yerbito
Everything posted by yerbito
  1. Hi. I have got a Nov '13 Skoda Octavia Mk3 without electronic foldable mirrors. door modules were 5Q4 959 393 B and 5Q4 959 392 B. Interior mirror has auto-dimming (it has a button and a green light). Well. I changed both side mirror for ones with auto-dimming, entry light and foldable electronically. Also I changed bot door modules for 5Q4 959 593 E and 5Q4 959 592 E, and the mirrors knob. But now I have some faults. - When the car is moving the doors auto-lock desnt work. I deactivated that opcion on infotainment because car tried to lock the door one or two times per minute - If I lock doors using lock button in front of the gear lever the door are locked, but I can't unlock doors using that button. - auto-folding mirrors when car is parked and locked doesnt work. That opcion is on infortainment but I can activate it. I followed the SashaGrace instruccions and I can do that: 09] Central Electronics [16] Security Access - Code is 31347, click "Do it!" [10] Adaptation, choose from the drop down channel [24] - Access control 2 - Funk Spiegelanklappung Modus change to “by look command via remote control key” [26] - Access control 2 - Menuesteuerung Funkspiegelanklappen change to “active” But I didnt find those: [34] - Access control 2 - Profilfunktion fur Anklappung der Aussenspiegel [35] - Access control 2 - Signalisierung Spiegelanklappung Do you think I have to change 19 module (can gateway) for the one from the car that donated the mirrors? Maybe yes. Look at the faults: " [New feature! Extended UDS fault detail is only supported by current gen. interfaces]": Address 19: CAN Gateway Labels: 5Q0-907-530-V1.clb Control Module Part Number: 5Q0 907 530 L HW: 5Q0 907 530 E Component and/or Version: GW MQB Mid 124 1144 Software Coding: 030100040B087300EF000248080F00010001000000000000000000000000 Work Shop Code: WSC 73430 790 00125 ASAM Dataset: EV_GatewLear 009013 (SK37) ROD: EV_GatewLear_009.rod VCID: 3A716F2ABD5F905D8C-806E 3 Faults Found: 131658 - Door Control Module - Driver's Door U0199 00 [008] - No Communications [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 54 Mileage: 191960 km Date: 2023.03.08 Time: 19:31:52 Terminal 30 power supply: 12.3 V Terminal 15: OFF 15360512 - Component Protection U1101 00 [009] - Active Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 247 Mileage: 191415 km Date: 2023.02.25 Time: 18:19:59 Terminal 30 power supply: 14.0 V Terminal 15: On 8526355 - Voltage Drop in Generator Leads too large P30DE 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 5 Fault Frequency: 254 Reset counter: 67 Mileage: 191416 km Date: 2023.02.25 Time: 20:51:37 Terminal 30 power supply: 14.1 V Terminal 15: On Address 42: Door Elect, Driver Labels: 5QX-959-X93-42.clb Control Module Part Number: 5Q4 959 593 E HW: 5Q4 959 593 B Component and/or Version: TSG FS 011 0032 Software Coding: 00110120D000040000001100 Work Shop Code: WSC 73430 790 12345 ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001 (SK37) ROD: EV_DCUDriveSideEWMAXCONT.rod VCID: 479706DEFEADFDB503-8012 1 Fault Found: 65593 - Switch for Central Locking B122D 29 [009] - Signal Implausible Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 14 Mileage: 191960 km Date: 2023.03.09 Time: 20:13:50 Address 52: Door Elect, Pass. Labels: 5QX-959-X92-52.clb Control Module Part Number: 5Q4 959 592 E HW: 5Q4 959 592 B Component and/or Version: TSG BFS 011 0032 Software Coding: 00110120DC00040000001100 Work Shop Code: WSC 73430 790 12345 ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001 (SK37) ROD: EV_DCUPasseSideEWMAXCONT.rod VCID: 46890BDAF9A7E4BDF8-8012 1 Fault Found: 65593 - Switch for Central Locking B122D 29 [009] - Signal Implausible Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 14 Mileage: 191960 km Date: 2023.03.09 Time: 20:13:50 I wair for your response. Regards.
