Everything posted by yerbito
Skoda Octavia III 1.6 TDI – Gear selection problems
The biting point is around halfway through the pedal travel, perhaps slightly lower, closer to the floor. With the clutch pedal fully depressed and a gear engaged, the car doesn’t try to move at all. The clutch doesn’t slip under load either. Even when driving uphill in a high gear, the engine revs drop rather than the clutch slipping. With the engine switched off, all gears engage more easily, even without pressing the clutch pedal. However, I can still feel the mechanical engagement of each gear through the gear lever, almost as if I can feel the gears engaging. With the engine running, shifting is noticeably harder, especially when downshifting. I’ve already adjusted the gear linkage following a tutorial, but unfortunately it hasn’t solved the problem. Personally, I would suspect the plastic components in the gear linkage, the gearbox oil level or condition, or even worn synchronisers before blaming the clutch. Of course, I could be wrong, but the clutch itself seems to be working fine to me. What do you think?
Hi everyone! I have a 2013 Skoda Octavia III 1.6 TDI 105 PS (CLHA), with a 5-speed manual gearbox and around 250,000 km. The engine was originally remapped from 105 to 155 PS, and the exhaust system has since been modified and emptied out. I estimate it might now produce around 170 PS, although this hasn’t been confirmed on a dyno. Recently, I’ve started having problems selecting gears, especially when downshifting into 4th, 3rd and 2nd. Sometimes it feels as if the gear lever hits a mechanical stop, and I have to apply more pressure than normal to engage the gear. Rev-matching or giving the throttle a quick blip sometimes helps. I’ve also noticed that 5th gear can be difficult to engage, and the lever doesn’t always seem to return smoothly from the 5th gear position. However, the lever seems to return to the centre normally from the other positions. The clutch doesn’t slip, and gear selection doesn’t seem to improve significantly with the clutch pedal fully depressed. The problems appeared after someone else drove the car quite aggressively, including some hard acceleration and rough gear changes. I’ve already adjusted the gear selector cables following an online tutorial, but unfortunately the problem persists. I’m wondering whether this could be caused by worn gearbox components, damaged synchronisers, a clutch issue, or something else. Has anyone experienced similar symptoms with this 5-speed gearbox? I’m also planning to check the gearbox oil level. Any advice or experiences would be greatly appreciated! Thanks in advance!
Upgrade gearbox from 5 speed to 6 speed
Hi everyone! I’m also interested in converting my Octavia III 1.6 TDI from a 5-speed to a 6-speed manual gearbox. Mine is a 2013 1.6 TDI CLHA, originally 105 hp. It has been remapped with an additional 50 hp (around 155 hp in total), and the DPF has also been removed. I bought it in 2021 for €2,900 with 170,000 km on the clock. It now has around 250,000 km. Recently, I’ve been having problems with the gearbox, especially when downshifting. Fourth, third and second gears are all becoming very difficult to engage. As far as I can tell, the clutch isn’t slipping and doesn’t seem to be in particularly bad condition. If the gearbox itself turns out to be the problem, I’d rather replace it with a compatible 6-speed gearbox instead of fitting another 5-speed one. My main goal would be to reduce engine RPM at motorway speeds, improve fuel economy and make better use of the extra power. Does anyone know which 6-speed gearbox would be the most compatible with my CLHA engine? I’d also like to know: Would I need anything else apart from the gearbox and gear selector/linkage? Can I keep my original driveshafts, gearbox mounts, clutch and flywheel? Would any ECU coding or other software changes be necessary? Has anyone actually completed this conversion on a front-wheel-drive 1.6 TDI? I’d really appreciate any advice, especially from anyone who has already done this conversion. Thanks in advance!
front head rest removal
Thank you very much for your help! Your explanation was exactly what I needed, and I managed to remove the headrest successfully. I’m attaching two photos in case they help someone else with the same problem in the future. Thanks again! 👍
About USB on Octavia mk3
Hi I installed rear usb from Aliexpress (following one tutorial on this forum) but it is not QC3 and my iphone it consumes more battery than it charges when Im using wireless CarPlay. Does anybody know if exist a Quick charge version? Also I saw next picture in Aliexpress, but I didnt find those usb. Does anybody know how can I find them (qc version better)? thanks in advance.
