Joco776
Everything posted by Joco776
  1. @RBWHi. There is no ready update because your unit is version 02xx and 0480 is 04xx so it needs to be created. If you are interested, feel free to write to me.
  2. @Lantean@RBWI can update it for you to version 0480.
  3. @ScleptzeR I need to create new software for your unit and then upload it to the unit as instructed. If you want, send me a pm.
  4. @ScleptzeR restart the radio and then fix the errors. 480 will change all the colors to new ones
  5. @ScleptzeR Hi. If you have vcd or obdeleven go to 5F enter security code S12345 OK then in edit look for "confirmation" there you will see 4 numbers you will need to change using the calculator I will send you a link to. https://mib-helper.com/im-so-xory/ There you write the numbers and have new ones generated and write to the vcd with a space and confirm, then the unit tells you to start over (that means the unit reboots). After rebooting, remove all errors from 5f that appear due to the update log and you will never see these errors again because you have successfully verified the new code after installation. If you want, I can update your unit to version 0480.
  6. Who wants to convert 02xx, 03xx to 04xx, write me.
  7. @Deansie Hi Deansie. I can update your unit to version MST2_EU_VW_PQ_P0480T. It already has a color menu and I can activate Apple Carplay and upload all the swap codes at the same time. If you are interested, please contact me at any time. Regards, Joco.
  8. @thuginme Okay. It's just a risk and if you do the new update wrong your unit will stop working and you can't fix it yourself without knowledge and tools.
  9. @erik12 @abouelkacem1981 pm.
  10. Look at pm. @crackzman @padree @AnsFr @Nikola1985 @dexty01 @Alex_Mere @usermask
  11. @Eirhead pm
  12. @Eirhead I have already swapped successfully, uploaded the correct parameterization for my vehicle, had to manually edit a few things from the old backup and everything works. Do you have any diagnostics? Or send me the 09 exchange statement
  13. Can someone fix the columbus unit has a stuck screen and only shows the logo and restarts after a while 🙄
  14. @Skiziix Email me and I'll send you an update and instructions
  15. @AmolK Hello, you have to do the activation at the seller. I can only send you an update on 0369T. I would have to have your unit with me to put 0480 there.
  16. @Gabor1986 Email me and I'll send you an update and instructions
  17. @MrPekka Hi, send me an email and I will send you the update for your unit and the update instructions.
  18. @Skiziix hi send me sw what's there
  19. @AlexeM @janoscool @mirolo I wrote you a message
