simcor
Everything posted by simcor
  1. Well one replacnrt door speaker and all is well with the world so far. No distortion on any of the other speakers at all and sounds back to normal. Very odd but there you go, I've never blown a speaker before in a car or in professional audio gear in my life before. Go figure. But at least it was a crazy cheap fox after all.
  2. Well after some investigation I have purchased a new door speaker and replaced it the audio is back to normal and no distortion, no idea why other speakers were also distorting. But we shall see how it goes long term but for now it's all good again.
  3. I'm aware Chinese units are not the best but tbh I don't want to pay Skoda prices to have it fixed and also don't really want to pay 300 quid for a repair to my unit, or even finding someone who will repair it for less and maybe still have issues down the line. I just want to be able to listen to music again with out distortion and I'm not likely to be keeping the car that much longer anyway.
  4. Having said all that I have 2 trouble codes for the 5F unit, dab antenna both open circuit. Apparently that failing can cause distortion on all audio sources. I have discinected the fakra connector to see if that resolves it bit srill the same, also possible break in door harness can also cause it, so hoping it's one of those that is causing it. Quick look and found a new one but for 75 quid for a tiny little box.
  5. Mind I'm guessing these use the media/nav module still as the amp at guess?? Need to check they out cause if that's the case then it's a waste of time.
  6. https://pluscenter.co.uk/products/skoda-octavia-mk3-rapid-2013-2019-android-15-car-stereo-head-unit-carplay-android-auto?srsltid=AfmBOoo0TUz_Q2bwnqLqLSQivFAuKCgKTOU3qd36d7cyLZjWsCOHe7H8 Might just go for that as a direct replacement and keep original functions.
  7. My radio has started to distort at low volume and high volume but it's much more notice bake at low volume. I do drive the amp and speakers loud a lot of the time but I am also and ex sound engineer ao I do know how hard they can be driven safely. I'm guessing at the most as I have not done any diagnostics yet other than pressing and holding the power button for 10 secs til the unit reboots and the logo cones up but that makes no difference. I'm thinking of changing the radio to an aftermarket one is there any that fit the hole without needing fascia panels and keeps as many of the cars original functions like on the old screen at all?? Haven't really got round to looking into it yet, but I'll probably be getting rid next year. Any thoughts or suggestions on decent ish replacments as above??
  8. Anyone got the cost for a nearside VRS 2018 half LED rest light cluster for a hatchback?? Damaged it today getting old sofa into the boot and mightily annoyed it bust a piece off. And as its visible even with boot closed its gonna have to get fixed.
  9. The way I would describe it was like pads down to the rivets but also maybe worse than that, should have seen the looks I was getting driving through Sheffield city centre! Then it just stopped and has not come back so maybe was just a stone that flicked up and got caught between something like disc or driveshaft etc, it also had a new wheel bearing while under warranty at Skoda. It's now done 76k miles so now under average for its age as well.
  10. Running at normal oil temp, normal coolant temp, no lack of power, no smoke drives perfectly fine today. It's always used some oil since I bought it in 2023, in fact every diesel car, van and truck I've ever driven use some oil over time. Like I said I put maybe a litre max maybe only half a litre in to get it to halfway on the dipstick, tbh I should check it more often than i do. I don't think I've checked it since it's service and MOT in November. Naughty me. I always let it complete dpf regens, never seen the dpf light on unless it's near 100% soot loading and I force it to do a field regen at a suitable time for me with carista. I don't drive it hard very often and never from cold. Never had any warning lights on dash in my ownership. It's like it never happened took it for another road test after having a look round everything, no obvious leaks or anything. It's a right Toyah Wilcox (anyone of a similar age to me will get that).