Drivers side blower not blows warm air
Both pipes on heater matrix were hot, very hot. I couldn't touch them for more of two seconds. Do you think heater matrix could been start to blocked. I readed in a forum that when heater natrix is starting to be blocked left side air doesnt heat and few weeks later right side air neither. timing belt, coolant pump were changed one month ago. also coolant and coolant tank (original G13) were changed for a new ones (G12)
Today I was trying to fix the fault but I couldnt do it. Firts of all, VCDS shows me this fault: Thursday,28,December,2023,11:55:28:00009 VCDS Version: Release 22.10.0 Running on Windows 10 x64 www.Ross-Tech.com 6 Address 08: Auto HVAC Labels: 5G0-907-044.clb Control Module Part Number: 5E0 907 044 HW: 5E0 907 044 Component and/or Version: Climatronic H02 0604 Software Coding: 01010104000100011005004000100000 Work Shop Code: WSC 73430 031 00063 ASAM Dataset: EV_ACClimaBHBVW37X 002017 (SK37) ROD: EV_ACClimaBHBVW37X_002_VW37.rod VCID: 62C1F74A754FB89DF4-8036 1 Fault Found: 1048838 - Functional Limitation due to Energy Management B10CD 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 3 Reset counter: 82 Mileage: 207483 km Date: 2023.12.25 Time: 12:59:00 I erased the fault, but nothing happened I checked left servomotors and I think the work correctly during the reset and when I changed temperatures. Perhaps there are something broken inside the flap of numer 9 servomotor (left temperature) I setted up the temperature at 16º and 28º when coolant was 90º. When climatronic was 16 there were diference between right and left side, but when was 18 there were 10º of difference (remember footweel vent temp sensor is on the left side) warm air: Cold air: What happen if I reset values on Basic settings button? Really I dont know how to fix this issue 😞 Thanks in advance
Bcm swap
Thanks so much. I bought one on eBay
Maybe that servomotor (v158) is not connected to the flap. As you say as a result of the accident because for car reparation I didnt touch anything near the servomotor. I will check it the day after tomorrow.
Bcm swap
How much does the 5Q0937084AE module cost? Im from Spain.
Bcm swap
VIN number is: TMBAG7NE3E0010834 I dont have ODIS, but I know two person that the have. The routine you say does a backup of my original BCM? I think that the two keys I have can be configured with the new immo codes, right?
I cleared vcds error and tried the instructions of this video for three times but only passager side blowers blow warm air. Drivers side blowers blow cold air. 26º are setup in two sides 😞 I don't know what more can I do
Thanks for your response, but I was tried this before wrote the post. Nothing happened
Bcm swap
Hii! i have got a LHD Nov’ 13 Octavia mk3. I want to do a bcm swap. i think my actual bcm is medium and I want to swap ir for a high to install heated seates and foldable mirrors. i dont know if is possible and how difficult can be. I only know that its needed to remove component proteccion but I know two persons to do that. in advance
Hii! i have got a LHD Nov’ 13 Octavia mk3. I get crashed two mounths ago. the car was repaired but now the blower on the drivers side doesnt not blow warm aire. In the passeger side works correctly. i get the next error in vcds. I cleared it, but nothing happens. Saturday, 23, December, 2023, 11: 09:45:00009 VCDS Version: Release 22.10.0 Running on Windows 10 x64 www.Ross-Tech.com Address 08: Auto HVAC Dri\ Control Module Part Number: SEe 987 044 Labels: 5G0-907-044. clb HW: 5E0 907 044 Component and/or Version: Climatronic H02 0604 Software Coding: 01010104000100011005004000100000 Work Shop Code: WSC 73430 031 00063 ASAM Dataset: EV_ACClimaBHBVW37X 002017 (SK37) ROD: EV_ACC11maBHBW37X_082_W37.rod VCID: 62C1F74A754FB89DF4-8036 1 Fault Found: 1048838 - Functional Limitation due to Energy Management B10CD Be [ees] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: อออออออ1 Fault Priority: 6 Fault Frequency: 9 Reset counter: 74 Mileage: 206691 km Date: 2023.12.11 Time: 19:21:27 Can anyone help me, please? thanks in advance.
