JoaoVr
Everything posted by JoaoVr
  1. Does anyone know the correct oil spec for our gearboxes?
  2. Good question. Same engine and gearbox as you, looking for the same
  3. Dont worry about yout 110ºC. And we are still in winter 😞
  4. This is mine last week, frim 150hp to 180hp. It feels like the car is way lighter πŸ˜ƒ
  5. Is there any plug and play oil radiator for our Skoda Superbs?
  6. To clear all adaptations is to reset to factory settings in VCDS? thank you for all the help, it is much appreciated!
  7. I moved lumbar support up and down to the maximum and took some logs Log-TMBJH9NP7H7031059.txt
  8. Whre did you get it? looking one for myself
  9. I Tried that but without any success. Norming fixed the other seat errors but not these ones. Seat is 100% original
  10. Having this "older" gateway the only differece will be not showing the menu in the MIB? Or I am missing more features? 1 Error done, 3 to go! All related to Lumbar thing. Any advices?
  11. expansion-display_configuration_0x45_msg_bus -> was something I turned on to show VC menu in the MIB. Not activated works perfectly! Dosent show the error. I never had the menu anyway. Understood that now. I managed to have Mib 2.5 and VC working perfectly but never managed to find that menu in my MIB. I guess I would never find it anyway πŸ˜ƒ "Not activated" will change anything in my car?
  12. Yeah! I retrofited the Mib 2.5 the 9.2" screen and the Virtual Cockpit
  13. Here it is 5F πŸ˜ƒ adpmap-5F-565-035-043-E_TMBJH9NP7H7031059-20230222-0702.CSV
  14. Here it is: ;SW:3Q0-959-435-E HW:3Q0-959-435-E --- Acc/Start Auth. ;Component:VWKESSYMQB 036 0811, Coding:032C0C0E03 ;EV_KessyHellaMQBAB,004039,EV_KessyHellaMQBAB.rod ;Tuesday,21,February,2023,19:35:50:22860 ;VCDS Version: Release 22.10.0 (x64) Data version: 20221026 DS344.0 ;VCID: 3C20342626EE332BF7A-8068 IDE00001-MAS12708-Production mode-Deactivation of automatic shutdowns of terminal 15,not active ,3 IDE00001-MAS12709-Production mode-Deactivation of automatic rear lid opening,not active ,3 IDE00001-MAS12710-Production mode-Deactivation of terminal 50 request,not active ,3 IDE00820-MAS01172-Activating and deactivating all development messages-Development messages,not active ,1 IDE00820-ENG98891-Activating and deactivating all development messages-Reserved,0 ,1 IDE02332-Deactivate production mode,0 ,3 IDE03251-Stop enable for Start/Stop function,According to function requirements ,1 IDE04159-Deactivation of start/stop function,not active ,1 IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2 IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2 IDE09735-CU tailgate opener: sensor 1: threshold value 1,101 ,1 IDE09736-CU tailgate opener: sensor 1: threshold value 2,24 ,1 IDE09737-CU tailgate opener: sensor 1: threshold value 3,24 ,1 IDE09738-CU tailgate opener: sensor 1: threshold value 4,24 ,1 IDE09739-CU tailgate opener: sensor 1: threshold value 5,24 ,1 IDE09740-CU tailgate opener: sensor 2: threshold value 1,2 ,1 IDE09741-CU tailgate opener: sensor 2: threshold value 2,31 ,1 IDE09742-CU tailgate opener: sensor 2: threshold value 3,2 ,1 IDE09743-CU tailgate opener: sensor 2: threshold value 4,31 ,1 IDE09744-CU tailgate opener: sensor 2: threshold value 5,224 ,1 IDE09745-CU tailgate opener: sensor 1: timer value 1,170 ,1 IDE09746-CU tailgate opener: sensor 1: timer value 2,0 ,1 IDE09747-CU tailgate opener: sensor 1: timer value 3,0 ,1 IDE09748-CU tailgate opener: sensor 1: timer value 4,225 ,1 IDE09749-CU tailgate opener: sensor 1: timer value 5,28 ,1 IDE09750-CU tailgate opener: sensor 2: timer value 1,11 ,1 IDE09751-CU tailgate opener: sensor 2: timer value 2,165 ,1 IDE09752-CU tailgate opener: sensor 2: timer value 3,147 ,1 IDE09753-CU tailgate opener: sensor 2: timer value 4,204 ,1 IDE09754-CU tailgate opener: sensor 2: timer value 5,8 ,1 IDE09755-CU tailgate