Everything posted by okmate
Drivers door not locking
That link also says transporter so must be the right part thanks pal will get this ordered
I put my car details in and it says itwont fit but its the correct part number ?? https://www.ebay.co.uk/itm/164708399776?hash=item265962baa0%3Ag%3AwMgAAOSw-8th6AnC&amdata=enc%3AAQAHAAAAoHD3nfUL%2Bnv2kpc%2FWCxD3wEg0nsMPO0mXnqSEgOPDL%2FoAP7WCnuquCm%2FtTBXSuslgCsyrXxXCXiDjSJvVg3fIu6OlqFzSZKpMA%2BIWCzzzjO8wEWnbr8MYcxf6Pl3mjSt%2B8%2FbeUjPvHvowWM48vLR8nD3ivjkdiPtJwNxGkZmadgoYH6%2F4r8phAg5NX5FUEEjji9jNqn4PYL79Xaqjp0eBa0%3D|tkp%3ABk9SR9ius-nWYA&LH_ItemCondition=3
No pete its the pull push mechanism thats snaped away from the main lock ive found a small spring in the door. i would assume the wire lock mechanism is complete on the door lock,this ones broken. will have a search for the door lock on ebay,there seems to be loads off different vechicles that are fitted for this lock
Hey guys ive had a go today, ive removed the door frame and glass and plugged the connector in to see if it works and hey presto central locking worked great,and the bad side the lock mechanism that that you pull up and down was broken, it connects onto a brass connection that looks like it engages to a cog,but its broken so its a new mechanism, hey how . any idea what the part number is on this ?
I will go for that pete lol fingers crossed its just the case of plugging in lol
think i may buy some hex self tapers lol what size you think pal ?
Cheers pal ive just ordered the rivits and gun, its the bigger 6.4 size with 2 handles could you tell me which ones need to be drilled out,maybe a pic,dont want to drill out the ones i dont need to, i told my son to order the new lock for the sake of £20 but he wants to wait and see lol, i'm hoping i can repair it maybe a dodgy micro switch fingers crossed,whats your take pal ?
- Drivers door not locking
My train of thought was they had an issue with the door lock due to the cable i repaired or maybe the corrosion,but instead of looking there theve taken the panel off and realised that its pop rivited so decided to tug on the cable going through the plate to the lock mechanism,the pop rivits look original- Drivers door not locking
well today we took the connectors out of the door frame and checked for corroded terminals. There was a few terminals that looked corroded, especially the large black plug, so cleaned and scrubbed with wd40 and a toothbrush along with a small wire brush, not forgetting I already repaired the violet /yellow cable. I plugged them back in and checked, but it was exactly the same, i decided to take the panel off the door to take a closer look and realised that someone had been here before, when all the screws were off i lifted the door card off and the lock mechanism connector fell away, yes that's right it wasn't even plugged in, and at looking a little closer it looked like some one had pulled it off as the clip side had broken and as the rivet's were still intact i could see this was someone's attempt of a quick fix. Unfortunately ive had to leave it for today as i go on holiday on Sunday and haven't got the correct rivet's to refit, but defo thinking its the lock mechanism. whats your thoughts ??- Strange wires from fuse box
Well just had an hour or 2 with my son to try and get to the bottom of several problems which i will update on the other posts I created, we traced the wires back to the stereo, for some reason the wires that feeds permanent live was cut very close to the stereo harness not sure why they went to so much trouble but I'm glad they were obviously not very electrical savvy, we will purchase a new stereo anyway, the good news is the main stereo harness is intacked. that's one problem off the list- Strange wires from fuse box
Going to sort this tomoz guys, will keep you updated- Drivers door not locking
soz pete just posted this thanks pal- Drivers door not locking
will have a go in a bit,i guess its best to disconnect the battery- Strange wires from fuse box
Yes its terrible dont worry lads it will be removed, not on my watch lol i love a challenge lol will trace the wires back and have a look- Drivers door not locking
Sorry the purple in the left of the pic is the wire ive repaired, i didnt realise that the sockets could be at fault, is there a way of unpluging without taking the door off? was going to pop the door trim off and may be do some continuity checks- Strange window switches
How you reset pal ?- Strange wires from fuse box
- Front bumper lower grille replacement
yes will defiantly remove the bumper, is there any video's out there- Drivers door not locking
well the first step is complete pete found a wire that was broken and re-soldered, but the problem is still there, the tiny red light flashes where the lock is but still nothing happens so its off with the door card,- Front bumper lower grille replacement
its not that kind og grille think its the facelift,- Rear seat pull catch broken
is the right side drivers side ?- Strange window switches
Thanks pete,i'm looking for a new drivers one to have you a number for that ? god i'm a pain,ive purchased a haynes manual but i'm looking for some kind of service parts catalogue any ideas it will stop me asking you lol, i'm also after a place to order parts apart from ebay - Drivers door not locking
