12 IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,12 IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,12 IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,12 IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,12 IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,12 IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,50 %,12 IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,50 %,12 IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,70 %,12 IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,70 %,12 IDE10298-Alternating park position 1,20.00 °,2 IDE10299-Alternating park position 2,24.49 °,2 IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,64 ,256 IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,64 ,256 IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,64 ,256 IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,64 ,256 IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,64 ,256 IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,64 ,256 IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,64 ,256 IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,64 ,256 IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,07 ,256 IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,30 ,256 IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00 ,256 IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4,00 ,256 IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00 ,256 IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,1C ,256 IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00 ,256 IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00 ,256 IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab,01 ,256 IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf,01 ,256 IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,19 ,256 IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay,00 ,256 IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %,256 IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256 IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,100 %,256 IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht,100 %,256 IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256 IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %,256 IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %,256 IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %,256 IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,100 %,256 IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %,256 IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256 IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,100 %,256 IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht,100 %,256 IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256 IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %,256 IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %,256 IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %,256 IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,100 %,256 IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %,256 IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256 IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,100 %,256 IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht,100 %,256 IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256 IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %,256 IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %,256 IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %,256 IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,100 %,256 IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %,256 IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256 IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,100 %,256 IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht,100 %,256 IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256 IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %,256 IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %,256 IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %,256 IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,100 %,256 IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %,256 IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256 IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,100 %,256 IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht,100 %,256 IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256 IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %,256 IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %,256 IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100 %,256 IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,100 %,256 IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %,256 IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256 IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,100 %,256 IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht,100 %,256 IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256 IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %,256 IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %,256 IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100 %,256 IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256 IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %,256 IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256 IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,100 %,256 IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %,256 IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256 IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %,256 IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %,256 IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %,256 IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,100 %,256 IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %,256 IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256 IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,127 %,256 IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %,256 IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256 IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %,256 IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %,256 IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %,256 IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,127 %,256 IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %,256 IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256 IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %,256 IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht,0 %,256 IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %,256 IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %,256 IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %,256 IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126 %,256 IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126 %,256 IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %,256 IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256 IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,127 %,256 IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %,256 IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256 IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %,256 IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %,256 IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100 %,256 IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,127 %,256 IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %,256 IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256 IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256 IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %,256 IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256 IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %,256 IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %,256 IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100 %,256 IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256 IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %,256 IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256 IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,100 %,256 IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht,100 %,256 IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256 IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %,256 IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %,256 IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100 %,256 IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,100 %,256 IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %,256 IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256 IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,127 %,256 IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %,256 IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256 IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %,256 IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %,256 IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %,256 IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,100 %,256 IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %,256 IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256 IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,127 %,256 IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %,256 IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256 IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %,256 IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %,256 IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %,256 IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,100 %,256 IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %,256 IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256 IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,100 %,256 IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %,256 IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256 IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %,256 IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %,256 IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %,256 IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,100 %,256 IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,10 ms,256 IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit,0 s,256 IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach,0 s,256 IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum,0 s,256 IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht,0 s,256 IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko,0 s,256 IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren,0 s,256 IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit,0 s,256 IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach,0 s,256 IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,10 s,256 IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht,0 s,256 IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko,0 s,256 IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0 s,256 IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit,0 s,256 IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach,0 s,256 IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum,0 s,256 IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht,0 s,256 IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko,0 s,256 IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren,0 s,256 IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit,0 s,256 IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach,0 s,256 IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum,0 s,256 IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht,0 s,256 IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko,0 s,256 IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren,0 s,256 IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit,0 