opener: sensor 1: burst length,16 ,1 IDE09756-CU tailgate opener: sensor 1: active screening,16 ,1 IDE09757-CU tailgate opener: sensor 2: burst length,2 ,1 IDE09758-CU tailgate opener: sensor 2: active screening,31 ,1 IDE09759-CU for tailgate opener: reset all counters,Unknown (224),1 IDE09760-CU for tailgate opener: check sum,170 ,1 IDE09829-CU tailgate opener: foot gestic recognition: timer value 1,2 ,1 IDE09830-CU tailgate opener: foot gestic recognition: timer value 2,31 ,1 IDE09831-CU for tailgate opener: play protection increments,6 ,1 IDE09832-CU for tailgate opener: play protection decrements,25 ,1 IDE09833-CU for tailgate opener: play protection threshold active,255 ,1 IDE09834-CU for tailgate opener: play protection threshold inactive,5 ,1 IDE09835-CU for tailgate opener: play protection decrement interval,60 ,1 IDE09836-CU tailgate opener: sensor 1: control parameter,16 ,1 IDE09837-CU tailgate opener: sensor 2: control parameter,16 ,1 IDE09838-CU tailgate opener: foot gestic recognition: evaluation,0 ,1 IDE09839-CU for tailgate opener: parameter set version,30 ,2 IDE10844-Control module rear lid opening: duration status query,4960 ms,1 IDE10845-Control module rear lid opening: vehicle type,1C ,1 ENG153713-ENG129122-Byte12_diverse-environment_scan_step1,not activated ,1 ENG153713-ENG126978-Byte12_diverse-environment_scan_step2,not activated ,1 ENG153713-ENG154598-Byte12_diverse-exeption_drivers_doors_interior_scan,activated ,1 ENG153713-ENG154691-Byte12_diverse-interior_scan_clamp_15_new_concept,activated ,1 ENG153713-ENG154710-Byte12_diverse-open_cabrio_canopy_interior_scan,not activated ,1 ENG153713-ENG154787-Byte12_diverse-suppression_access_detection_for_remotestart,not activated ,1 ENG244871-ENG245027-Byte13_vit_lf-lock_via_toggle_by_closed_vehicle_skin,not activated ,1 ENG244871-ENG245033-Byte13_vit_lf-toggle_active,not activated ,1 ENG244871-ENG245019-Byte13_vit_lf-toggle_at _open_door,not activated ,1 ENG244871-ENG297724-Byte13_vit_lf-toggleVariante,China ,1 ENG244871-ENG129126-Byte13_vit_lf-vit_evaluate_inversbit,not activated ,1 ENG244871-ENG129125-Byte13_vit_lf-vit_exit,not activated ,1 ENG126956-ENG126976-Byte9_VIP-active_vip,activated ,1 ENG126956-ENG154580-Byte9_VIP-Coding_easyclose_locking,not activated ,1 ENG126956-ENG154581-Byte9_VIP-Coding_kick and_close_function,activated ,1 ENG126956-ENG248655-Byte9_VIP-ECL_Start_ueber_ViP,not activated ,1 ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation,not activated ,1 ENG126956-ENG142121-Byte9_VIP-vip_activation_on_clamp15,not activated ,1 ENG126956-ENG126977-Byte9_VIP-vip_deactivation_on_running_engine,not activated ,1 ENG129011-CAN_signal_transmitting_delay_of_car_roll _away_warning,1.00 s,1 ENG126957-CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff,1.00 s,1 ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off,10.00 s,1 ENG105462-CAN-timeout service-key message,260 ms,1 ENG105634-Correction value LED dimming,1.0 ,1 ENG114301-Cycletime for voltage monitoring during sleepmode,100 ms,1 ENG120046-Cyclic interior scan during clamp 15 on,10 s,1 ENG126961-deactivation_time_vip_slidingdoor,15 s,1 ENG126960-Debounce_time_detection,500 ms,2 ENG126959-Debounce_time_driver_presence,200 ms,1 ENG126948-delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle,300 ms,1 ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM,120.00 s,1 ENG105791-Delta value LED dimming curve first point 40 percent dimming,30.0 %,1 ENG105792-Delta value LED dimming curve forth point 100 percent dimming,5.0 %,1 ENG105793-Delta value LED dimming curve second point 60 percent dimming,15.0 %,1 ENG105794-Delta value LED dimming curve third point 80 percent dimming,10.0 %,1 ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open,not activated ,1 ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open,not activated ,1 ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery,not activated ,1 ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go,activated ,1 ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start,activated ,1 ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted,not activated ,1 ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation,activated ,1 ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door,activated ,1 ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive,activated ,1 ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection,not activated ,1 ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv",activated ,1 ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT,activated ,1 ENG123036-ENG99363-DeveloperCoding: Search lights-ZAT active during clamp 58t on,activated ,1 ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load,not activated ,1 ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt,not activated ,1 ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt,not activated ,1 ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible,not activated ,1 ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk,activated ,1 ENG123037-ENG129114-DeveloperCoding: vehicle environment-reactivate_all_doorhandles,not activated ,1 ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel,Left hand steering ,1 ENG105825-Diagnostic: wait time after power on,500 ms,1 ENG126943-Display_duration_emergency_off,3000 ms,1 ENG126944-Display_duration_error_mode_2_SPN,10 s,1 ENG126941-Display_duration_please_engage_P,10 s,1 ENG105898-Doorknob contact sensor disconnecting time,5400 min,1 ENG244875-duration_A-CAN_wake_up_for_Engine_ECU_wake_up,2000 ms,1 ENG126955-duration_to_ZAT_continuous_actuation_detection,1000 ms,1 ENG129005-duration_to_ZAT_multi_actuation_detection,3000 ms,1 ENG126950-duration_ZAT_debounce,50 ms,1 ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose,30 %,9 ENG129029-ENG142127-Easy_close_alignment-Max_time_IDGeber_rear,2.00 s,9 ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose,5.00 s,9 ENG129029-ENG142130-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose,150 ,9 ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk,70 %,9 ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate,500 ms,9 ENG129029-ENG129139-Easy_close_alignment-Timeframe_scan_active,20.00 s,9 ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step,C1 ,5 ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step,05 ,5 ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4,70 mV/m,5 ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area,65 mV/m,5 ENG126966-environment_scan_cyclic_step1,700 ms,1 ENG126967-environment_scan_cyclic_step2,2000 ms,1 ENG126965-environment_scan_duration_step1,300 min,1 ENG126971-environment_scan_duration_step2,24 H,1 ENG126969-environment_scan_level_bem,2 ,1 ENG126968-environment_scan_responselevel_reduction,500 ,1 ENG126970-environment_scan_startdelay_time,5 s,1 ENG126958-Ignition_For_Immobilizer,Default ,1 ENG129016-Initialization_diagnostics_switching_terminal,not activated ,4 ENG107050-Interior scan: deceleration after comfort closing,3200 ms,1 ENG107051-Interior scan: max. engine speed for standing engine,10 km/h,1 ENG107052-Interior scan: opening threshold sliding roof,1 %,1 ENG107053-Interior scan: opening threshold window lifter,5.0 %,1 ENG107054-Interior scan: Speed - threshold,20 km/h,1 ENG153724-Interior_scans_clamp15_break_at_active_message,5000 ms,1 ENG153725-Interior_scans_clamp15_retry_at_active_message,5 ,1 ENG98656-internal,0 B,1 ENG129022-ENG142120-internal_keyminder_byte1-aktivate_function_trigger_access_leaving_elv,activated ,1 ENG129022-ENG129115-internal_keyminder_byte1-allowa_remotestart_to_disable_keys,not activated ,1 ENG129022-ENG120037-internal_keyminder_byte1-Cyclic interior scan during active warning message "Key not found",not