  2. Hi. I need your help. I bought foldable mirrors, mirror knob and dorrs modules. I installed today and I can fold them using the knob, but they dont fold automatically when I lock the car. Well I tried to coding using VCDS but the opcions on my VCDS are not the same that in your post. I did that: But I did find that: I see the opcion on infotainment but I can activate. The mirror lights work radomly and i didnt see those options on modules 42 a 52. My car havent door lights
  3. Hi guys. I’m searching for a rear trunk spoiler for my car but I can't decide between 5E5071605A and 5E5071605B but I dont find images with good quality that help me and in some of them I think that the part number are incorrect I want that the spoiler be small and discret. Can you show me your trunk spoilers please? 5E5071605A 5E5071605B Thanks so much
  4. Difficult or badly explained question?
  5. Thanks so much. ¿Qué web estás usando para ver eso?. I cant use 7zap, when I tried to enter with Google chrome gets me an error
  6. Ok Thanks. I did not associate the label with that tray and I saw a drawer in some car models.
  7. My Octavia came in origina with MIB1 and Bolero screen. It was a small screen and it havent CarPlay. I bought a MIB 2 and a screen 5E0919605n (amundsen I think). Obviously The MIB and screen werent plug&play. They should be unlocked for working on my car. They have been unlocked by Coding Vag Bilbao, CarPlay, Android Auto were be activated. Now I could install a rear camera from Aliexpress. Also Sport Menu was been activated. My question is about sport menu and car information. In sport menu I can see several indicator but only "g force indicator" shows any information. I cant see oil temperature but I can see it on Maxidot. I cant see coolant temperature but I can see it using Vagcom. I cant see turbo vacuum (maybe my car hasnt sensor for that) Is it possible to do some changes with VagCom to see this information in Sport menu or is it not possible because my car is incompatible? About tyres pressure, the guy of Coding Vag Bilbao activated something with OBDeleven but there wasn't information about pressure in the screen, there only was a error light on the speedometer. Maybe my car is not ready for that function. Is it possible to get it ready for that? The picture shows sport menu with oil temperature (no info) and oil temperature on Maxidot.
  8. Hi guys. Can anyone tell me about that tray under drivers seat? I think that it is incomplete. Has it a missing cover?. It seems very small. What can be stored there? Thanks
  9. Oh. Sorry me. I didn't understand that about mirror wire harness. I was thinking that there was another connection near to mirror. And it is double fault by me because two years ago I had to change one broken mirror and now I dont remember that wire were attached to mirror. My memory fails 😞 Thanks so much for telling me that "new" mirror knob has four wires like mine. that makes me think that I don't need to change door wiring. You are helping me so much. I already ordered: - both power foldable mirrors - mirrors knob - both door modules All items are from a 2016 Octavia and I hope to have them next week. And also hope that can work on my car after activate it with Vagcom.
  10. Yes, I was following those intructions, but my no-memory mirror can not do that I did it with Vagcom, but didn't work because my mirror is a no-memory one. Now I can say with absolutely certain that my doors modules are not compatibles. I dessambled one door, and I check module pin conections and wires harnesses. Module pin conection to mirror only have six pins and wire harness from module to mirror six wires (obviously). Well, seeing that I need to change both modules and both wire harness from modules to mirrors. But now I have a big doubt: mirror knob must to be change because the actual one has no power foldable option, but ... how many wires has the mirror knob that I need?. Actual has four wires, if the one needed has more than four I need to change all door wire harness. Can anyone solve me this doubt please?
  11. I'm afraid to use Google Translation for something so sensitive. One bad step and maybe need to recode a module or a ecu. I have my modules information: ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb Part No SW: 5Q4 959 393 E HW: 5Q4 959 393 B Component: TSG FS 010 0031 Serial number: 0000175550004 Coding: 001000208000040000001100 Shop #: WSC 21626 000 1048576 ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001 ROD: EV_DCUDriveSideEWMAXCONT.rod VCID: 458B0CD6C4A1EFA5F1-8010 Rear Driver Side Door Control Module: Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB Component: FOND_FHSG_DRV 005 0004 Serial number: 00000000000000227768 Coding: 010200 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb Part No SW: 5Q4 959 392 E HW: 5Q4 959 392 B Component: TSG BFS 010 0031 Serial number: 0000155959757 Coding: 001000208000040000001100 Shop #: WSC 21626 000 1048576 ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001 ROD: EV_DCUPasseSideEWMAXCONT.rod VCID: 448D11D2CF9BD6ADE6-8010 Rear Passenger Door Control Module: Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB Component: FOND_FHSG_PSG 005 0004 Serial number: 00000000000000236216 Coding: 190200 No fault code found. ------------------------------------------------------------------------------- Now I need to know if those modules are compatible with foldable mirrors. On Vagcom I can to activate foldable mirros option. Maybe it is compatible, isnt it? And I need to dissambly one door and check wires from module to mirror because I remember that only was six wires per mirror, and fodables ones have more wires. In this case I need to buy mirrors and wire harness. Also I need to check how many wires are form module to mirrors knob and then buy in a car scrapping or ebay all I will need
  12. Well, I know that mirror dipping and foldabling mirror are two different things, but I asked because we are talking about mirrors As you say, I will identify the modules this week, then I will compare it with Sasha's one The first one Its looks difficult and I can't speak russian. Maybe if I do the second one I will need to change door module, the mirrors ( ones with more wires) and mirrors knob and finally I get that two new functions on my car. Is it possible to know the part number of the appropriate module? Thanks.