s,256 IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach,0 s,256 IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum,0 s,256 IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht,0 s,256 IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko,0 s,256 IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren,0 s,256 IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit,0 s,256 IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach,0 s,256 IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum,0 s,256 IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht,0 s,256 IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko,0 s,256 IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren,0 s,256 IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit,0 s,256 IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach,0 s,256 IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum,0 s,256 IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht,0 s,256 IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko,0 s,256 IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren,0 s,256 IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen,00 ,256 IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,E1 ,30 IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,E1 ,30 IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,E1 ,30 IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,E1 ,30 IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,E1 ,30 IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,E1 ,30 IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,E1 ,30 IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,E1 ,30 IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,E1 ,30 IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,E1 ,30 IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,E1 ,30 IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,E1 ,30 IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,E1 ,30 IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,E1 ,30 IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,E1 ,30 IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,E1 ,30 IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,E1 ,30 IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,E1 ,30 IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,E1 ,30 IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,E1 ,30 IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,E1 ,30 MAS01490-ENG116830-Energy management-Energy_Management_Adaptation,Energy management active ,1 MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement,not active ,1 MAS05055-lower turn position,30.00 °,2 MAS05056-upper turn position,157.49 °,2 MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,8 MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,8 MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,8 MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,8 MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,8 MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,8 MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,active ,8 MAS05934-ENG133391-Convert. top oper.-Remote Lock Unlock Timer s1,0 s,8 MAS05934-ENG133392-Convert. top oper.-Remote Lock Unlock Timer s3,0.000 ms,8 MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,8 MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,8 MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,8 MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,8 MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,8 MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,8 MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,8 MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,active ,8 MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze,60 lx,24 MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze,110 lx,24 MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,1000 lx,24 MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO,30 lx,24 MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten,60 lx,24 MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten,110 lx,24 MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,80 ,24 MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,100 lx,24 MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4500 mV,24 MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,300 lx,24 MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,2000 mV,24 MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke,0 lx,24 MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung,02 ,24 ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30 ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30 ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30 ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30 ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30 ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30 ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30 ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30 ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30 ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30 ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30 ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30 ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30 ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30 ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30 ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30 ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30 ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30 ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30 ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30 ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30 ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30 ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,I-panel ,30 ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,I-panel ,30 ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,I-panel ,30 ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,I-panel ,30 ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,I-panel ,30 ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,I-panel ,30 ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,I-panel ,30 ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,I-panel ,30 ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,not installed ,30 ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10,not installed ,30 ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11,not installed ,30 ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12,not installed ,30 ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13,not installed ,30 ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14,not installed ,30 ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15,not installed ,30 ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30 ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3,not installed ,30 ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4,not installed ,30 ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5,not installed ,30 ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6,not installed ,30 ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7,not installed ,30 ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8,not installed ,30 ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9,not installed ,30 ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12,0 ,60 ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,1 ,60 ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10,0 ,60 ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11,0 ,60 ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13,0 ,60 ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14,0 ,60 ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15,0 ,60 ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16,0 ,60 ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17,0 ,60 ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18,0 ,60 ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19,0 ,60 ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,2 ,60 ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20,0 ,60 ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,3 ,60 ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,4 ,60 ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,5 ,60 ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,6 ,60 ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7,7 ,60 ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8,0 ,60 ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9,0 ,60 ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60 ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10,0 ,60 ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11,0 ,60 ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12,0 ,60 ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13,0 ,60 ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14,0 ,60 ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15,0 ,60 ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16,0 ,60 ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17,0 ,60 ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18,0 ,60 ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19,0 ,60 ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,8 ,60 ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20,0 ,60 ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,12 ,60 ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,16 ,60 ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,20 ,60 ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,21 ,60 ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7,22 ,60 ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9,0 ,60 ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8,0 ,60 ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,installed ,60 ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10,not installed ,60 ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11,not installed ,60 ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12,not installed ,60 ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13,not installed ,60 ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14,not installed ,60 ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15,not installed ,60 ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16,not installed ,60 ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17,not installed ,60 ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18,not installed ,60 ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19,not installed ,60 ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,installed ,60 ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20,not installed ,60 ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,installed ,60 ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,installed ,60 ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,installed ,60 ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,installed ,60 ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7,installed ,60 ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9,installed ,60 ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8,installed ,60 ENG126647-ENG98399-debug_light_function-Activation,0 ,11 ENG126647-ENG101417-debug_light_function-Adresse,0 ,11 ENG126647-ENG126820-debug_light_function-Bitmask,0 ,11 ENG126647-ENG126821-debug_light_function-Divisor,0 ,11 ENG126647-ENG98827-debug_light_function-Offset,0 ,11 ENG126647-ENG126822-debug_light_function-Polaritaet,0 ,11 ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0 ,11 ENG122934-erase_error_table,00 00 00 ,3 ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay,17 ,2 ENG117283-ENG108451-Frontwaschfunktion-reserve,0 ,2 ENG99457-ENG117394-Head area heater-blower_speed,1 ,2 ENG99457-ENG98971-Head area heater-Temperature,-2 ,2 ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22 ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22 ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22 ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22 ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22 ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22 ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22 ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22 ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22 ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22 ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22 ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %,22 ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00 %,22 ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %,22 ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00 %,22 ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00 %,22 ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00 %,22 ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00 %,22 ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00 %,22 ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00 %,22 ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00 %,22 ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00 %,22 ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22 ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22 ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22 ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22 ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22 ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22 ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22 ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22 ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22 ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22 ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22 ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22 ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22 ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22 ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22 ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 ,22 ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 ,22 ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 ,22 ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22 ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22 ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22 ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22 ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22 ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22 ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22 ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22 ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22 ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22 ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22 ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22 ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22 ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22 ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22 ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %,22 ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %,22 ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %,22 ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %,22 ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %,22 ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %,22 ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %,22 ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %,22 ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %,22 ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %,22 ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %,22 ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %,12 ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %,12 ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %,12 ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %,12 ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %,12 ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %,12 ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12 ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12 ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12 ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12 ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12 ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12 ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10 ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10 ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10 ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10 ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10 ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00 ,10 ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00 ,10 ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00 ,10 ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00 ,10 ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00 ,10 ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10 ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10 ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10 ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10 ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10 ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00 ,10 ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00 ,10 ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00 ,10 ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00 ,10 ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00 ,10 ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12 ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12 ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12 ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12 ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12 ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12 ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00 %,12 ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %,12 ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %,12 ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %,12 ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %,12 ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %,12 ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8 ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8 ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8 ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8 ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00 ,8 ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00 ,8 ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00 ,8 ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00 ,8 ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8 ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8 ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8 ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,510 lx,8 ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00 ,8 ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00 ,8 ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00 ,8 ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00 ,8 ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %,6 ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %,6 ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %,6 ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %,6 ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %,6 ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %,6 ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8 ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8 ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8 ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8 ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00 ,8 ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00 ,8 ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00 ,8 ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00 ,8 ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8 ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8 ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8 ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8 ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00 ,8 ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00 ,8 ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00 ,8 ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00 ,8 ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %,6 ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %,6 ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %,6 ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %,6 ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %,6 ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %,6 ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10 ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,2000 ms,10 ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,3000 ms,10 ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,4000 ms,10 ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,5100 ms,10 ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %,10 ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00 ,10 ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00 ,10 ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,40.00 ,10 ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00 ,10 ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0,maximize ,16 ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0,maximize ,16 ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize ,16 ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,127 ,16 ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0,0 ,16 ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0,0 ,16 ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0,0 ,16 ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16 ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16 ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,33 - LED-Modul Blinkleuchten ,16 ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0,Always ,16 ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16 ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0,not active ,16 ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,not active ,16 ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active ,16 ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,not active ,16 ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0,not active ,16 ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0,not active ,16 ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0,not active ,16 ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10,maximize ,16 ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10,maximize ,16 ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10,maximize ,16 ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,127 ,16 ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10,0 ,16 ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10,0 ,16 ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10,0 ,16 ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,1E ,16 ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,37 ,16 ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low' ,16 ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10,Always ,16 ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Left high beam ,16 ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,Lichthupe generell ,16 ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10,not