  11. Was heading to city Hall last night for a night out. Came off M1 and as I slowed on the slip road the car started making an awful scraping sceexhing sound, like metal on metal. Limped it down the Parkway and it was awful, sounded like I was murdering the car. At a stop it wasn't making any noises, as soon as I pulled away it made it again and was really really loud, didn't seem to really alter with road speed like it was brake related and didn't realize change frequency or pitch with rotation of the wheels, just whenever moving. FSH car with Skoda, had a new water pump and timing belt on it, aux belt looks fine, pads and discs as I expected are still almost like new. As I put ferodo discs and oads on front maybe within last year and brembo discs and lads on read before MOT in Dec. After a while of limping it to the car park the noise just went away on its own I was gonna call my breakdoen out after the concert but I tried it and it was fine to drive. Making no noise this morning that is obvious but I can hear an odd noise around the timing belt area that I can't say if has always been present. Really don't know what to think anyone has something similar on a VRS diesel? It's gotten me a bit worried as it's my only car and I need it Sunday for work. It was low on oil again mind it was serviced late Nov maybe a litre ir so needed, it does seem to use a bit of oil but again I think that seems to be normal with this engine. I'm at a loss with it right now.
  12. Pm sent so when you get chance to look that would awesome thank you.
  13. Pm sent so when you get chance to look that would awesome thank you.
  14. 2007 MK1 1.9TDI estate. I'm trying to find correct part numbers for the headlights but I'm struggling. Anyone got or able to get me the part numbers required at all please? I'd be eternally grateful if anyone can help. Can provide vin number via pm if required. It's 6Y6 vin number. I could do with sourcing them before this weekend to get them fitted for its MOT. not my car I've got an Octavia VRS dirty diesel. 🤣 Simon
  15. Well I downloaded the 2024/25 map data for the inbuilt sat nav but I use Waze or Google maps on android auto mostly anyway. But thought it was worth updating it for the speed limit info. Would help if the instruction on the sat nav portal actually told you exactly how to do it, but use the original SD card, save the contents off the card just in case, download the correct mapping by checking the version on the car first, unzip the files you download with 7 zip or any zip program. Copy the maps folder to the SD card and the checksum file and then pop the card back into the card and hey Presto. Oh and format it fat32 or exact dependant upon the size of the card. Have not been out to see if it's solves some of the errors on speed limits yet though. But don't expect much hope.
  16. It seems from some googling that menu is not available on all cameras so seems to be camera dependant possibly. I googled it and found a thread saying that. Cause in adaptions on OBD11 I have nothing like that.
  17. Bear in mind I'm using OBD11 not VCDS, Controller A5 (Front / front view camera) 16 - Security Access - enter 20103 10 - Adaptations Select channel Display end of speed limit symbol Change to activated Actually it is that I'm struggling to find sorry got a little muddled up there as to what I couldn't find. If I go into adaptions after entering the security code I don't have anything that resembles that. I have noticed on a few 30mph roads it says the speed limit is 60mph and does drop back to 30mph after a while it also shows it as 60 on the factory nav, it also shows a lot of 30mph limits as 20mph as well. I suspect to update the nav mapping id need a newer version on an SD card?
  18. Huh that has worked this time although I can't find that channel 151 menu display threshold adaptation for some reason. Not sure what difference that will make. Just been out and it's shows road signs and changes and tells me if I exceed the speed limit into one.
  19. This guide was on YouTube supposedly for all MQB platform cars.
  20. My car has lane assist, no satnav Traffic Sign Assist Activation 1. Control Unit 5F - Information
 Adaptation
 Car_Function_List_BAP_Gen2 traffic_sign_recognition_0x21 = Activated, then Green tick
 Car_Function_Adaptions_Gen2 menu_display_road_sign_identification = Activated, then Green tick
8. Control unit A5 (front / advance camera)
 Security access - 20103 Control unit Long Coding
 Byte 16
Bit 04 Activate , then Green tick
 13. Control unit 17 (Dashboard)
 Byte 5
 Bit 02 Activate, then Green tick I also tried this guide from OBD11 forum from memory.
