Everything posted by kelso
Memory settings not working for seats
Some hints from me: 1. end-end resetting values (as above move end to end in all directions) 2. obd11 or any other programme (reset to default values) 3. driver update (in service or by ODIN) 4. module replacement to the newer one... In my case this point solve the problem.
Seat memory issues
status update after few months... as of now, obd11 indicates me only faults related to lumbar part. ive checked live data and it seems that other seat positions (base,back etc) are normed and no faults. in a meantime i didnt do anything with the seats...its just dissapeared by its own. ok so lumbar part...did base settings via obd11 (few times). after that, obd11 still says lumbar not normed. did try do set this up manually - full up and down + front and back lumbar....still no bong..still obd11 says "not normed". out of ideas 🤯
Cruise Control not working
i have connected obd11 today and dig a bit in live data and coding...I found that part: "Activation Not codednot installed" Does it mean that iCC has to be coded by skoda first? https://zapodaj.net/672d09c64a846.jpg.html
I did that part with cleaning that lever. Ok, there was black oily stuff, however still not working after assembling. i have ni clue where to search issue now…all things which could be checked, were checked… - lever with cleaning - brake sensor - ive checked if all buttons in that cc lever works (obd11 sees that while im clicking on it) - max speed set up limit works perfectly, which means lever itself is working cause im using same buttons…however cc doesn’t. well i think its about time just to accept that my cc wont work and i need to use my leg as a CC
1 more thing which may be connected with that issue (but not sure). I remember that after purchasing a car I coded Lane assist option via OBD11 tool. Before that i wasnt testing if CC is working. below is the coding i've used: STG 17 > Codierung > Byte 4 > Bit 6 - aktivieren ("Spurhalteassistent/Lane Assist aktivieren") STG 17 > Codierung > Byte 11 > Bit 1 - aktivieren ("Spurhalteassistent/Lane Assist Information BAP verbaut aktivieren") STG A5 > Codierung > Byte 16 > Bit 7 - aktivieren STG A5 > Codierung > Byte 00 > Bit 0 - aktivieren STG A5 (Front-/Vorfeldkamera) auswählen STG A5 Adapt. Zugriffscode 20103 eingeben -umcodiert (Personalisierung BAP) (BAP personalization,not activated ) von aktiviert auf nicht aktiviert -umcodiert (Warnungsintensität Spurhalteassistent)(Warning intensity; lane depart. warning,Medium > from menu) von Mittel auf Auswahl über Menü - status enabling HCA - STG F5 -umcodiert (ADP-(49)-Car_Function_List_BAP_Gen2-LDW_HCA_0x19) von nicht aktiviert auf aktiviert -umcodiert (ADP-(21)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning) von nicht aktiviert auf aktiviert -umcodiert (ADP-(23)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high) von nicht aktiviert auf aktiviert STG 44 > Codierung > Byte 3 > Bit 4 - aktivieren ("Spurhalteassistent HCA verbaut") - STG 44 > Codierung > Byte 3 > Bit 0 - aktivieren STG 10 - Park Assist > kodowanie > Byte 03 > Bit 5 - activ
checked. working well. well, im not 100% sure, however from what i can see at lever, there's no distance set up option on the graphic pictograms, therefore i assumed its a regular CC not ACC. FYI - camera seems to work well, as sign recognition is working.
not sure if i follow your answer...you mean that CC wont start until you press break pedal?
Air conditioning stops working after 100km driving
If auto AC, try to reset flaps. Below video shows which buttons to use: https://youtu.be/MRa6c9UfyEs
Hi Gents, so i've got a CC probilem in my Superb MK3, meaning I cannot activate it. CC is available under the same stalk as indicators and once Turning on CC, no light on dashboard appears and after pressing SET button still no luck with CC. The funny part is that, when im changing CC mode into Speed limit mode (on the bottom of that lever, icon on dashboard appears and its working well. Ive already checked under obd11 if all buttons under that lever have working signals - yes Ive tried to change in long coding few positions (changing CC options), but no luck. INFO: my car has regular CC only (not ACC). I own that car only for 5 months and got this problem from the beginning. Is it possible that lever is fauly wven though obd11 shows signals are working well? or i should look for that issue somewhere else?