activated ,1 ENG129022-ENG100928-internal_keyminder_byte1-Seat Memory: scan after driver door opening,not activated ,1 ENG129022-ENG99649-internal_keyminder_byte1-Seat Memory: scan after driver door opening no KESSY unlocking,activated ,1 ENG129022-ENG99417-internal_keyminder_byte1-Softtouch mounted,installed ,1 ENG129023-ENG99123-internal_keyminder_byte2-Inhibit ID-transmitter for passive go,activated ,1 ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate,activated ,1 ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior,activated ,1 ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing,activated ,1 ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling,not activated ,1 ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate,activated ,1 ENG129020-ENG121989-internal_passive_entry_exit_byte1-Impairment Entry / Exit key on low battery,not activated ,1 ENG129020-ENG125240-internal_passive_entry_exit_byte1-lf_crc,not activated ,1 ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open,activated ,1 ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open,not activated ,1 ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock,not activated ,1 ENG129021-ENG155267-internal_passive_entry_exit_byte2-lf_shutdown,not activated ,1 ENG129021-ENG155268-internal_passive_entry_exit_byte2-lf_shutdown_gotrigger,not activated ,1 ENG129021-ENG100246-internal_passive_entry_exit_byte2-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed,activated ,1 ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit,activated ,1 ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL,activated ,1 ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1,activated ,1 ENG129021-ENG103529-internal_passive_entry_exit_byte2-Passive Entry: second control concept,not activated ,1 ENG107211-Key Minder: delay reunlocking tailgate,500 ms,1 ENG107212-Key Minder: p_keyless_eventsearch_holding_time,10 s,1 ENG107213-Key Minder: p_keyless_eventsearch_retries,2 ,1 ENG107363-LED dimming curve first point 20 percent dimming,40.0 %,1 ENG107592-MCTX Pause,1 B,1 ENG107593-MCTX pause for Go / Key Minder,20 ms,1 ENG107594-MCTX pause for Go authentification,14 B,1 ENG107595-MCTX settling phase,10 B,1 ENG129013-min_receptiontime_vit,0 ms,1 ENG126945-min_time_for_Terminal_50_request,200 ms,1 ENG129003-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,1 ENG126940-Number_of_ZAT_activations_to_DTC,10 ,1 ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout,2.00 s,1 ENG108166-Passive Entry Exit: entry request e-sliding door active time,500 ms,1 ENG108167-Passive Entry Exit: minimum activity time locking sensor,140 ms,1 ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,220 ms,1 ENG108169-Passive Entry Exit: T_ACT_OP_2,5000 ms,1 ENG108297-Proximity Sensor: Comfort Exit-Enlargement,200 ms,1 ENG108298-Proximity Sensor: duration of proximity Signal,10 s,1 ENG108299-Proximity Sensor: lower limit Impuls,2000 Β΅s,1 ENG108300-Proximity Sensor: lower limit proximity-Impuls,12200 Β΅s,1 ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle,10.0 km/h,1 ENG108302-Proximity Sensor: max. Impulslength,75 ms,1 ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls,20400 Β΅s,1 ENG108304-Proximity Sensor: max. intermission-length Diagnostic,14 ms,1 ENG108305-Proximity Sensor: max. length of Diagnosticimpuls,71 ms,1 ENG108306-Proximity Sensor: max. length of Entryimpuls,10400 Β΅s,1 ENG108307-Proximity Sensor: max. length of Exitimpuls,40400 Β΅s,1 ENG108308-Proximity sensor: max. length of signal hall sensor,100 s,1 ENG108309-Proximity Sensor: max. signal-length,120 s,1 ENG108310-Proximity sensor: max. tolerance data bit length,200 Β΅s,1 ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle,20.0 km/h,1 ENG108312-Proximity Sensor: min. enginespeed for a running engine,300 /min,1 ENG108313-Proximity Sensor: min. length of Diagnosticimpuls,42 