active ,16 ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10,not active ,16 ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10,not active ,16 ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10,not active ,16 ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10,not active ,16 ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10,not active ,16 ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11,maximize ,16 ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11,maximize ,16 ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11,maximize ,16 ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,127 ,16 ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11,0 ,16 ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11,0 ,16 ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11,0 ,16 ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,1F ,16 ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,41 ,16 ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low' ,16 ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11,Always ,16 ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,Right high beam ,16 ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,Lichthupe generell ,16 ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11,not active ,16 ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11,not active ,16 ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11,not active ,16 ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11,not active ,16 ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11,not active ,16 ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11,not active ,16 ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12,maximize ,16 ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12,maximize ,16 ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12,maximize ,16 ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16 ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,0 ,16 ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12,0 ,16 ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12,0 ,16 ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,16 ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38 ,16 ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16 ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12,Always ,16 ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,16 ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links ,16 ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,not active ,16 ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12,not active ,16 ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12,not active ,16 ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12,not active ,16 ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12,not active ,16 ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12,not active ,16 ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13,maximize ,16 ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13,maximize ,16 ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13,maximize ,16 ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16 ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,0 ,16 ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13,0 ,16 ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13,0 ,16 ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,16 ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42 ,16 ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16 ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13,Always ,16 ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,16 ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts ,16 ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,not active ,16 ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13,not active ,16 ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13,not active ,16 ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13,not active ,16 ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13,not active ,16 ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13,not active ,16 ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16 ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16 ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16 ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16 ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16 ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16 ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16 ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16 ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16 ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16 ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16 ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16 ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16 ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16 ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16 ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16 ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16 ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16 ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16 ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,maximize ,16 ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16,maximize ,16 ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,maximize ,16 ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0 ,16 ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,0 ,16 ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,0 ,16 ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,0 ,16 ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00 ,16 ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16 ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,not active ,16 ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16 ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active ,16 ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,not active ,16 ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16 ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,not active ,16 ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,not active ,16 ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16,not active ,16 ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,not active ,16 ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,not active ,16 ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,maximize ,16 ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17,maximize ,16 ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,maximize ,16 ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0 ,16 ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,0 ,16 ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,0 ,16 ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17,0 ,16 ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00 ,16 ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16 ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active ,16 ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16 ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active ,16 ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,not active ,16 ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16 ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,not active ,16 ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,not active ,16 ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17,not active ,16 ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,not active ,16 ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,not active ,16 ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,maximize ,16 ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize ,16 ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize ,16 ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16 ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18,0 ,16 ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,0 ,16 ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18,0 ,16 ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,16 ,16 ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,08 ,16 ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,12 - Blinkleuchten ,16 ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always ,16 ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,Blinken links Hellphase ,16 ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18,not active ,16 ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16 ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18,not active ,16 ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,not active ,16 ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18,not active ,16 ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18,not active ,16 ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18,not active ,16 ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,maximize ,16 ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize ,16 ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize ,16 ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16 ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19,0 ,16 ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,0 ,16 ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19,0 ,16 ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,18 ,16 ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,18 ,16 ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,12 - Blinkleuchten ,16 ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always ,16 ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,Blinken rechts Hellphase ,16 ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19,not active ,16 ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16 ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19,not active ,16 ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,not active ,16 ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19,not active ,16 ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19,not active ,16 ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19,not active ,16 ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize ,16 ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize ,16 ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize ,16 ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,127 ,16 ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1,0 ,16 ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1,0 ,16 ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1,0 ,16 ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16 ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16 ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,33 - LED-Modul Blinkleuchten ,16 ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always ,16 ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16 ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1,not active ,16 ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,not active ,16 ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1,not active ,16 ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,not active ,16 ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1,not active ,16 ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1,not active ,16 ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1,not active ,16 ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,maximize ,16 ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20,maximize ,16 ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20,maximize ,16 ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16 ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,0 ,16 ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16 ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20,0 ,16 ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,16 ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,09 ,16 ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16 ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always ,16 ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake lamp ,16 ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,not active ,16 ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16 ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,not active ,16 ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16 ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20,not active ,16 ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,not active ,16 ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20,not active ,16 ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,maximize ,16 ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21,maximize ,16 ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21,maximize ,16 ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16 ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,0 ,16 ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16 ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21,0 ,16 ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,16 ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19 ,16 ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16 ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always ,16 ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake lamp ,16 ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,not active ,16 ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16 ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,not active ,16 ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16 ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21,not active ,16 ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,not active ,16 ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21,not active ,16 ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22,maximize ,16 ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22,maximize ,16 ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22,maximize ,16 ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16 ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22,32 ,16 ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22,0 ,16 ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22,0 ,16 ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22,2C ,16 ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22,29 ,16 ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,34 - LED Bremsleuchten ,16 ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always ,16 ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22,Brake lamp ,16 ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16 ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22,Quittierungsfunktion 1 ,16 ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22,not active ,16 ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22,not active ,16 ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22,not active ,16 ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22,not active ,16 ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22,not active ,16 ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23,maximize ,16 ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,maximize ,16 ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23,maximize ,16 ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,100 ,16 ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16 ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23,0 ,16 ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23,0 ,16 ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,29 ,16 ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,0A ,16 ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W ,16 ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always ,16 ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16 ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16 ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16 ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16 ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,not active ,16 ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23,not active ,16 ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,not active ,16 ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23,not active ,16 ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,maximize ,16 ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24,maximize ,16 ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24,maximize ,16 ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,100 ,16 ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16 ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24,0 ,16 ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24,0 ,16 ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,2A ,16 ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,1A ,16 ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W ,16 ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always ,16 ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16 ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16 ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16 ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16 ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,not active ,16 ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24,not active ,16 ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24,not active ,16 ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24,not active ,16 ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25,maximize ,16 ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25,maximize ,16 ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25,maximize ,16 ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16 ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25,0 ,16 ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25,0 ,16 ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25,0 ,16 ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25,30 ,16 ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25,28 ,16 ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25,36 - LED Kleinleistung ,16 ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25,Always ,16 ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16 ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16 ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,not active ,16 ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25,not active ,16 ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25,not active ,16 ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25,not active ,16 ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25,not active ,16 ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25,not active ,16 ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26,maximize ,16 ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26,maximize ,16 ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26,maximize ,16 ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16 ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26,0 ,16 ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26,0 ,16 ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26,0 ,16 ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,16 ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C ,16 ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15 ,16 ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16 ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16 ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,not active ,16 ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,not active ,16 ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26,not active ,16 ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,not active ,16 ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26,not active ,16 ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26,not active ,16 ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26,not active ,16 ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,maximize ,16 ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27,maximize ,16 ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27,maximize ,16 ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16 ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27,0 ,16 ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,0 ,16 ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27,0 ,16 ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,16 ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16 ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16 ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,Always ,16 ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16 ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,not active ,16 ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,not active ,16 ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27,not active ,16 ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,not active ,16 ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27,not active ,16 ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27,not active ,16 ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27,not active ,16 ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,maximize ,16 ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28,maximize ,16 ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28,maximize ,16 ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16 ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28,0 ,16 ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28,0 ,16 ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28,0 ,16 ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,31 ,16 ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,0B ,16 ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,16 ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,16 ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Rueckfahrlicht ,16 ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28,not active ,16 ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,not active ,16 ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28,not active ,16 ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28,not active ,16 ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28,not active ,16 ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28,not active ,16 ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28,not active ,16 ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29,maximize ,16 ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29,maximize ,16 ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29,maximize ,16 ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100 ,16 ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29,0 ,16 ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29,0 ,16 ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29,0 ,16 ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,32 ,16 ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29,1B ,16 ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,16 ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,16 ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29,Rueckfahrlicht ,16 ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29,not active ,16 ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29,not active ,16 ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29,not active ,16 ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29,not active ,16 ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29,not active ,16 ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29,not active ,16 ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29,not active ,16 ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2,maximize ,16 ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,minimize ,16 ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,maximize ,16 ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,27 ,16 ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,100 ,16 ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,10 ,16 ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,0 ,16 ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16 ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16 ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16 ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2,Always ,16 ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16 ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16 ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Daytime running lamps ,16 ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16 ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Blinken links aktiv (beide Phasen) ,16 ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16 ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,not active ,16 ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2,not active ,16 ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30,maximize ,16 ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30,maximize ,16 ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30,maximize ,16 ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,100 ,16 ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30,0 ,16 ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30,0 ,16 ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30,0 ,16 ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,02 ,16 ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30,00 ,16 ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,46 - LED Kleinleistung ,16 ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always ,16 ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,Footwell lamp ,16 ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30,not active ,16 ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30,not active ,16 ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30,not active ,16 ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30,not active ,16 ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30,not active ,16 ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30,not active ,16 ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30,not active ,16 ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31,maximize ,16 ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31,maximize ,16 ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31,maximize ,16 ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16 ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31,0 ,16 ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31,0 ,16 ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31,0 ,16 ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,03 ,16 ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31,00 ,16 ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31,not active ,16 ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31,Always ,16 ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,Ambientelicht 1 ,16 ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31,not active ,16 ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31,not active ,16 ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31,not active ,16 ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31,not active ,16 ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31,not active ,16 ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31,not active ,16 ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31,not active ,16 ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32,maximize ,16 ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32,maximize ,16 ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32,maximize ,16 ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16 ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32,0 ,16 ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32,0 ,16 ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32,0 ,16 ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,04 ,16 ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32,00 ,16 ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32,not active ,16 ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32,Always ,16 ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 2 ,16 ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32,not active ,16 ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32,not active ,16 ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32,not active ,16 ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32,not active ,16 ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32,not active ,16 ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32,not active ,16 ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32,not active ,16 ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33,maximize ,16 ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33,maximize ,16 ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33,maximize ,16 ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16 ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33,0 ,16 ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33,0 ,16 ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33,0 ,16 ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,05 ,16 ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33,00 ,16 ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33,not active ,16 ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33,Always ,16 ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 3 ,16 ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33,not active ,16 ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33,not active ,16 ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33,not active ,16 ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33,not active ,16 ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33,not active ,16 ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33,not active ,16 ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33,not active ,16 ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34,maximize ,16 ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34,maximize ,16 ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34,maximize ,16 ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16 ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34,0 ,16 ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34,0 ,16 ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34,0 ,16 ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,06 ,16 ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34,00 ,16 ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34,not active ,16 ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34,Always ,16 ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 4 ,16 ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34,not active ,16 ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34,not active ,16 ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34,not active ,16 ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34,not active ,16 ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34,not active ,16 ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34,not active ,16 ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34,not active ,16 ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3,maximize ,16 ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,minimize ,16 ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,maximize ,16 ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,27 ,16 ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,100 ,16 ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,10 ,16 ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,0 ,16 ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16 ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16 ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16 ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3,Always ,16 ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16 ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,Parking light right ,16 ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Daytime running lamps ,16 ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16 ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Blinken rechts aktiv (beide Phasen) ,16 ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16 ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,not active ,16 ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3,not active ,16 ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16 ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4,maximize ,16 ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4,maximize ,16 ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16 ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127 ,16 ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16 ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4,0 ,16 ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16 ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,48 ,16 ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16 ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4,Always ,16 ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lamps ,16 ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,not active ,16 ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16 ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16 ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active ,16 ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16 ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4,not active ,16 ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4,not active ,16 ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16 ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5,maximize ,16 ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5,maximize ,16 ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16 ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127 ,16 ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16 ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5,0 ,16 ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16 ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,4C ,16 ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16 ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5,Always ,16 ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lamps ,16 ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,not active ,16 ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16 ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,Parking light right ,16 ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active ,16 ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16 ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5,not active ,16 ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5,not active ,16 ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6,maximize ,16 ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6,maximize ,16 ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6,maximize ,16 ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16 ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16 ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6,0 ,16 ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6,0 ,16 ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,1A ,16 ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,36 ,16 ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,3 - Xenon Abblendlicht ,16 ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always ,16 ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links ,16 ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16 ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16 ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6,not active ,16 ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6,not active ,16 ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6,not active ,16 ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6,not active ,16 ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6,not active ,16 ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7,maximize ,16 ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7,maximize ,16 ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7,maximize ,16 ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16 ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16 ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7,0 ,16 ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7,0 ,16 ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,1B ,16 ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,40 ,16 ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,3 - Xenon Abblendlicht ,16 ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always ,16 ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts ,16 ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16 ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16 ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7,not active ,16 ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7,not active ,16 ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7,not active ,16 ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7,not active ,16 ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7,not active ,16 ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8,maximize ,16 ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8,maximize ,16 ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8,maximize ,16 ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,0 ,16 ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16 ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8,0 ,16 ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8,0 ,16 ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,00 ,16 ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,00 ,16 ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,not active ,16 ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always ,16 ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,not active ,16 ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,not active ,16 ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16 ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16 ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8,not active ,16 ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8,not active ,16 ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8,not active ,16 ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8,not active ,16 ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9,maximize ,16 ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9,maximize ,16 ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9,maximize ,16 ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,0 ,16 ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16 ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9,0 ,16 ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9,0 ,16 ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,00 ,16 ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,00 ,16 ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,not active ,16 ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always ,16 ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,not active ,16 ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,not active ,16 ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16 ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16 ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9,not active ,16 ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9,not active ,16 ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9,not active ,16 ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9,not active ,16 ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16 ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16 ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16 ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16 ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16 ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16 ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16 ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16 ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16 ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16 ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16 ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16 ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16 ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16 ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16 ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16 ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16 ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16 ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16 ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1,active ,1 ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2,active ,1 ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3,active ,1 ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4,active ,1 ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5,active ,1 ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6,active ,1 ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ,not active ,1 ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %,12 ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %,12 ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %,12 ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %,12 ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00 ,12 ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50 ,12 ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %,12 ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %,12 ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %,12 ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %,12 ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %,12 ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %,12 ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,not active ,16 ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,1 ,16 ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung,not active ,16 ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active ,16 ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16 ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active ,16 ENG98831-ENG133403-Personalization-PSO_FSG_Setup2_Bit_0,not active ,16 ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,not active ,16 ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,not active ,16 ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,not active ,16 ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4,not active ,16 ENG98831-ENG133408-Personalization-PSO_FSG_Setup2_Bit_5,not active ,16 ENG98831-ENG133409-Personalization-PSO_FSG_Setup2_Bit_6,not active ,16 ENG98831-ENG133410-Personalization-PSO_FSG_Setup2_Bit_7,not active ,16 ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt,not active ,8 ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung,active ,8 ENG122927-RLS_close_glazing,2.00 s,1 ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s,3 ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,10 s,3 ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h,3 ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h,3 ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx,2 ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12 ,2 ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6 ,2 ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s,2 ENG122929-RLS_LIN_Communication,4 s,1 ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1 ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1 ENG122930-RLS_tunel_gateway_recognize,5 s,1 ENG122935-RLS_Washer_Front,15 s,1 ENG122926-RLS_wiper_position_parking,15 s,1 ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00 ,20 ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00 ,20 ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00 ,20 ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00 ,20 ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00 ,20 ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00 ,20 ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00 ,20 ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00 ,20 ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00 ,20 ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00 ,20 ENG124901-Wischer_Fehlermaske_Mitsuba_Entw,0 ,4 ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3 ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3 ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30 ,3 Elapsed Time: 01:58
  17. @Joco776 how did you manage to make it work? I'm struggling to light up the leds but I get some errors..
  18. Hello, Can anyone help with the correct purpose for each wire? Wich one is for LIN, + and - ? Can I light them up without the LIN bus being connected? Thanks!
  19. @Joco776 oh, that doesn't sounds too good. Have you managed to fix it?
  20. Hi, You may find some information on the first page. This comment might help: I had the same problem and the color selector was not showing up. Have a look.
  21. I don't think that will work with 55. 55 is 85 in HEX which 85,85,85 is a grayish color. The RGB led is not capable of that. After you use that RGB to HEX converter you will have to use the table conversion in order to convert to the correct values. https://kb.iu.edu/d/afdl (Mentioned this one in a previous post). The example that I gave you with Magenta RGB(255, 0, 252), is the normal code color. That means Magenta (255, 0, 252) is (FF, 00, FC) in HEX. More specific: Rotwert Farbe 4 - FF Gruenwert Farbe 4 - 0 or 00 Blauwert Farbe 4 - FC You can also try with the normal code (255, 0, 252), I saw that may differ from car to car on what types of values do they accept. Some nice infos about the colors: https://www.drive2.ru/l/566377681994648900/ https://www.drive2.ru/l/594415778258794719/ Oh, what will be the next one? Is it a newer Superb?😁
  22. I saw in your scan that the other colors are by default E1 (Hex = 225) Try and modifiy the values below by setting another RGB code combination and see if that works. For example, if you want to set color #4 to Magenta try these values: RGB(255, 0, 252). Use this tool to see what values do you need for other colors. https://www.rgbtohex.net/ As I know, the color name will remain the same in the dropdown list, only the color output will be the one that you will set. You can give it a try, maybe it will work. Ambient light color list: Rotwert Farbe 4: E1 Gruenwert Farbe 4: E1 Blauwert Farbe 4: E1 Rotwert Farbe 5: E1 Gruenwert Farbe 5: E1 Blauwert Farbe 5: E1 Rotwert Farbe 6: E1 Gruenwert Farbe 6: E1 Blauwert Farbe 6: E1 Rotwert Farbe 7: E1 Gruenwert Farbe 7: E1 Blauwert Farbe 7: E1 Rotwert Farbe 8: E1 Gruenwert Farbe 8: E1 Blauwert Farbe 8: E1 Rotwert Farbe 9: E1 Gruenwert Farbe 9: E1 Blauwert Farbe 9: E1 Rotwert Farbe 10: E1 Gruenwert Farbe 10: E1 Blauwert Farbe 10: E1
  23. That's a bit odd. Maybe there are other things that needs coding in order to apply the new colors. So if you've had selected Turquoise, what color are the LED strips?