Cruise Control issue - no dash icon, no response
ok, i did above and no luck still.
yep, ive tried pulling that.. i've got line assist but just a regular CC...not an adaptive one. infotainment was resetted few times by now..stil nothing worked as expected. i will check speed threshold on my obd11 device. on the other hand i have some new idea...not sure if im going a good direction but worth to try... So once i've purchased that car, I've disabled Start Stop system via obd11 app. I've read that it changes some voltage value in some module to disable it....now im wondering, if that changed voltage value is causing some issue in the gateway or car electronics, which prevent enabling CC. i will give it a try tomo and revert back that change.
Yep, no errors brake lights works perfectly, therefore its not a switch. no Clutch - DSG. Additionally if Speed Limit option works, then it shouldnt be break switch. Its either coding (maybe someone changed that in the past) or broken module (don't know though, which one is for CC)
i've tried yesterday. Didn't work.
gotcha! will try that thanks for letting me know im not going to visit any dealer in a short time, especially with only that issue - don't want to be ripped off. that function is not MUST to have..its just Nice to have
should i do that once CC is enabled/disabled, on movement or can i do that in the garage?
Hi Champs, tried to look for a similar topic but no luck, therefore creating a new one. Issue: Cruise Control not working once switched ON. No Dashboard icon appear, No response when pressing +Set button. BUT when im changing CC option to speed limit (button at the bottom) it works perfectly. Even dash icon appears. I've read that maybe faulty switch is causing a problem...but....speed limit option works and can be set up, I've checked under VCDS if the buttons works and it seems its totally fine. I'm the 2nd owner, therefore im not sure if previous owner changed something in CC options.
Seat memory issues
im afraid that issue is being caused by that module...my car doesn't have warranty any more, therefore i can spend 150 pounds in better ways and Thank you for part number. i will try to find some good offer.
Seat memory issues
so its me again.... in short....issue still there... ;/ what i have done in a meantime: 1. switched batteries to a new ones in all key fobs 2. used VCDS and obd11 to set new "Norming" in seats memory---didnt work. 3. I've tried to reset seat settings to factory (both, via VCDS and OBD11) and no luck...I mean, both programs didn't let me to perform such operation. I was thinking about going to a dealer, but i don't want to go there as of now (no other issues of needs with a car, therefore not worth it)... do u mean Reset to factory settings or norming? General, i have no other ideas what to do....
Seat memory issues
Thank you TerryMcK for your input...i believe that's a good hint for me to start with. Some time ago i've replaced all batteries in my key fobs (kessy). now i dont see any indication on computer but maybe some "adaptation" is required... i will deep dive into that and let all know in this topic.
Seat memory issues
1. Because i can 2. Because very often im driving with heavy items on passengers seat and signal is annoying (yes, i dont want to seat belt that item)
Seat memory issues
i dont think its related...before i switched off Belt warning signal via OBD11, i was not having that GONG signal for seats....so its seem unrelated...but still i'll be waiting for your feedback once coming back from the dealer
Seat memory issues
Will be waiting for your reply Yes sir, ive tried different various button holding and releasing variations
Seat memory issues
yep, also tried that. not working. so , i've also tried to do it with Ignition off, on, while driving..nothing worked so far. i've tried to re-calibrate seat by obd11 - its moving max forward,back, tilt up etc...same after that... OBD11 -> Live Data -> tried to check all buttons communication etc with module..all worked perfectly. so either its a faulty module (something is blocking) or its still me, not doing something properly/in right order.
Seat memory issues
thanks mate for that. I was trying to use different button variations (long,short press etc) but no luck anytime. Also tried to press and hold 2 buttons at the same time...no luck. MY OBD11 shows me that i have 7 issues under seats section "B135154", 135254, B201000 etc all static ones.
Seat memory issues
Hi Gents, already looked for a forum solution but no luck. My issue is related to Seat memory - tried all tips and tricks and nothing worked so far. Driver's seat buttons are workin and I can adjust seat, but can't save via programming buttons. Tried to set up by moving forward, back, etc. also I've tried to set up seat by using OBD11, but again...no luck. Checked all the connections under the seat...all good. I even bought new switch (that part with buttons) to check if maybe that is faulty...well, it wasn't. I have no idea what else i could do... P.S. saving methodology i was using: 1. adjust mirrors + seat (all positions) 2. press SET button (for about 1 sec or longer) - release that button 3. Press 1/2/3 button to save it....no GONG sound at the end.