ms,1 ENG108314-Proximity Sensor: min. length of Entryimpuls,6200 Β΅s,1 ENG108315-Proximity Sensor: min. length of Exitimpuls,24200 Β΅s,1 ENG108316-Proximity sensor: min. tolerance data bit length,120 Β΅s,1 ENG108317-Proximity Sensor: SP_X2,10 min,1 ENG108318-Proximity Sensor: SP_X3,1 ,1 ENG108319-Proximity Sensor: SP_X4,80 ,1 ENG108320-Proximity Sensor: SP_X5,1 ,1 ENG108321-Proximity Sensor: SP_X6,30 min,1 ENG108322-Proximity Sensor: SP_X7,1 ,1 ENG108323-Proximity Sensor: Time Power On,1960 ms,1 ENG123035-Proximity Sensor: Timervalue for ExitReverseOption,0 ms,1 ENG108325-Proximity sensor: turn-off limit from battery-manager,2 ,1 ENG108326-Proximity Sensor: upper limit intermission-length,10 ms,1 ENG120045-Reduced current for transponder-ID request,0 Step,1 ENG126939-rpm_threshold_engine_runnning,100 /min,1 ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol,5 Step,1 ENG108576-Scan Procedure: cycle convenience coverage limiting,40 ms,1 ENG108577-Scan Procedure: Number of Repeats,1 ,1 ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause,100 ms,1 ENG108579-Scan Procedure: Timeout Authentification Result,150 ms,1 ENG129017-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go,190 ms,1 ENG129018-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi,700 ms,1 ENG108582-Scan Procedure: Timeout LF Repetition,100 ms,1 ENG108585-ScanProcedure: Timeout Entry Response,260 ms,1 ENG108586-ScanProcedure: Timeout Response,100 ms,1 ENG126963-settime_trigger_entry_vehicle,500 ms,1 ENG126962-settime_trigger_exit_vehicle,500 ms,1 ENG129024-ENG120039-Sonstiges_byte1-Backdoor TSG,not activated ,1 ENG129024-ENG103075-Sonstiges_byte1-Battery manager mounted,activated ,1 ENG129024-ENG102728-Sonstiges_byte1-Diagnostic: service 86 - response on event,not activated ,1 ENG129024-ENG98656-Sonstiges_byte1-internal,not activated ,1 ENG129024-ENG102591-Sonstiges_byte1-Response extension for scan procedure,not activated ,1 ENG129024-ENG99430-Sonstiges_byte1-Scan Procedure: Timeoutcontrol active,activated ,1 ENG129024-ENG104010-Sonstiges_byte1-Use default antenna data,not activated ,1 ENG129025-ENG129137-sonstiges_byte2-interiorscan_clamp15_reach_trashhold,not activated ,1 ENG129025-ENG142122-sonstiges_byte2-sad_existing,not activated ,1 ENG129025-ENG142123-sonstiges_byte2-trunk_ecu_existing,activated ,1 ENG129007-Speed_threshold_for_driving_cycle_detection,3.0 km/h,1 ENG129006-Speed_threshold_for_moving_vehicle_detection,1.0 km/h,1 ENG129008-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,1 ENG109053-Standard dimming value ZAT,80 %,1 ENG126938-Terminal_15_adaption_body_control_module,Default ,1 ENG126946-Terminal_S_Timeout,30 min,1 ENG102207-Time Sensor Power Off Group 2,3600 min,1 ENG129027-Time_frame_VIP_kick_forecast,5 ,1 ENG126942-time_to_drive_cycle_detection,1.00 s,1 ENG126947-time_to_ignore_ignition_trigger,35 s,1 ENG126954-time_to_ZAT_Open_circuit_detection,1000 ms,1 ENG126951-time_to_ZAT_Short_circuit_fault_detection,60 s,1 ENG126949-time_ZAT_actuation_detection,3000 ms,1 ENG126952-time_ZAT_lock_after emergency_shutoff,1000 ms,1 ENG126953-time_ZAT_lock_after_normal_shutoff,500 ms,1 ENG129009-Timeframe_request_immobilizer_terminal_approval,10000 ms,1 ENG129019-timeout_convenience_coverage_limiting,75 s,1 ENG129014-Timeout_trigger_terminal_deactivation_central_locking,1.00 s,1 ENG109974-Voltage monitoring: overvoltage Delta,500 mV,1 ENG109975-Voltage monitoring: overvoltage for KESSY ECU,16000 mV,1 ENG109976-Voltage monitoring: overvoltage for Keyless Go,27000 mV,1 ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta,0 mV,1 ENG109978-Voltage monitoring: undervoltage Delta,500 mV,1 ENG109979-Voltage monitoring: undervoltage for KESSY ECU,9000 mV,1 ENG109980-Voltage monitoring: undervoltage for Keyless Go,6000 mV,1 ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta,0 mV,1 