  13. I have an Opel Insignia with memory seats and mirror too returns correctly. Today I tried to activate mirror dip on my Octavia and mirror didn't return. Really mirror dip only a little bit. The mirror only returned to the first position when I changed the mirror knob from "passenger mror" to "0" Please, can you tell me more about how to do this codification My car's mirror have 6 wires (at leats the driver's side one). I think tat wire are: 1 ground 2 for control the movements 1 for blinker 1 for defog taking advantage of this conversation. is it possible to install auto foldabling mirror in a car that dont have that opcion?
  14. Hi. Can you tell me how can I get worshop code and country code of another system? I want to try it tomorrow. Thanks Really my car doesnt have memory seats 😞 But I will try it if is possible. In case of the modification doesnt work I will reverse the changes. Thanks. This is not possible on mine car
  15. Hi guys I was trying to enable passenger mirror dip on selecting reverse but I received an error and I didnt knew how to continue. My Octavia III is from November'13 and maybe it isn't compatible with this mod. Well, car's module 52 is for passeger's door like the tutorial tells Really bits 2 and 3 in byte 4 are correct and if you read the descripcion them are for dipping mirror I activate both but when I exited for write the chages I received and error and I didnt know if was secure for the car Continue. Can you help me with that? Maybe I should to select "NO" and continue, but I was afraid of decoding the control unit and causing a breakdown I could activate fog lights as cornering lights, activate fuel refill on maxidot and activate goth rear fog lights using the tutorial on this forum. Thanks in advance
  16. Thanks. I fixed the problem replacing the servomotor with one from a Golf VII. Same part number (5Q0907511K) but different manufactured. Original one was Denso and the "new" one is Valeo. It cost me €15 in a scrapyard. In a Skoda oficial service the servomotor value is 125€. Thanks for your time. I cant help you with your question 😞
  17. Hi! problem found. The engine was lower than the one I was looking at. I removed that motor and it had a loose pinion. I put the pinion on the motor and tested with VCDS, there is no fault anymore, but I have to replace the motor because the pinion stopper is broken and the pinion comes loose.
  18. Hi! accessed the motor temperature flapthat is behind the glovebox (right side). I changed climatronic temperature form Low to High and High to Low and its moved correctly. I checkd on VCDS the movement of right and left motors temperature flaps and them moved correctly from 100% to 0.0% and viceversa. But.. I found a strange valud in warm stop of left temperature flap (234) The same of the right side and both for cold stop values are 0 (see the picture attached). And also you can see a new fault the I can erase with VCDS. I upload a video changing temperature and you can see the motors temperature flaps movement but I lowered the quality to be able to upload it. Vídeo 2-2-23, 17 29 22.avi Do you think tht do a "resetting of all adaptations value" will be secure for the car and it will be a solution for my problem?
  19. Hi. thanks for your answer No, I didnt try it that because I didnt know how to do that. I searched on Google, and I found a service manual for repairing a/c and I think that is a motor flap behind the glovebox (V159). Look at that: I also found that video, it is not the same car, but I think is same motor temperature flap I will try to fix it two hours later. Crossing fingers
  20. Hi. I have a December'13 Octavia III (LHD) and the heating does not heat. I used Vagcom to check errors and I got the next one: 1 Fault Found: 328197 - Motor for Right Temperature Flap B108D 54 [009] - Missing Calibration / Basic Setting Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 200 Can anyboy tells me where is located that motor please? O tell me something to fix that error. I recalibrated yhe climatronic pressing a/c and air up buttons, but error persisted ( Thank so much
  21. Hello. Thanks for your answer. I hope to receive the camera next week I'll try to get those rackets and hold the camera using them
  22. I will buy the one with tow USB-A that you told me. Thank so much.
  23. Please, can you show me those brackets to buy the same ones?.
  24. that is another option, but I had not found any so small that it did not protrude from the lighter. Iwill try one of them.