Retrofitting Rear + Front OPS parking sensors
Hiii. I want to do this retrofit but I dont know what pdc control unit, wires and sensors I need. maybe pdc control unit 5Q0919294E fits on my nov’ 13 Octavia III. Can I keep my front and rear bumpers if I drill out them with bea0001? Tjanks in advance.
Retrofitting heated seats
Hi. I bought that harness, but I dont know how to connect it. https://www.cars-equipment.com/en/shop/seat-heating-parts-comfort-5/wiring-for-front-seat-heating-retrofit-2/ My car is a LHD Nov’13 Octavia mk3 with this bcm Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb Part No SW: 5Q0 937 084 S HW: 5Q0 937 084 S Component: BCM MQBAB M H14 0112 Serial number: 00011313701384 I want to install heated seats, but I need to know how connect the harness to bcm the harnness has got the next wires: For left seat, I think: - Brown with ring comnector for ground - Red/green with a medium size femake connector maybe for +12v - purple wire with a small female connector - white wire with a small female connector that has a split to the another seat connector for right seat: - brown wire too - red/white with a medium size female connector maybe for +12v - black/green with a female small connector. - the white wire. Also it has an extra red wire about 80cms lenght and two diferent female connectors in both sides. Can I connect this harness to my bcm and activate heated seats bit in module 09 or do I need an extra control unit like this: https://www.cars-equipment.com/en/shop/seat-heating-parts-comfort-5/oem-3aa959772-seat-heating-control-unit/ thanks in advance.
Driver’s window error
Thanks so much. I followed your instructions and I dolved the issue. 😊
Hi! I have this error in Vagcom and I don't know how to fix it. The window goes up and down, but the comfort option (one touch up or down) does not work. Does anyone know how to solve it?) thanks in advance. Address 42: Door Elect, Driver Labels: 5QX-959-X93-42.clb Control Module Part Number: 5Q4 959 393 E HW: 5Q4 959 393 B Component and/or Version: TSG FS 010 0031 Software Coding: 001000208000040000001100 Work Shop Code: WSC 21626 000 1048576 ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001 (SK37) ROD: EV_DCUDriveSideEWMAXCONT.rod VCID: 458B0CD6C4A1EFA5F1-8010 1 Fault Found: 65588 - Motor for Window Regulator B1487 54 [009] - Missing Calibration / Basic Setting Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 22 Mileage: 205974 km Date: 2023.11.05 Time: 00:56:19
- vRS Heated leather seat retrofit
Heat seats
Hi guys. I would like to know if Skoda has manufactured heated seats with the same upholstery as the original seats in my car. If so, I would like to know the references of the seats so I can look for used ones to install in my car.
Crash data reset
thanks so much! Thanks so much. can you tell me the link of this item? fortunately chassis is not damage. In my case the damage is to the steering and suspension elements of the right wheel and the rear axle (also on the right side, but I replaced it completely)
Crash data reset
Hi guys. I ran off the road with my car and the airbag exploded! Fortunately I only blew one tire, but the right curtain airbag exploded. Is it possible to reset the airbag control unit with Vagcom or do I have to buy a new or used one? thank you
Did anyone have problems buying at kopacek?
Well, On May 17 I bought dynamic turn lights and led light for mirrors, and a rear spoiler. I spent 252€. That day they sent me a tracking number. The following week the transport company said they still did not have the package, and I could not see changes in the tracking. I sent an email to Kopacek asking for my ordern status. The next week they answered me saying that they havent the rear spoiler in selected colour. I answered saying that the color is not important because I need to repaint it and if they can not send the spoiler refund me for that item and send the rest. After that I sent some mails more and the never answer me. Today I keep on without news of them. I thing that this web is not secure to buy, abut I used Paypal to pay the order and I'm thinking to ask for a full fefund to Paypal. In any of case they are not a serious web to buy.
Help me. Installing electronic foldable mirrors with autodimming.
Can you help me please? 😞