ENG120047-ZAT init value,0 %,1 ENG110364-ZAT nominal voltage,13.0 V,1 ENG110365-ZAT post-carridge during clamp 15 off,10 min,1 ENG153750-ZAT_clamp58xt_signal_factor,0.200 ,1 ENG153751-ZAT_clamp58xt_signal_offset,3.0 ,1 ENG153752-ZAT_first_fall_time_high_low_state,900 ms,1 ENG153753-ZAT_first_rise_time_low_high_state,100 ms,1 ENG153754-ZAT_motor_signal_timer_1,3000 ms,1 ENG153755-ZAT_motor_signal_timer_2,3000 ms,1 ENG153756-ZAT_pwm_offset_1_lower_limit,5 %,1 ENG153757-ZAT_pwm_offset_2_lower_limit,10 %,1 ENG153758-ZAT_pwm_peak1_upper_limit,90 %,1 ENG153759-ZAT_pwm_peak2_upper_limit,100 %,1 ENG153760-ZAT_second_fall_time_high_low_state,2000 ms,1 Elapsed Time: 00:56
  15. Hey everyone, Trying to solve some faults in my superb, the easy ones I managed, I need some help with the remaining ones. One Fault in Multimedia Saturday,18,February,2023,20:21:44:22860 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64 VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4630.4 Data version: 20221026 DS344.0 www.Ross-Tech.com VIN: TMBJH9NP7H7031059 License Plate: Mileage: 123504km-76741mi Repair Order: Address 5F: Information Electr. Labels: None Control Module Part Number: 565 035 043 E HW: 565 035 043 Component and/or Version: MU-H-N-EU H50 1440 Software Coding: 03840201FF0000005111000100080A232F0100E401200000DE Work Shop Code: WSC 12345 123 61029 ASAM Dataset: EV_MUHig4CGen2HBAS 001001 (SK48) ROD: EV_MUHig4CGen2HBAS_AU37.rod VCID: 1470BC866EFE1B6B5FA-8040 1 Fault Found: 7237 - Function Restricted due to Missing Message(s) U1111 00 [009] - - [Display configuration (0x45) - function restriction due to communication error - BapErr_retry not successful] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 123 Mileage: 123504 km Date: 2023.02.12 Time: 20:43:19 Voltage terminal 30: 12.4 V BAP-BAP_Function_ID: 02 3 Faults in seats unit: Saturday,18,February,2023,20:22:14:22860 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64 VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4630.4 Data version: 20221026 DS344.0 www.Ross-Tech.com VIN: TMBJH9NP7H7031059 License Plate: Mileage: 123504km-76741mi Repair Order: Address 36: Seat Mem. Drvr Labels: None Control Module Part Number: 5Q0 959 760 B HW: 5Q0 959 760 B Component and/or Version: Sitzmemory H08 0022 Software Coding: 0010000000000500018280808080000000008181000000D400 Work Shop Code: WSC 33361 790 00139 ASAM Dataset: EV_SeatMemorDriveSide 002022 (SK48) ROD: EV_SeatMemorDriveSide.rod VCID: 3C20342626EE332BF7A-8068 3 Faults Found: 9654868 - Motor for Lumbar Support Fore/Aft Adjustment B1352 54 [009] - Missing Calibration / Basic Setting Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 123 Mileage: 123504 km Date: 2023.02.12 Time: 20:43:16 9654612 - Motor for Lumbar Support Height Adjustment B1351 54 [009] - Missing Calibration / Basic Setting Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 123 Mileage: 123504 km Date: 2023.02.12 Time: 20:43:16 10489856 - No Basic Setting B2010 00 [009] - - [keine oder falsche Grundeinstellung/Adaption] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 7 Fault Frequency: 1 Reset counter: 123 Mileage: 123504 km Date: 2023.02.12 Time: 20:43:16 Anyone managed to solve this?
  16. VAG crash fix option disable or enable? Im not so lucky with mine πŸ˜•
  17. Do you have a special config in your AAWireless? Saw yours and bought one, but mine is always rebooting for no reason
  18. How does the Virtual Cockpit menu on the MIB looks like? Did all codding, got all working, cant find the menu.
  19. Found it! So.... From the MIB2 unit goes a cable to USB HUB under the armrest - REALLY UNDER. From there goes to both USB sockets. Both can connect androidauto/aplecarplay to the unit
  20. I I need to locate USB hub. Part 5g0 035 953c
  21. Here it is. If it is only in ash tray, also very simple to replace the cable