  21. All control units listed ignore any errors as I have resolved one or 2 I caused and only have 3 error codes now, LED bulbs under seat, key battery and DAN aerial are the only 3 error codes. Full scan Control Units: 18 Fault count: 5 Control Units: D7 LED Module Right System description: LED1R Software number: 7P5941591AJ Software version: 0011 Hardware number: 7P5941591A Hardware version: H07 ODX name: EV_LED_PLUS_R_KEBODAVW416 ODX version: 001003 Faults: No trouble codes found D6 LED Module Left System description: LED1L Software number: 7P5941591AJ Software version: 0011 Hardware number: 7P5941591A Hardware version: H07 ODX name: EV_LED_PLUS_L_KEBODAVW416 ODX version: 001003 Faults: No trouble codes found A9 Structure Borne Sound System description: SAS-GEN 2 Software number: 5E0907159 Software version: 0001 Hardware number: 4H0907159A Hardware version: H06 Serial number: 170908200290 ODX name: EV_SoundActuaGen2AU64X ODX version: 003010 Faults: No trouble codes found A5 Driver Assistance System description: MQB_B_MFK Software number: 3QD980654 Software version: 1272 Hardware number: 3Q0980654A Hardware version: H08 Serial number: 02091741K20063 ODX name: EV_MFKBoschMQBB ODX version: 001001 Faults: No trouble codes found 76 Parking Assistance System description: PDC 4 Kanal Software number: 5QA919283B Software version: 0044 Hardware number: 5QA919283 Hardware version: H07 Serial number: 00030841961727505221 ODX name: EV_EPHVA14AU3700000 ODX version: 009033 Faults: No trouble codes found 5F Multimedia System description: MU-S-ND-ER Software number: 5Q0035874C Software version: 0468 Hardware number: 5Q0035874C Hardware version: H41 Serial number: SKZAZ2T5391491 ODX name: EV_MUStd4CTSAT ODX version: 001022 Faults: U111100 - Function limitation due to missing message static Date: 2024-07-13 14:02:20 Mileage: 105039 km Priority: 6 Malfunction frequency counter: 1 Unlearning counter: 138 Dynamic environmental data: 028677184402 52 Passenger Door System description: TSG BFS Software number: 5Q4959392E Software version: 0032 Hardware number: 5Q4959392B Hardware version: 011 Serial number: 0000280067036 ODX name: EV_DCUPasseSideEWMAXCONT ODX version: 006001 Faults: No trouble codes found 4B Multifunction Module System description: FCM MQB Low Software number: 3Q0907338 Software version: 0286 Hardware number: 3Q0907338 Hardware version: 002 Serial number: 29091710520539 ODX name: EV_MultiModulContiVW48X ODX version: 001010 Faults: No trouble codes found 44 Steering Assistance System description: EPS_MQB_ZFLS Software number: 3Q0909144K Software version: 5072 Hardware number: 3Q0909144H Hardware version: 506 ODX name: EV_SteerAssisMQB ODX version: 013144 Faults: No trouble codes found 42 Driver Door System description: TSG FS Software number: 5Q4959393E Software version: 0032 Hardware number: 5Q4959393B Hardware version: 011 Serial number: 0000280241683 ODX name: EV_DCUDriveSideEWMAXCONT ODX version: 006001 Faults: No trouble codes found 19 Gateway System description: GW MQB High Software number: 3Q0907530G Software version: 4304 Hardware number: 3Q0907530C Hardware version: 436 Serial number: 0006870215 ODX name: EV_GatewNF ODX version: 013023 Faults: No trouble codes found 17 Dashboard System description: KOMBI Software number: 5E0920957E Software version: 0310 Hardware number: 5E0920957E Hardware version: 303 ODX name: EV_DashBoardVDDMQBAB ODX version: 009060 Faults: U111000 - Function restriction due to communication interruption static Date: 2024-07-13 14:08:12 Mileage: 105039 km Priority: 6 Malfunction frequency counter: 1 Unlearning counter: 138 16 Steering Column System description: Lenks. Modul Software number: 5Q0953507GD Software version: 0140 Hardware number: 5Q0953549F Hardware version: 003 Serial number: 05101708490881 ODX name: EV_SMLSKLOMQB ODX version: 020002 Faults: No trouble codes found 15 Airbag System description: Airbag VW21 Software number: 3Q0959655BH Software version: 0703 Hardware number: 3Q0959655BH Hardware version: 006 Serial number: 003W4PJLV0KQ ODX name: EV_AirbaVW21TS6VW48X ODX version: 001014 Faults: No trouble codes found 09 Central Electrics System description: BCM MQBAB H Software number: 5Q0937084CQ Software version: 0253 Hardware number: 