Everything posted by Klario
Pulsating sound at 1000rpm
Did you solve this? I have the same sound but I haven't changed anything.
Clock spring
they changed the stem for me in the service and now I have that click
Creaky steering in hot weather
I looked at Skoda erWin they don't have a problem like this ... but I found that they swindle me for the touch screen sw ... which I have occasional problems with.๐
was at the service station they don't know what could be
my vehicle is octavia 2019 still under warranty
creaking/sqeaking steering
Hi, did you solve the problem and mine does something similar?
When starting the octavia 3 dsg the engine is occasionally turned off
with us you are obliged to go to an authorized service center authorized by the main importer
he also threw out the fault of the air conditioning damper motors that I hear in the cabin while driving tak tak tak knocking, they claim that this is not the cause of the shutdown ... they will replace the air motors that control the cabin circulation.
the vehicle is under warranty until 2024 so you should not do it anywhere other than at an authorized service center
as far as i noticed my works around 70rpm sometimes and more ... i noticed that the shutdown happens in the summer when the air conditioner is constantly on..in the winter it didn't go out. can't you adjust the engine speed? even service is not allowed only if there is a sw update for my vehicle. the service doesn't know what to do next, they send a technical inquiry to the factory ... it just goes on and on and they can't solve the problem.
this has nothing to do with the start stop function ... the start stop with me is always off..just something turns off the engine and that shouldn't happen ... the same thing when you suddenly release the clutch on the manual transmission .... only I don't have it the jerk just goes out.
I start the vehicle ... the vehicle is on, I switch to drive mode D. .I release the brake, it turns off and then the board says start the engine manually. This happened, to me at the traffic lights while I was waiting for the green light ... I keep the start stop off
the vehicle shuts down when starting and the board says start the engine manually ... I have no problem starting the vehicle but when moving
Engine stops during start with DSG gearbox
i have a problem with octavia 3, 1.6 tdi dsg 7. Occasionally it happens when starting the engine the vehicle shuts down and then I have to start it manually by turning the dsg gearbox from d to P and turn the vehicle off again with the key and start. a couple of times it happened in traffic and it wasn't very pleasant because the process of starting the vehicle is going on. I consider this a skoda safety problem. the vehicle is under warranty, the service performed a diagnostic test that did not show an error. the only mistake was the valve air conditioning motor that controls the air flow plus the potentiometer..service claims that this is not the cause of the vehicle shutting down (make a replacement). the basic adjustment of the dsg gearbox was performed again last week and the cause of the shutdown remained the same. I have seen a lot of vehicles on the forum with the same problem so please help and advice
the vehicle is under warranty, the service does not know what it is about..I recorded a video where the extinguishing can be seen, they sent an inquiry to the factory and now I am waiting..there is no mistake with the diagnosis?
dsg 7 maintenance
what do you suggest me to change the oil for how many kilometers and which oil to change, that the engine is 1.6 Tdi Dsg 7, the vehicle is 2019 production with 34000 km
dsg 7 maintenance
how do i know which clutch is now made from octavia 3, dsg 7, 1.6 tdi 2019. they say they do not have a service interval from the manufacturer.
dsg 7 maintenance
1.6 Tdi authorized service no service plan says that for dsg 7 gaerbox sealed no oil change
dsg 7 maintenance
I received an answer from an authorized service that there is no service plan for the DSG 7 gearbox, is that really true?
start stop is always on..the problem is still the same, when moving not every time the engine shuts down
the authorized service performed the vds scan, there are no errors and the vehicle is under warranty currently the service has lost connection with the ลกkoda server due to telecommunication problems and now I am on hold..checking with the factory if there is a sw bug, the vehicle has 30000km
I have a problem with the Skoda Octavia 3 Dsg, when starting the engine occasionally shuts down and I have to restart it manually.