5Q0937084CG Hardware version: H36 Serial number: 01001726802254 ODX name: EV_BCMMQB ODX version: 018001 Faults: B11FF01 - Footwell lighting Electrical error static Date: 2024-07-13 13:36:20 Mileage: 105039 km Priority: 6 Malfunction frequency counter: 1 Unlearning counter: 138 Terminal 15 status: On Terminal 50 status: Off Voltage: 12.0 V Outside air temperature: 18.5 °C Status Bremslichtschalter (HW): Off Status Bremslichtschalter (CAN): Off Off: not activated Parking light: not activated Automatic high beam assist: operated Low beam: not activated Parking light left: not activated Parking light right: not activated Letzte Weckursache/ Werte [00;2E]: keine Störschutzursache CAN-Bus_aktiv: On 08 Air Conditioning System description: Climatronic Software number: 5E0907044AP Software version: 2001 Hardware number: 5E0907044AP Hardware version: H04 ODX name: EV_ACClimaBHBVW37X ODX version: 006146 Faults: No trouble codes found 03 Brakes System description: ESC Software number: 5Q0614517AQ Software version: 0400 Hardware number: 5Q0614517AF Hardware version: H62 Serial number: 62817000002382 ODX name: EV_Brake1UDSContiMK100ESP ODX version: 036010 Faults: P164700 - Checking coding/versions of control modules in drivetrain static Date: 2024-07-13 13:41:56 Mileage: 105039 km Priority: 3 Malfunction frequency counter: 2 Unlearning counter: 138 Extended Freeze Frames: 0000001A32000000A8000100FD01000000000000000000 01 Engine System description: R4 2.0l TDI Software number: 04L906026BR Software version: 7724 Hardware number: 04L907309R Hardware version: H24 ODX name: EV_ECM20TDI01104L906026BR ODX version: 004006 Faults: U112300 - Databus error value received static Date: 2024-07-13 13:41:56 Mileage: 105039 km Priority: 6 Malfunction frequency counter: 2 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 57 °C Intake air temperature: 57 °C Ambient air pressure: 990 mbar Voltage terminal 30: 12.020 V Dynamic environmental data: 20962817E0000017DD1117DE000011870000
  22. Adaptation Control unit: 5F Multimedia Name: Car_Function_List_BAP_Gen2 Values: traffic_sign_recognition_0x21_msg_bus: Old value: Databus extended New value: Comfort data bus Mileage: 105061 km Date: 2024-07-13 21:08 --------------------------------------------------------------- Adaptation Control unit: 5F Multimedia Name: Car_Function_List_CAN_Gen2 Values: MFL_msg_bus: Old value: Databus extended New value: Comfort data bus Mileage: 105061 km Date: 2024-07-13 21:07 --------------------------------------------------------------- Long coding Control unit: 5F Multimedia Old value: 03735101FF00000051111201008800002F0209C6012005008F New value: 03735101FF00000051111201008800002F0209C601200500CF Mileage: 105061 km Date: 2024-07-13 21:03 --------------------------------------------------------------- Long coding Control unit: A5 Driver Assistance Old value: 0203070100000401000213408150A81084000E200000 New value: 0203070100000401000213408150A81094000E200000 Mileage: 105061 km Date: 2024-07-13 21:01 --------------------------------------------------------------- Adaptation Control unit: 5F Multimedia Name: Car_Function_Adaptations_Gen2 Values: menu_display_road_sign_identification: Old value: activated New value: Not activated Mileage: 105061 km Date: 2024-07-13 21:00 --------------------------------------------------------------- Adaptation Control unit: 5F Multimedia Name: Car_Function_List_BAP_Gen2 Values: traffic_sign_recognition_0x21: Old value: activated New value: Not activated Mileage: 105061 km Date: 2024-07-13 20:59 --------------------------------------------------------------- Long coding Control unit: 17 Dashboard Old value: 27A5010069848600010A6B021001000000000000 New value: 27A5010069808600010A6B021001000000000000 Mileage: 105061 km Date: 2024-07-13 20:57 ------------------------------------- I believe they were the adaptions I configured or do you need the full history? As its very long winded otherwise?
  23. Adaptions screenshots after putting it back to normal https://ibb.co/FxN9SSw https://ibb.co/d4tJnNf https://ibb.co/wLqzJg0 https://ibb.co/XpWBZWt I cant upload them to here so hope those links work.
  24. That was the guide I was using, I assume you mean a full log and you want the 5F adaption screenshots?
